Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 02-10-2001, 09:06 PM   #1
KEVINL
Member#: 3525
2004 Duramax W/500HP
And Want another STi
Post SVX is alive
Aaron's dead SVX is now mine and no longer dead. It runs so awesome the tranny is perfect the engine is even better. other than a major exhaust leak broken window switch and squeaky belts it's perfect. I went through Burger King drive through today and I hear this girl say something about my car I look back over and there is four employees drooling over my car. When I look at it I can't believe its mine.
[This message has been edited by KEVINL (edited February 10, 2001).]
KEVINL is offline
Old 02-10-2001, 10:16 PM   #2
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
I am glad you got it working well. I wish I had the time and energy to invest into that car, but my RS-T is my project for now.
Broken window switch and exhaust leak?
Aaron
AaronB is offline
Old 02-10-2001, 10:57 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
And hey, if things work out, then we can race 2 SVX-T's against each other.
kastle is offline
Old 02-10-2001, 11:23 PM   #4
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
Why bother when you will both be looking at my tail lights.
The AZ smack talk is overtaking the other forums now.
Aaron
AaronB is offline
Old 02-11-2001, 05:48 PM   #5
arejay
Member#: 1916
Cool
Kevin, get used to spending a lot of time staring at your car. I've had mine over a year now. I will still sit on the front porch and just stare . . . up and down. My daughter thinks I'm posessed by some "Christine -like" spirit or something . Congrats!
arejay is offline
Old 02-11-2001, 10:09 PM   #6
KEVINL
Member#: 3525
Post
The exhaust leak is my fault we were pulling it into the garage and I forgot the exhaust mounts were no longer holding it up so it hit the concrete which broke the exhaust donut which seals the front and rear half of the exhaust. the driver window switch has to be wiggled back and fourth to get the window up.
KEVINL is offline
Old 02-12-2001, 01:23 PM   #7
arejay
Member#: 1916
Post
Kevin, is this the driver's window, or other. If it's the driver's window, you may have to buy a whole new switch bank. If it's "other," you may get by with just cleaning the contacts. If you decide to take the switch apart, be careful. There are lots o' small parts that could fall out. The driver's window switch usually fails due to a broken plastic "enclosure" that holds the "guts" of the button together. If you decide to order a new one, you can get the '92 switch that has express up and down for around a hundred bucks at subaruparts.com, or, if express up isn't important to you (they removed that feature in later models), you can order one with just express down for around 75.00.
arejay is offline
Old 02-12-2001, 02:34 PM   #8
KEVINL
Member#: 3525
Post
Thanks for the info I will live with it for a while when I finally get tired of it i will break lose for the Auto up one. By the way the auto up feature doesn't work either I Hope thats the switch also
KEVINL is offline
Old 02-12-2001, 03:33 PM   #9
immortal_suby
Member#: 1711
140 rogue points!
2013 GBS BRZ Limited 6MT
Post
"I'm posessed by some "Christine -like" spirit or something "
And I thought I was the only one who saw that movie!
immortal_suby is offline
Old 02-13-2001, 08:56 AM   #10
arejay
Member#: 1916
Post
"By the way the auto up feature doesn't work either I Hope thats the switch also."
Yes, that would be the switch. The driver's switch has an appendage that extends deep into a slot that activates the electronics. Normally you'd pull up (or push down) slightly on the switch to roll the window up or down. Pull (or push) til it clicks and you get the express feature. Sounds like you have the same problem I had: broken switch housing. If I'd caught it in the earlier stages (with only a crack), an epoxy job would've done the trick, but, when I took the switchbank apart, pieces of plastic fell out. I tried epoxying them back together with sad results. Oh well . . . it's only credit
arejay is offline
HTML code is On
My book is alive... what is it??? rallyedan Off-Topic 21 04-17-2008 05:59 AM
Frankenstein is alive...alive... TaiChih Mid Atlantic Impreza Club -- MAIC 19 07-24-2002 09:32 AM
Customer Service is ALIVE! Thanks again Luke ScoobyWho Brakes, Steering & Suspension 3 03-08-2002 03:12 PM
RalliSpec is alive! RalliSpec General Community 44 01-09-2002 11:56 AM
My RS is ALIVE! Travis R Texas Impreza Club Forum -- TXIC 2 01-23-2001 05:26 PM
