Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-08-2003, 08:00 PM   #1
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Question How to mount Driving lights above bumper
I am thinking about picking up a pair of Hella 500s and mounting them from the grill or bumper of my legacy. I know that richeich has done this, and I like how his turned out, but I'm looking for details on how to install them. If it's possible I would like them to be removeable.
I'm thinking that it would be possible to cut out the inner portion of the grill and make a support coming from underneath the grill. Has anybody tried this?
ws6fiero is offline   Reply With Quote
Old 06-09-2003, 04:39 PM   #2
richeich
Member#: 1353
2001 Impreza 2.5RS
I think Jamie (subiegal) had a bar rigged up like that. Check with her, or maybe her website. Maybe she's still got her Legacy section up with a bunch of info on her car (before it was totaled). www.subiegal.com I think it is.
Good Luck-
Rich
Oh- you know, I assumed that you know how I've got mine mounted.... Do you? They're not removable (quickly, anyway). In a nutshell, I removed the bumper cover, drilled holes through the cover and some metal reinforcement bars, or 'plates', that I installed under the skin to add sturdiness to the setup. That's pretty much it. They do shake a bit over rough road surfaces, but not too bad. If I ever removed them, I'd just have to use a couple of body plugs or something painted to match the bumper.
richeich is offline   Reply With Quote
Old 06-09-2003, 05:24 PM   #3
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Actually I really wasn't sure how you did it, but I was thinking along the lines of what you just said. Did you have to remove the bumper to add reinforcement?
Thanks for the help!
Old 06-09-2003, 06:11 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Why not mount them directly in front of the bumper?
Old 06-09-2003, 06:44 PM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Subie Gal was selling them at one point. from what she told me there were just a zig-zag type set up. just some metal sections welded together and bolted to the front of the car.
subiekid is offline   Reply With Quote
Old 06-09-2003, 09:07 PM   #6
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Hmmmm... I looked but can't find them on her site. I may have to ask her about it.
ciper - I'm trying to locate them as high as possible. I would probably mount them in the stock fog location for simplicity/aesthetics, but I am more interested in functionality.
If I get a set and make my own mounts, I will be sure to post pictures and instructions.
Old 06-09-2003, 09:17 PM   #7
subiekid
Member#: 25516
i think these are what she had, or these might be grill suport.
damn she had an awsome car.
Old 06-09-2003, 09:52 PM   #8
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Yeah she did
I browsed through the pictures but all I saw was two horns on that one... glad you pointed it out. I think that is essentially what I will make
Old 06-10-2003, 01:04 PM   #9
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
that design was okay at best guys...
it was cheap and easy, but the lights bounced like strobes
on the RS i went the route of a "U" shaped bracket
1/4" aluminum...
fit over the front of the bumper face,
then was bolted through with large bolt/spacer/nut combo
and tightened down from the top...
front of light bar was drilled to hold 2-4 lights (up to you)
end result was much much more stable:
tough install though! be warned!
you have to drill through the back bit of the bumper beam/support ... not easy but worked well...
please, feel free to ask questions guys.
i dont mind helping out at all... still miss my GT...
RIP
have fun
Jamie - www.subiegal.com
Old 06-10-2003, 03:32 PM   #10
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Hmmmm... I do like the way you wrapped it around the bumper on your RS. Time to go look at my car again
edit - after looking at the car, it will have to be a bigger "U" than yours, but it looks like a good way to do it. Thanks for the help!
Old 06-10-2003, 03:42 PM   #11
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
These work:
They've been on there for a year now with no tightening required. The aim is a little off, but that's my fault for installing them during the day.
remarcable is offline   Reply With Quote
Old 06-12-2003, 06:28 PM   #12
dscottf
Member#: 3312
1999 Outback Wagon
Sapphire Blue
Lightbulb these work too...
Hella 500's even
no bouncing - rock solid
don't come out of align
removable (with a wrench, plugs inside)
cheep!
it's a piece of 1.25" angle iron, hammered over to be slightly less than 90 dgrees (hellas don't tip back past 90 degrees), ground out a curve to conform to the bumper (cover) under the grill. Drilled down though the bumper as far forward as possible (given the shape of the inside of the bumper - measure it carefully). bolted to the bumper with two 5 inch bolts, nuts on other end (blind wrenching). Wire into high beams only!
