Old 06-10-2003, 07:23 PM   #1
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
Default how much boost
how much boost can i run? i have a 2001 RS with stock engine and 8.5:1 forged pistons RRFPR and high flow fuel rails and a walbro fuel pump . All stock WRX turbo parts.
bryan2.5rs is offline   Reply With Quote
Old 06-10-2003, 07:43 PM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
You can run as much as you want. It might blow up though.
It is so much harder than just saying what components you have.
Eric SS is offline   Reply With Quote
Old 06-10-2003, 08:13 PM   #3
Turbo GC4
Member#: 28555
you can run 159.7341 mmhg. that is an exact figure, I used a calculator. Using this formula
[ (8.5:1) X ] = 159.7341
Turbo GC4 is offline   Reply With Quote
Old 06-10-2003, 08:36 PM   #4
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
how many pounds is that, and i don't want to blow it up again, thats why i have the new pistons.
Old 06-10-2003, 08:44 PM   #5
Shinji N
Member#: 3987
1999 Miata
Well it's not a straight conversion. You have to weigh the monkey that he's using, but you'll have to catch him first!
Shinji N is offline   Reply With Quote
Old 06-10-2003, 11:24 PM   #6
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
oh boy.....I am trying to piece together my turbo options and as it is with a stock engine I can go no further than 5psi...I can go further if I want to blow up my engine though
CheezeWeezle is offline   Reply With Quote
Old 06-11-2003, 12:16 AM   #7
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
With the forged pistons you can probably max out the stock WRX turbo. I would say you could do around 14-15 psi on that turbo, but at that point the efficiency of the turbo is maxed beyond belief on the 2.5L motor. I would highly recommend upgrading your turbo. You should look at a VF-22 or a VF-30 IHI turbo, much larger than the WRX turbo, to really see the potential of the new fored pistons.
Did you blow your motor? Only new pistons or rods as well?
Graham
Graham is offline   Reply With Quote
Old 06-11-2003, 10:02 AM   #8
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
i was running 9 pounds on stock internals and blew the rings in cylinder number 4 however the car is still driveable i have been driving it for about a month, but it is getting worse I will be putting in the new pistons next week.
Old 06-12-2003, 01:24 PM   #9
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
bump
Old 06-12-2003, 08:42 PM   #10
spt_impreza
Member#: 3004
which low comp pistons do you have?? thx
spt
spt_impreza is offline   Reply With Quote
Old 06-13-2003, 07:51 PM   #11
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Run 17psi max as thats the limit of the turbine's effieciency...
If you want more power look into upgrading the compressor side and run the same 17psi...
If you want even more power, look into upgrading the whole turbocharger...If it were me, I'll go with a T3/T04e with a .63A/R on the Turbine with a Vtrim Wheel and a .70A/R Compressor with a 60-1 Wheel...
Zee
Sunrise City Rider is offline   Reply With Quote
Old 06-13-2003, 08:02 PM   #12
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
THANX!
Old 06-13-2003, 10:21 PM   #13
kaos200
Member#: 2692
OMFG This made me laugh so bad!
kaos200 is offline   Reply With Quote
Old 06-14-2003, 12:49 PM   #14
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
You're a MF trip, dude!
Kreeger is offline   Reply With Quote
Old 06-17-2003, 11:36 PM   #15
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
It also depends on what you are doing for timing control.
The 8.5:1 pistons may only let you run 10-12 psi with the 2001's ECU and stock timing advance, vs 5-6 psi with the stock pistons and stock timing advance. To run 13-17 psi you may need to retard the timing 4-6 degrees to avaoid detonation. Also, the TD04 is not be big enough to boost those numbers on a 2.5L, I would seriously look at a VF22 or something in that size.
We have a guy up here at 6000 feet with a 8:1 CR 2.2T block and he can only run 15 psi with his stock 1.8L ECU's timing curve and no timing controller, on 93 octane. He has to drop to 13 psi for 91 octane, and we can usually run 2-3 psi more up here than at sea-level. However, I am told the 1.8 ECU has more timing advance than the 2001 ECU.
Larry
www.subaruplanet.com
ImprezaRS dot com is offline   Reply With Quote
Old 06-18-2003, 12:46 PM   #16
ravent
Member#: 500
00/+ RS/OBS
white
What rods are you using??? Remember, the chain is only as strong as the weakest link. What gas are you using? Do you have the "Squirt" from Crawford Perfomance (water injection)? They will be at Pikes Peak next week for PPIHC. Also remember that all it will take is "detonation" once at the right boost to end the life of "any" motor, so the tuning is the most important...not something to experiment with.
Almost forgot, what turbo are you using...this also will be important as to how much boost you can run. The "system" has to be built as a whole, not just some parts you bought ie turbo, pistons, rods, head bolts, gaskets, NOT just some parts someone said were good or were taken off anothers car.
ravent is offline   Reply With Quote
How much boost for how long? bcmaxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-06-2007 12:06 AM
How much boost is TOO MUCH? skimobile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 07-31-2005 07:44 PM
How much boost is to much boost? xtheviperx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-16-2002 09:49 AM
How much boost?? Baluchitherium4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-31-2001 03:48 AM
How much boost and/or hp can the EJ20 in the 2002 WRX take? GTLee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-28-2001 01:44 AM
