Old 06-09-2003, 11:40 PM   #1
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
2002 Dragon slayer :)
Default RS-T problems...
As some of you might have read in my other posts, i put a 2002 EJ25 working block back in the car with the decked heads (were overheated 4 thousands and were decked 5 thousands) of my overheated engine. Coolant still found its way in the engine. I did NOT see any traces of coolant in the cylinder walls/chambers as I took the head off of the engine. I could not, for the life of me, figure out what is wrong. The head, or the gasket. Here are the pics. You call what's wrong.
This is the << LEFT >> head, not as I stated in the picture.
This is the << RIGHT >> head.
Thanks for your help guys. By the way, i had the engine off the car in 20 min. without power tools.
~Anthony.
WRX 555 STi is offline   Reply With Quote
Old 06-10-2003, 12:53 AM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Do you have pictures of the block and headgaskets?
wac is offline   Reply With Quote
Old 06-10-2003, 08:37 AM   #3
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
Yes I do. I will post them as soon as I can.
~Anthony.
Old 06-10-2003, 11:57 AM   #4
Avenger
Member#: 1234
Did they check the head for crack?
Avenger is offline   Reply With Quote
Old 06-10-2003, 12:20 PM   #5
N/A
Member#: 133
TBA TBA
TBA
Possibly could have cracked something. That or the thing is just warped and not going to seal correctly.
N/A is offline   Reply With Quote
Old 06-10-2003, 08:07 PM   #6
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
So, here's my 2 situations:
a. Buy new heads (~$800?)
b. Buy an EJ25 engine with 11k miles on it, but it was head-on crashed and has broken a timing cover. I will have to go and look at it if it is safe to put on the car. They tested the compression and everything is good. $800
Which of the two?
~Anthony.
Old 06-10-2003, 08:16 PM   #7
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
I found a set of heads for $190 each (L & R), so figure what, 500 with shipping? What you guys think?
~Anthony.
Old 06-10-2003, 08:26 PM   #8
N/A
Member#: 133
TBA TBA
TBA
I take it then there are no visible cracks even very small ones? I only paid $600 for my entire spare motor so $190 a side still sounds expensive.
Old 06-11-2003, 03:35 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
the heads were decked .005" and pressure tested, i was skeptical because of a heat mark in the head, well that heat mark seems to have expanded when the heads were torqued down and then heated up. unfortunately this is just something that can go wrong when you severely overheat a block.
Outside temp (heat) and RS-T problems? Ethan Normally Aspirated with bolt-on Forced Induction Powertrain 3 06-08-2003 04:07 AM
RS-T problem WRX 555 STi Normally Aspirated with bolt-on Forced Induction Powertrain 29 06-08-2003 12:00 AM
Impreza RS drivetrain problem 98Impreza2.5RS Transmission (AT/MT) & Driveline 7 11-12-2002 01:58 AM
Funky RS clutch problem? JCsRS Transmission (AT/MT) & Driveline 0 03-18-2002 01:25 AM
