Old 06-05-2003, 09:09 AM   #1
Boujie
Member#: 5444
2000 2.5RS
BRP
Angry Chirping noise...help!
Ok so I've had this chirping/squeaking noise ever since I had a new clutch and flywheel put in. Was told it was the throwout bearing so I waited til that clutch started slipping and then went with an exedy clutch/flywheel kit. The damn noise is still there. When I push the clutch in the noise goes away. Let the clutch out and it's back. I can pull the clutch fork forward and the noise goes away. Once I let go it comes back though. Any ideas on what could be causing it? Slave cylinder? Throwout bearing again?! I have no idea.
-Frank
Boujie is offline   Reply With Quote
Old 06-05-2003, 09:11 PM   #2
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Who did the Exedy kit install?
Have you packed the slave cylinder with grease yet?
If you already did the symptom you describe is identical to a bad TOB. It's also possible your clutch fork is bent and is accelerating your TOB wear.
Albert is offline   Reply With Quote
Old 06-06-2003, 10:50 AM   #3
Boujie
Member#: 5444
2000 2.5RS
BRP
I had a local mechanic that I've known for years do the install. Haven't tried packing the slave cylinder with grease. What kind of grease should i use? You may laugh at my n00bishism.
Thanks for your help. I truly appreciate it.
-Frank
Old 06-06-2003, 12:17 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
simple question.
did you change the tob???
you never said this was changed along with the clutch.
if it was.. then definately time to consider slave/master cylinder swaps... i had this problem "cricket" noise.. until i changed the cylinders....
good luck to ya.
jamie www.subiegalracing.com
_____________________________________
Old 06-06-2003, 05:48 PM   #5
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Good catch Jamie...there is no specific mention of installing a new TOB.
If you still want to try the slave cylinder grease thingy all you'll nedd is about a half teaspoon of high temp roller bearing grease. The grease will help damper the rattle of the slave cylinder pushrod when there is no pressure applied to the clutch (ie at a stop light). Basically just pop off the rubber accordian booth from the end of the slave cylinder, (don't loose the little brass pushrod). Pack the grease into the opening, reinstall the pushrod and booth then finally put a small dab of grease where the pushrod contacts the clutch fork.
Old 06-07-2003, 04:04 AM   #6
Boujie
Member#: 5444
2000 2.5RS
BRP
Oh yea...yes the TOB was replaced. Sorry about that.
-Frank
Old 06-07-2003, 05:14 PM   #7
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
good!!
****BTW, what kind of shape was the old one in? Were any of the end seals ruptured, did it spin freely and in good operational condition?
now...
...grease the slave m/c pushrod.
if that doesn't resolve the issue, replace the slave m/c, if that still doesn't do it your clutch fork is likely bent IF the old TOB was in bad shape.
Old 06-09-2003, 12:25 PM   #8
Boujie
Member#: 5444
2000 2.5RS
BRP
Going to grease her up sometime this week and see if that helps
If the slave cylinder needs to be replaced is there a good aftermarket I should replace it with?
Thanks again for the help!
-Frank
Squeaking/Chirping noise, help me diagnose JanssenTodd Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-06-2009 07:15 PM
Chirping Noise? Help... Akina Newbies & FAQs 4 01-19-2007 12:49 AM
Car making a chirping noise, need help imisplacedmine Newbies & FAQs 11 05-31-2006 08:29 AM
WRX develops chirp noise? toobee1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 05-08-2002 01:50 AM
Chirpping noise coming from right front tire? ImprezedRS Brakes, Steering & Suspension 1 08-21-2001 01:44 PM
