Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 06-08-2003, 11:05 PM   #1
Avenger
Member#: 1234
Default Voltage Clamp
I remember there was a post about voltage clamp for the map sensor for MY00 RS but it been more than a year and it won't let me search later than a year. But I recall it being about 4.8 volt is this right or is it lower?
Avenger is offline   Reply With Quote
Old 06-08-2003, 11:49 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Very first option on the drop down for date is "any date"
kastle is offline   Reply With Quote
Old 06-09-2003, 02:53 PM   #3
Rick Hunter
Member#: 825
2002 wrx
It was 4.7 volts on my car (2000 RS). 4.8V triggered fuel cut. I used a 400 mw 5.1 Volt zener diode. Cause the impedance is so low, a higher voltage zener can be used. I ended up clamping with that 5.1 zener at 4.72 volts.
Rick Hunter is offline   Reply With Quote
voltage clamp spgavin Normally Aspirated Powertrain 0 10-04-2001 12:51 AM
Proper voltage clamp? SubaFastR Normally Aspirated with bolt-on Forced Induction Powertrain 3 09-02-2001 04:40 PM
Check valve vs voltage clamp? wcbjr Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-28-2001 01:54 PM
voltage clamp, or check valve??? LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 15 08-24-2001 10:50 PM
Voltage clamp for MAP fix? NOT! JC SPORTS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2001 08:23 PM
