Old 06-09-2003, 09:37 AM   #1
warlock
Member Sales Rating: (2)
Member#: 27251
02 WRX
Sedona Red
Default Helix UP, Endlinks Cusco sway
Well, I just finished up a grueling install this sunday and here is what I have to say about the parts I installed.
Helix Up-Pipe
It looks pretty good, the flanges are thick, and the nut spacing is good. It was a seamless fit once We got it on the car. It also comes with gaskets, which is nice.
The only problem with this part, is that the EGT bung that was welded to it it, had flashing left on the inside. Thank god I was carefull enough to look. It might have never come off, but what if it did? Im going to make sure gruppe-s knows about this.
The car is a very different experience after this install. The turbo spools faster, I get boost sooner, and it genrally improves the driveability of the car.
Helix Endlinks.
These are adonized purple, just like the pictures on gruppe-s's site. They seem to be constructed very well, and were a breeze to install.
Cusco Adjustable Rear Sway
This is a nice part. All and all a major improvement over factory, so Much so, that I could tell under normal driving conditions. My only complaint with this part is it comes with instructions in what I assume is Japaneese.
I will post more after I go to an Auto-x and see how everything has changed.
warlock is offline   Reply With Quote
Old 06-16-2003, 09:55 PM   #2
Thumper23
Member Sales Rating: (1)
Member#: 11571
Are you getting any sort of noise coming from the sway bar and endlinks? I installed my whiteline bar with the helix endlinks and got some clunking. I went back under the car and rear-greased everything and the sounds went away. Its back now but nowhere near as bad as it was.
Thumper23 is offline   Reply With Quote
Old 06-18-2003, 02:48 PM   #3
jsmonet
Member#: 14190
2005 STi
white
Default Re: Helix UP, Endlinks Cusco sway
just be glad sway bars are cake to install
jsmonet is offline   Reply With Quote
Old 09-11-2003, 03:21 PM   #4
warlock
Member#: 27251
02 WRX
Sedona Red
yes, I get some clunking, but I have just lived with it, it isnt real bad, but I am thinking on a way of quieting this. Im not sure how yet, but I will think of something :P
Old 09-11-2003, 03:23 PM   #5
warlock
Member#: 27251
02 WRX
Sedona Red
Update:
Everything is working well. I had to move the swaybar in to the stiffest setting for some performance, but all in all, its good. The up pipe is still solid no leaks, the only real problem I have with it is My own fault, I should have heat wrapped it, My under hood temps have went up even more. I will get under there some day and wrap the thing, but not anytime soon.
Old 09-28-2003, 04:48 AM   #6
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
Warlock I just got my helix up pipe and am planning on installing it probably next weekend. Thanks for recommending it the quality is top notch.
speed_freak27 is offline   Reply With Quote
Old 09-28-2003, 09:38 PM   #7
Mogoloid gugoff
Member#: 37362
Default Install
Just curious, did you just remove the turbo to do the install or did you jack the car and do it a la Perrin's instructions? I have a Helix Up going in as well as soon as break-in is over.
Mogoloid gugoff is offline   Reply With Quote
FS: Cusco rear swaybar, Helix rear endlinks DFW. CHEAP for a week!! subUrbanAuthority TXIC Private Classifieds 14 10-27-2009 09:47 PM
Red 4 Pots, Helix Rear Endlinks, NRG H Brace, Cusco Front Sway Bar, OEM Rear Top Hats hoshot Suspension/Brakes/Handling 9 05-26-2009 02:04 AM
Kartboy Endlinks & Cusco Sway Bar Combo|Tein & Cusco Coilovers|Cobb & Perrin Sways! Spun Autosports Suspension/Brakes/Handling 46 11-13-2007 01:34 PM
Help with Helix endlink and Sway install WiredWRX Brakes, Steering & Suspension 5 06-18-2004 10:16 PM
cusco adjustable rear sway bar, helix rear endlinks, carbon fiber sidemarker covers BooStedScooby Private 'For Sale' Classifieds 9 08-14-2003 09:26 PM
