Welcome to the North American Subaru Impreza Owners Club Saturday April 19, 2014
Old 06-07-2003, 07:45 PM   #1
AutoSpeedWRX
Member#: 15334
2002 Wrx Sedan
11.????
Thumbs down M2 Uppipe
Just installed and M2 up-pipe in a customers car today and i have to say oh my god how are you guys buying this crap?
first off it required that you remove the studs from the stock up-pipe which are self locking once they are in the stock one so it a pita to remove them. next i has an egt bung that does not work with the stock one and comes with no plug for the hole. so i welded a plate over it. next the up-pipe flange to the turbo is just made way off and the studs dont slide in like they should it pretty much needs to be beaten in. and last to top it off since there is no flex and the pipe isnt made to correct measurements the up-pipe leaked. needless to say the customer is now goin to buy ours and sell this usesless pipe to some other sucker that will choose the $100 pipe over the $300 pipe and will regret it in the end.
Yeah i know i may be biased because i work for autospeed but after haveing installed about 20 of Autospeed's up-pipes that fit flawlessly and have NEVER leaked it just amazes me how people are even buying this crap. In the last two weeks i have seen the m2 and 2 different hks pipes all had very simmilar fitment issues but the 2 hks pipes did seal ok which was ok.
sorrry just had to vent
AutoSpeedWRX is offline   Reply With Quote
Old 06-10-2003, 04:00 PM   #2
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Default Re: M2 Uppipe
I have done 156 uppipes so far and the M2's suck... Will never do one again.
Eric
WRBLUEWAGON is offline   Reply With Quote
Old 06-10-2003, 05:24 PM   #3
tiltrite
Member#: 36493
2002 wrx wagon
white
I'm looking for an uppipe. I've done some research and it seems that not all aftermarket uppipes have the same diameter as the stock td04 turbo. In your experience, which uppipes share the same or closest diameter to the tdo4? It seems that there would be less turbulence that way.
thanks,
TILT
tiltrite is offline   Reply With Quote
Old 06-11-2003, 10:58 AM   #4
Mark@AutoSpeed
Member#: 23720
2000 F150
Talking
Tiltrite,
Our up-pipe utilizes 2.000" OD 304 stainless tubing. The ID is 1.875". The TD04 has an inlet diameter of 1.800" that means there is a 1/32" lip from being perfectly port matched. This lip is very small and barely detectable to the untrained eye.
For curiousity sake when we were developing our pipes we had "Port-Matched" several turbine inlets by removing the hot housing and using a carbide die grinding bit and chamfered the inlet edge to smooth over the small lip. Honestly I can say that there was no improvement felt on our calibrated butt dynos
But we have never done a back to back comparison on a dynojet to see if there were any measurable gains. I am not saying you shouldn't try and squeeze every last once of power, but I do think it will be marginal given the type of casting on the TD04.
Bottom line if you look at what we are trying to accomplish, you will find that the majority of new found power is coming from the removal of the precat and the smoothness of the piping design when compared to the OEM power robber.
If you need any more info please do not hesitate to contact us at 856.207.5941
Mark
Mark@AutoSpeed is offline   Reply With Quote
Old 06-19-2003, 05:37 AM   #5
relayer66
Member Sales Rating: (1)
Member#: 14614
Platinum Silver
I put an M2 uppipe in my car over a year ago. It came with studs, and had a plug for the tuning bung. It fit perfectly and there were no leaks after the install. I have never had a problem with this uppipe. Maybe I got one of the good ones.
relayer66 is offline   Reply With Quote
Old 04-02-2004, 04:35 PM   #6
SQC 155
Member#: 52622
2002 WRX stage IV...
Silver and now wrecked :(
same hear, man!! No issues.
SQC 155 is offline   Reply With Quote
Old 09-20-2004, 12:21 AM   #7
rich22
Member#: 34662
2004 WRX Wagon
How are the HKS uppipes?
rich22 is offline   Reply With Quote
Old 06-15-2005, 01:04 AM   #8
eyehate
Member Sales Rating: (10)
Member#: 10223
i got a good one too! just had to find something to plug that hole.... i heat wrapped it as well. 2 years, no problems!
eyehate is offline   Reply With Quote
Old 06-15-2005, 03:46 AM   #9
hpracingwrx
Gone... But not forgotten
Member#: 16772
2003 R6
i miss my rex....
im sorry but M2 uppipes suck at life, although ive only put in a handful of uppipes, the M2 has been the biggest nightmare.
i hate it and hope it gets aids..........
hpracingwrx is offline   Reply With Quote
M2 uppipe and greddy EGT gauge? mattdesmond.com Factory 2.0L Turbo Powertrain 29 04-18-2002 11:23 PM
M2 uppipe opinions or info please! Tinman Factory 2.0L Turbo Powertrain 20 12-29-2001 11:42 PM
M2 uppipe - who has it? SPeeDSiN Factory 2.0L Turbo Powertrain 10 12-12-2001 01:49 AM
My M2 Uppipe Problems (Rant - Help now!!) djerickd Factory 2.0L Turbo Powertrain 9 12-09-2001 09:58 PM
FYI, Just got a M2 uppipe, Very nice WRBLUEWAGON Factory 2.0L Turbo Powertrain 0 11-05-2001 05:06 PM