I have since switched to clear covers, so I don't have to stop and take them off
oh yeah, spray painted black
details:
dscottf is offline   Reply With Quote
Old 06-13-2003, 02:22 AM   #13
scubaracer
Member#: 4909
1992 legacy 2.2Turbo
silver sports sedan
Why should you only wire in the high beams? can't i just run them off a independent switch to turn on/off anytime i want.??
scubaracer is offline   Reply With Quote
Old 06-13-2003, 08:49 AM   #14
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
From what I hear, when you mount the lights in that location and aim them properly you will blind everything in your path. So it makes sense to only have them on with the high beams, and it's more convenient than an extra switch
At least, I think that's why he said that.
Old 06-13-2003, 06:25 PM   #15
dscottf
Member#: 3312
1999 Outback Wagon
Sapphire Blue
Default high beams because...
To be legal you have to hook them up to run only when the high-beams are on, or rather, so they can't run when the high beams are off (and so you have a dashboard indicator that you are blinding someone )
I have a separate switch that allows them to be turned off when the high beams are still on, and they run trough their own relays.
Yes they do, and kill small animals and strip paint but the real point is, you can see everything in your path
since they are so rude to point at people, you want a quick, habitualy trained way to turn them off ( and they kick b_tt for "flash - to - pass )
Old 06-14-2003, 04:25 PM   #16
remarcable
Member#: 2362
1999 Legacy Outback
I wasn't aware it wasn't legal to have them hooked up independent of the factory lighting system.
Oops.
Old 07-12-2003, 04:42 PM   #17
GreenGiant
Member#: 19991
2014 Outback
Twilight Blue Metallic
Question
Hey Subie Gal,
Are there any pics of this bracket off the car or better yet any design drawings?? I want to make something similar for my 2000 Legacy Outback so that I will be able to SEE what is down the road at night. ( I live relatively out in the country). Also are there any detailed install pics or instructions around? I dont have alot of downtime available to ponder the innerds of my car on the garage floor.
Thanks in advance,
Tony
GreenGiant is offline   Reply With Quote
Old 07-12-2003, 06:48 PM   #18
kevinsUBARU
Member#: 2263
2012 Impreza Sport
http://members.nasioc.com/ViewMember...52&PicNumber=4
flip between the pictures
Everything in those pictures can be bought from home depot. I now also use zip ties to secure the light so the mounting point doesnt turn on me. Been working like a charm for over a year now
Kevin
kevinsUBARU is offline   Reply With Quote
Old 07-13-2003, 03:55 PM   #19
GreenGiant
Member#: 19991
2014 Outback
Thumbs up
Thanks Kevin, I might try something like that on mine as soon as I get a JOB and have some play money. I havent looked at the pictures real closely yet but how did you attach the angle iron to the bumper? Did you attach it to the metal support or just to the bumper material?
Thanks again,
Tony
Old 07-13-2003, 05:54 PM   #20
kevinsUBARU
Member#: 2263
2012 Impreza Sport
There was no drilling involved. The grill in a sense acts as the meat in a sandwhich....there are two pieces of that angle steel that act as the bread. One "L" piece of steel slides between the bumper skin and the bumper beam. Do this on each side. Reinstall the grill, and then slide another another piece of the steel between the grill and the top of the bumper skin.
I think the rest should be pretty straight forward by the photos Good luck with it!
08 Impreza - How to replace fog light bulbs? Where to mount ballasts? Azxster Electrical & Lighting 1 09-24-2008 03:47 AM
Help the Linux noob...how to mount logical drive -=C=- Off-Topic 8 08-02-2007 06:11 PM
Want to mount sat radio above rearview mirror CletusTheDwarf Interior & Exterior Modification 1 02-22-2006 10:19 PM
How to wire driving lights and keep DRLs? ATB Electrical & Lighting 7 12-31-2003 06:34 PM
How to wire driving lights into foglight switch? SonicWRX Electrical & Lighting 13 02-18-2003 02:52 PM
