Old 06-05-2003, 10:51 AM   #1
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Default 99 RS and up Knock sensors
I am curious as to the actual usage of the stock knock sensor. I beleive that there is a kncok sensor on the 99 and up RS'. But how well or how good is this knock sensor. Is it next to useless or is it as good as the wRX one (which i don't beleive it is).
HOK is offline   Reply With Quote
Old 06-05-2003, 11:50 AM   #2
Turbo GC4
Member#: 28555
all i know is that my knock sensor bolt came loose and i thought my car was gonna blow up.
it depends on what your definition of useless is? I think once you step on the gas and go to high throttle, the ECU stops using sensor readings to determine A/F.
I believe this is the reason why a JS safeguard comes in handy. Knock is not our friend.
Turbo GC4 is offline   Reply With Quote
Old 06-05-2003, 01:06 PM   #3
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
what about advance I know at high revs the ECU stops listening to the knock detector but i didn't know that at high throttle or WOT it goes to ignore mode too...
Can you elaborate on your situation with the screw loose on the knock sensor? sounds scary...
Old 06-06-2003, 09:02 AM   #4
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Revision is offline   Reply With Quote
Old 06-07-2003, 01:27 AM   #5
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
thanks!
Code #325 came up...knock sensor? If so, then... dingo dave Warranty Issues & SOA Problems 0 09-04-2005 05:18 PM
WTB RS 2,5 Knock sensor jayfressh Private 'Wanted' Classifieds 2 07-14-2005 01:24 PM
99 RS build-up, engine and EM ??? chrismindless Normally Aspirated with bolt-on Forced Induction Powertrain 14 04-22-2005 11:14 PM
Link and Factory Knock Sensor (RS) Graham Engine Management & Tuning 2 01-22-2003 08:59 AM
KnockLink and stock knock sensor Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 5 04-22-2002 12:29 PM
