Old 06-07-2003, 11:37 AM   #1
Solomon
Member#: 36587
2000 Legacy GT (BE)
Default Possible to get Header/Exhaust before a turbo?
Would it make sense to get some Headers and exhaust before getting my turbo? I was thinking that I would get everything at the same time due the fact of going to a turbo would change everything.
Solomon is offline   Reply With Quote
Old 06-07-2003, 05:13 PM   #2
Brady
Member#: 14838
2005 LGT--Garnet Red
197 Iggpoints
well, if you're planning on running engine management too (not just a piggyback), this would be a good idea.
start off with the management alone. then get that tuned really well with your stock exhaust. then put on the exhaust and headers and get that tuned really well too. then put your turbo on (with all the other goodies or whatever) and then, hopefully your experience in tuning will pay off and you shouldn't risk doing any damage when you turbo.
Brady is offline   Reply With Quote
Old 06-07-2003, 07:51 PM   #3
Solomon
Member#: 36587
2000 Legacy GT (BE)
With a bolt on turbo do I not have to get different Headers and Exhaust. So your also saying that I should get a ECU first, then the headers, then turbo?
Old 06-07-2003, 10:50 PM   #4
Brady
Member#: 14838
197 Iggpoints
you don't HAVE to get new headers and exhaust. it's a good idea though. and you won't find a "bolt on" turbo for your car. it just isn't that easy. you'll likely need a custom up-pipe and down-pipe, you'll likely need new fuel rails, possibly a new fuel pump (depends on how much power you'll need.
but to more directly answer your question, if you get aftermarket management, especially standalone, you would be better off to work on engine management first.
remember the motto: your first step in modifying is making sure everything works perfectly first, then add one thing at a time.
this is why you want to do engine management first. get everything working perfectly before you add too many variables. then try the headers/exhaust. then the final step.
Possible to get STi ECU to pick up non-avcs cam signal? LeeC Engine Management & Tuning 1 07-07-2008 10:10 AM
Is it possible to get a 2008 Toyota Highlander Hybrid for close to invoice? Matt A Off-Topic 12 07-02-2008 03:08 PM
Cheap Place to get a hitch before the weekend? Audipwr1 New England Impreza Club Forum -- NESIC 3 05-31-2006 11:02 PM
Is it possible to get an Opel Speedster imported to the U.S.? FunkerVogt Off-Topic 16 07-31-2005 09:42 AM
is it possible to get the WRX letters on to the IC? Carbon888 Interior & Exterior Modification 41 04-05-2005 02:07 PM
