Old 06-10-2003, 11:44 AM   #1
byan
Member#: 38105
2000 Legacy
Green
Unhappy Please help! Headlights go On and Off...
Hi,
I have a Subaru sedan, the model is Year 2000 Legacy L. It has been great and I am quite satisfied with it for over two years. But recently a strange problem happens now and then.
While I was driving, the headlights (both side) could suddenly go off for no reason, after a random time, could be half an hour or an hour, the lights come back on by themselves. I called a Subaru dealer, also went to a garage, to see if they could check things out. They told me it could be wire problems. but nothing they can do while the car works fine.
I am quite frustrated (the lights came back five minutes before I arrived the garage), I don't know what I should do. Any ideas? Anyone encountered such problem before? Please give me some advices. Thanks in advance.
byan
byan is offline   Reply With Quote
Old 06-10-2003, 12:01 PM   #2
MannySoobia
Member#: 22139
2008 FXT Sport
Gee-Are-Pee
Question what Kinda bulbs you using???..........
If your Using the--So called "HID" bulbs, there's a good chance that the high voltage could've melted/shorted your headlight wiring. The reason I say is because this happened to me, I was using the BLUE bulbs and then a month or so later, for no apparent reason my lights would stop working (for a minute to a day) and then just go back on. Well, Hope I could help .
-- Manny
MannySoobia is offline   Reply With Quote
Old 06-10-2003, 12:35 PM   #3
byan
Member#: 38105
2000 Legacy
Green
Thanks for the quick response.
I still have the regular OEM bulbs, the ones came with the car. Not sure if it is the same problem as yours. I am thinking that maybe I should take one day off, drive around the dealer. Whenever it happens, I could have them to look at it. No sure it is going to work though. :-(
Just curious, how did you fix the ON/OFF headlights problem?
Old 06-10-2003, 03:22 PM   #4
MannySoobia
Member#: 22139
2008 FXT Sport
Gee-Are-Pee
I just had the dealer replace the wiring, Although, if you are ever interested in using high wattage bulbs you might look into a HighGuageWire set. Apex has one for about 60 bucks, and I found it's about 60 to install it. It'll increase the current so the bulbs shine nice and bright.
-- Manny
CEL blinking engine runs rough fans go on and off please help tofastforyou2 Service & Maintenance 9 01-26-2006 10:07 PM
Headlights coming on and off intermittently snow111 Electrical & Lighting 6 12-14-2004 01:38 AM
Headlights go on and off byan Electrical & Lighting 4 06-18-2003 02:17 AM
Parking Brake light keeps going on and off? SpamMansXe Mid Atlantic Impreza Club -- MAIC 16 04-01-2003 12:29 PM
Noise under dash with power going on and off Tangmere Service & Maintenance 1 06-06-2002 04:07 PM
