Old 06-09-2003, 11:01 AM   #1
Snoopy
Member#: 700
99 Impreza RS
Silverthorn Metallic
Default My 99 RS needs new suspensions. Need your suggestion.
Now that it's been nearly 4 years since I bought the car, the ride is soft like a big car. Body rolls are more exagerated and the car squats under acceleration. Bleh! I hate it but my fiance likes it.
What's a good not too expensive but better than stock suspension set up? BTW...is it my springs that are soft or shocks or both? I think my shocks are okay coz the car doesn't continue bouncing after a big bump but I could be wrong. Isn't that what shocks do : Keep the car from bouncing and bouncing after a bump?
Snoopy is offline   Reply With Quote
Old 06-09-2003, 11:37 AM   #2
Stickee
Member#: 530
2005 9-2x Aero
FastAr Red
I just installed the KYB/AGX and Eibach Pro-kit on my MY99 OBS. Ride is great. If you set the struts at 1f/3r, it feels just like stock (my girlfriend didn't even notice). However, if you need to bump up the damping/rebound for Auto-X or track days, you can adjust in less than 2 minutes.
With regards to prices, but Subie Gal and others have suggested www.p-s-t.com for a good place to get the struts.
Alot of people have this setup, if you search on "kyb" or "eibach" in the suspension forum or technical archive forums, there is alot of info...
Hope this helps...
Stickee is offline   Reply With Quote
Old 06-09-2003, 12:19 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yup i agree
gruppe-s also has good pricing ... and you can get both at the same time
Old 06-09-2003, 01:18 PM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
It's likely your struts that are worn. Springs sag more with age but don't go soft usually. Your bushings all over the car are getting worn and loose with age as well.
You should set a budget for this upgrade. That will dicate how good a set up you can get. I agree that the AGX/Eibach pro is a great set-up. However , if you don't autox or track a KYB GR2/Eibach or just the GR2's would do.
linsavy is offline   Reply With Quote
Old 06-09-2003, 04:03 PM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
I believe it was Midas that has been advertising Buy 1 get the 2nd at half price for KYB struts. You might see if they'll sell the struts and let you figure out the install on your own.
CosmoTheCat is offline   Reply With Quote
Old 06-09-2003, 11:54 PM   #6
Boxologist
Member#: 21118
getting the struts is the easy part, getting them on is tuff
Snoopy, what other handling mods have u done, if we may inquire?
Boxologist is online now   Reply With Quote
Old 06-10-2003, 04:06 AM   #7
CosmoTheCat
Member#: 3409
98 My FMIC
PS. You should have upgraded when I got my stuff...
Ver. 5 stuts (red 40mm things)
SPT/Eibach springs (blue)
STi top mounts
I think my out-of-pocket was considerably less than $300, but I had a fistful of MBNA coupons from my Subaru card.
The ride is very firm. But I like it. It's really connected to the road. Sometimes I feel like it's too bouncy, but that might be the stock seat or just my pudge.
Old 06-10-2003, 08:43 AM   #8
Snoopy
Member#: 700
99 Impreza RS
All I have is the 20mm rear sway bar. I was gonna keep the car as stock as possible until the WRX arrived but the car wasn't quite to my liking so I'll have to settle for the STi in a couple of years.
Old 06-10-2003, 08:44 AM   #9
Snoopy
Member#: 700
99 Impreza RS
STi top mounts
Should I go for the Midas offer of the setup you just suggested?
STi top mounts
Old 06-10-2003, 12:38 PM   #10
Boxologist
Member#: 21118
obviously u should trytoridein asmany differentcars with different setups to get an idea of what u want.
since u have the rear sway bar, check the rear links tosee how worn they are. those should run u less than 150 new if u install them urself(not a biggie if u did the bar), tops.
a lot of people use the agx/eibachs, but i am consider a v5/6 spring/strut setup.
perhapsthe whiteline springs are what u want. tons of options for u.
Old 06-10-2003, 01:25 PM   #11
gypsymoth
Member#: 6072
01 Silver 2.5 RS
04 Silver WRX STi
It's probably due your suspension is too stiff for the surface you happen to be on.
Bumpy surface . . . softer setup. Smooth hard surface . . . stiffer setup
Chieh
Chieh's Web - http://Chieh.CameraHacker.com/
gypsymoth is offline   Reply With Quote
Old 06-10-2003, 02:22 PM   #12
CosmoTheCat
Member#: 3409
98 My FMIC
But you can't have it both ways for the amount I paid.
The midas comment was a tad on the facetious side, I don't know if they would even sell a performance strut.
I got those V5 struts for $75 a piece new when they were mis-priced on Subaruparts.com. When I replace them I'll probably go with the AGX's.
Old 06-10-2003, 07:36 PM   #13
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Check the "Group Buys"; IIRC you could get the parts for ~$700 (KYB/AGX+Eibach Pro Springs)but I searched a bit also. The install info can be found at www.scoobymods.com
joubtt is offline   Reply With Quote
Old 06-12-2003, 11:37 PM   #14
Siper2
Member#: 1134
2007 BMW 328xi wagon
Yep I got my V5 struts for about $200 from Exeter Subaru in mid-late 2001. Here's to mis-pricing!
I think my next setup will be the STi Tarmacs from Rallispec. Mmmmm.
Although, I still need the GpN strut tops!
-S2-
Siper2 is offline   Reply With Quote
Old 06-13-2003, 01:47 AM   #15
StormCrow
Member#: 33572
2001 2.5RS Coupe
Silverthorn
I just put in a set of KYB AGXs and Prodrive P1 springs about two weeks ago and am very happy with them.
When it's set at 3f6r it's stiff like my vette. At 2/4 it's stiff enough from stock (new, I suppose in your case ) that you can feel the bumps without having all your vertabrae readjusted.
Installing them wasn't bad. I installed them with the help of Smash0r (also on here) and another friend. It took us a total of 9hrs, but that includes three stubborn bolts and a bazillion tool runs.
Tuesday, we installed a similar setup on Smash0r's 03 WRX and did it start to finish, with just the two of us, in 2 hrs.
Pricewise, it ended up costing me about $960 for the struts, springs and STi strut mounts (front and rear). You'll want to look into the strut mounts because the stock ones apparently get worn out fast with this setup.
I went with the Pros because I wanted a linear spring and the difference in price was about $80 or $90 (after shipping) so it seemed worth it to me.
Anyway, that's probably more info than you wanted to know.
StormCrow is offline   Reply With Quote
my 99 rs suspension jdmsuby 1993 - 2001 Impreza Specific Parts 8 12-06-2007 08:36 PM
my new rims on my 99 RS golfs2good Member's Car Gallery 12 03-20-2004 09:14 AM
Am I going to need Timing Control on my 99 rs-t Bobalouy Normally Aspirated with bolt-on Forced Induction Powertrain 14 03-12-2004 11:30 AM
looking to upgrade my suspension on my 99 RS ILUVMY2.5RS Brakes, Steering & Suspension 2 06-18-2002 07:53 AM
Need new clutch badly any suggestions? BlueScooby New England Impreza Club Forum -- NESIC 7 02-23-2001 12:44 AM
