Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Old 06-05-2003, 02:13 PM   #1
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Default Calling all JDM STI Engine (EJ207) owners!!
I'm trying to build up a database/table of the EJ207 engine codes for the new age Impreza. As most of you know, there are three model years in the 'new age' catagory.
MY01 - First production year, known as GxxA (i.e. GDAA, GDBA, GGAA, etc) Also called Version 7
MY02 - Second production year, known as GxxB (i.e. GDAB, GDBB, GGAB, etc) Also called Version 7
MY03 - Third production year, updated body sytle, twin scroll turbo on the sti. Known as GxxC (GDAB, etc). Also called Version 8.
What I am looking for!
I'm trying to map out the engine codes. The engine code can be found in two places. First is a small white sticker on the lower left passenger side of the black plastic timeing belt covers (front of the engine). The second stick is at the bottom back side of the drivers side head. You can see it from the top just a bit, and read it with a mirror (it is on the back side, just all the way down).
The Number on either sticker will look like:
EJ207DW3CR-xxx yyyyyy zzzzz
The yyyyyy is the block serial number, which is also stamped into the block on the right back top side, where it mates with the tranny. On the block it will usually be Byyyyyy.
So, could any/all of you with JDM STI or JDM WRX motors read this number and email/post back, also let me know if you know what MY it is. I'll keep the chart below updated with all of the info I can find! This will be VERY helpful for anyone who is considering doing an STI swap in the future.
[UPDATED!]
Model Name/Model Code/Engine Code
Code:
A (MY01 - New Age Body Style Rev 1, V7 )
00/08-01/08
WRX NB (5mt)      GDAA4CD - EJ205DW3BE
WRX NB (4et)      GDAA4CT - EJ205DW3BE
WRX Sti           GDBA4EH - EJ207DW3CR
WRX RA-Sti        GDBA4DH - EJ207DW3CJ
20K (wagon 5mt)   GGAA58D - EJ205DW3BE
20K (wagon 4et)   GGAA58T - EJ205DW3BE
Sti (wagon)       GGBA5EH - EJ207DW3CR
B (MY02 - New Age Body Style Rev 1, V7)
01/09-02/10
WRX NB (5mt)      GDAB4CD - EJ205DW4BE
WRX NB (4et)      GDAB4CT - EJ205DW4BE
WRX NB-R          GDAB4HT - ??????????
WRX Sti           GDBB4EH - EJ207DW4CR
WRX STi-RA spec C GDBB4FH - EJ207DW4EJ
WRX STi PRODRIVE  GDBB4KH - ??????????
WRX STi LIMITED   GDBB4JH - ??????????
S202 STi version  GDBB4FH - EJ207DW4ER
20K (wagon 5mt)   GGAB58D - EJ205DX4BE
20K (wagon 4et)   GGAB58T - EJ205DX4BE
Sti (wagon)       GGBB5EH - EJ207DW4CR
C (MY03 - New Body Style Rev 2, V8)
02/11-
WRX (5mt)         GDAC48D -
WRX (4et)         GDAC48T -
WRX Sti           GDBC4EH -
WRX STi spec C    GDBC4FH - EJ207DW5EJ
WRX Wagon (5mt)   GGAC58D -
WRX Wagon (4et)   GGAC58T -
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 06-05-2003, 04:14 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
well its not exactly a 207 but here is a vin plate from an STI .. it was from the press car at rim
Old 06-05-2003, 04:19 PM   #3
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
you might want to talk to mike at www.spdusa.com and the guys at ralli spec..
Old 06-05-2003, 04:49 PM   #4
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Yep... Dave at Rallispec gave me a bunch of the info I already have... Just wanted to complete the table with every one elses input! I'm building a web page with all of this info, plus all of the other impreza model years for the US, UK, AUS, and JDM.
Thanks for the EJ25 STI info.. I actually just got the same info from an STI here, and it looked identical. The Model Code for the new STI is GDFCYEH (in other words, it is a GDF). Engine code for the new 2.5 turbo is EJ257!
Jeff
Old 06-05-2003, 09:40 PM   #5
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
Hi Jeff here ya go....
MYO2 sti model ~ GDBB4EH
Sticker on timing belt cover ~ EJ207DW4EJ-02F 612782 K510
Sticker drivers side rear lower block ~ EJ207DW4EJ-02F-2782
Drivers side rear block flywheel housing stamp ~ B612782
Rear block center flywheel housing stamp ~ 87282186211
Tom..
Thomas Ruble is offline   Reply With Quote
Old 06-06-2003, 01:21 AM   #6
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Tom..
Did you get the model number from the list above, or from the car?
It appears the motor is an STI Limited, or an STI RA Spec C motor. You can decifer the codes as follows:
EJ207 = the STI 2.0 motor
DW = The market (domestic JDM)
4 = MY02
EJ = RA Spec C, or STI Limited (CR is the regular STI motor)
Based on the block serial number, it looks to be a late MY02 engine. That is a great motor, as the Spec C/Limited motor has more agressive CAMs then the regular JDM STI.
Jeff
Old 06-06-2003, 07:30 AM   #7
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
[quote]Originally posted by sponaugle
[b]
The model # is hand written in white ink on the timing belt cover on my motor.
I thought it was a bit odd that the model code corressponded to a regular ( non spec C ) sti but the engine code is for a spec C. I don't think I have a spec C motor becuase it has AC unless the sti Limited motors came with AC.
I believe I got my motor from same person as you did ( Marshall ). The factory may have mixed and matched parts for testing purposes only, so maybe I have a hybrid.
Tom
Old 06-06-2003, 09:22 AM   #8
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
[quote]Originally posted by Thomas Ruble
[b]
Tom
It is probably an STI Limited motor (which is the same as the Spec C). The Limited had AC as well.
The only way to know for sure is to take a valve cover off, and measure the lift of the CAMs. The Spec C and Limited have a bit more lift then the regular STI.
You are correct, that the motors from Marshal are often hybrids of some kind. The one I got from him was also an EJ, and sure enough, it has the Spec C cams, etc. It may be that the testing area all use the EJ series engines for testing. (NOTE, by EJ, I am refering to the EJ engine spec code, not EJ207, etc. The regular JDM STI Motor has a CR spec code)
Jeff
Old 11-12-2003, 12:27 AM   #9
STI.newbie
Member#: 48008
Hi, where else can I find the serial beside timing belt cover?
Thanks
STI.newbie is offline   Reply With Quote
Old 11-12-2003, 05:31 PM   #10
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Mine had it on the timing cover and also on the head.
Need4Boost is offline   Reply With Quote
Old 11-12-2003, 06:33 PM   #11
STI.newbie
Member#: 48008
Interesting... I didn' see the serial # on the head...
Old 11-13-2003, 03:34 PM   #12
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
[b]
Tom
I have a AC compressor setup from a 02 spec C...it is a smaller, lighter system than that of the Std. WRX.
Jeff, I've been tardy in reporting my data, but I'll post it here asap.
Steve
n2xlr8n is offline   Reply With Quote
Calling All JDM STi Swaps... LatentWagen Subaru Conversions 151 04-30-2011 08:34 PM
Calling all JDM Roof Vent owners jcbluescooby Interior & Exterior Modification 27 01-13-2009 03:42 PM
Calling all JDM V7 and up ECU owners Hyper Subaru Conversions 0 10-20-2006 12:58 AM
Calling All JDM STi Swaps... LatentWagen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 66 07-20-2006 10:47 PM
Calling all MY04 STi Owners 04Flatfour_wagon Off-Topic 0 12-26-2003 05:58 PM
