Old 06-10-2003, 06:28 PM   #1
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
Default Problems with JDM
ok i may have secured a small batch of 3 or 4 JDM front Clips , V3/4 however im uncertain if ill have em ordered or not , my concern is evryone is worried about replacment parts, and gas, wouldnt the parts be interchangeable with other models ? and gas , i hear Japan runs 95 octane, so will it matter that i personally only have 93 octane around here, ?
cindergarden is offline   Reply With Quote
Old 06-11-2003, 09:15 AM   #2
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Parts are parts. The big difference between the JDM engines and the USDM EJ20s are just the size of the turbos and the state of tune for the ECU (except for STi motors which have forged pistons, different cams, etc.). What parts are your people worried about replacing? Pistons? Who cares if you can source an OEM replacemtent, if you crack a piston replace them with aftermarket ones. Clutches? Again, aftermarket clutches for the USDM EJ20 will work. I really don't see any need for concern about getting replacement parts.
As far as fuel goes, Japan uses 98 and 100 RON fuel. IIRC, 100 RON comes out to about 94 or 95 octane. I have used everything from 94 to 92 octane in my STi Ver. 3 with no noticeable difference. Although, I try to avoid using 92 whenever possible.
- Trent
peepshow is offline   Reply With Quote
Old 06-11-2003, 10:52 AM   #3
Puckaveli
Member#: 1518
00 2.5RS
Parts like hoses, sensors, etc might have to come from Japan, but there probably are a lot of parts that are interchangable between the GC and GD motors to JDM motors. I don't think anyone has sat down and compared the parts manuals between both markets and all years to see what's interchangable; that is the missing link. For instance I need a need timing cover for my DOHC Ver2 motor I would imagine a timing cover from a DOHC 98RS would work, but I won't know until I try it. Rallispec ,from what I've been told, can source oem jdm parts.
Peep is correct about the fuel too.
Puckaveli is offline   Reply With Quote
Old 06-11-2003, 12:04 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
from my expirance alot of parts are "simmilar"
not exactly the same .. like power steering backets .. look similar but the us pump won't fit in a jdm bracket ... however a us bracket will fit on a jdm motor
Any AC problems with JDM swaps 22b-iotch Subaru Conversions 7 08-29-2005 08:00 PM
Problems with JDM fog kit on my STi ewright Interior & Exterior Modification 1 08-02-2005 10:22 PM
problems with jdm hid projector install Benjamin Tang Electrical & Lighting 2 10-23-2003 11:03 AM
Problem with JDM Hids, help!! Cerum Interior & Exterior Modification 1 03-02-2003 03:00 PM
bulb (turn signal) problem with JDM tails wop Interior & Exterior Modification 2 05-11-2001 08:17 AM
