Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-11-2003, 12:51 PM   #1
spriggan
Member#: 14283
2013 wrx
Metallic Silver
Default 99 gt gauge pod
Anyone know a place that sells side pillar mounts for the 99gt
spriggan is offline   Reply With Quote
Old 06-11-2003, 06:03 PM   #2
Sobelizard109
Member#: 10302
2005 GT WAGON
SILVER
I think someone said that the pillar pods from a 01 rs will fit on a legacy. good luick.
Sobelizard109 is offline   Reply With Quote
Old 06-11-2003, 08:48 PM   #3
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Yes It will. I have a picture somewhere. I'll go dig it up.
Steven
pleiades is offline   Reply With Quote
Old 06-11-2003, 08:50 PM   #4
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Found it. (I only have 1 guage right now. )
That is the RS pod. Not a perfect fit, but pretty good. It could stand a little heat gun forming. You can see the little gap through the top hole, but because of the black around the windsheild, you can't see it from outside the car, and obviously, if I had another gauge in there you wouldn't be able to see it from the inside.
Old 06-14-2003, 03:07 PM   #5
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Does it snap on under the window/pillar door/pillar trim or are there actual pins/screws that hold it in place? I've wanted to do this but didn't want to modify the pillar cover to do it.
Thanks,
Dale
Subietonic is offline   Reply With Quote
Old 06-14-2003, 09:45 PM   #6
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Thanks,
Dale
You have to drill four small holes in the pillar.
Old 06-15-2003, 01:41 AM   #7
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
where do the wires run down to after they exit the pillar pod? i decided to make my own custom dash pod for my gauges going for the stealth look, hehe.
Ben
Old 06-15-2003, 02:38 AM   #8
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Ben
stealth, how did you do that?
mine bug me
i would like stealth, but not sure how to do it.
this will tell ya what was said above.
http://forums.nasioc.com/forums/show...ghlight=gauges
subiekid is offline   Reply With Quote
Old 06-15-2003, 05:42 PM   #9
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
From my previos legacy, this is pretty nice and stealthy:
http://www.soundillusions.net/sites/...es/gauges1.jpg
Speedwagon is offline   Reply With Quote
Old 06-15-2003, 08:24 PM   #10
subiekid
Member#: 25516
Old 06-15-2003, 10:14 PM   #11
PHATsuby
Member#: 13617
2001 Legacy GT back
subiekid-those look pretty nice, did you do those?
i put mine in the dash below my cd deck, basically there were 2 empty DIN spots, just some compartments that i took out, then i made a replacement face, the angles the gauges up and toward the driver a little, its a work in progress but once i finish it, which should be in a couple days, i will post some pics.
how did you cut out the gauges holes, is it possible to get a 2 1/16" diameter hole cutter that attaches to a drill or how did you guys cut them out for those of you that did. thanks
Ben
Old 06-16-2003, 12:27 AM   #12
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
After being told that I wasn't authorized access to the Sound Illusions site, I managed to get on Speedwagon's soundillusions.net/sites/speedwagon/ site but couldn't find the gauge or the stealth installation. Did find a Defi Gauges under your modifications but no joy there either as the thumbnails wouldn't load. And that's another question, is there a reason why the thumbs won't load? Whenever I click on the thumbs (that I could see), especially of Okinawa where I've spent lots of time, I get the dreaded HTTP 404 Not Found page.
Br, Dale
Old 06-16-2003, 12:37 AM   #13
subiekid
Member#: 25516
you can get a bit for a 2 and 1/16 hole. it would be hallow in the middle. i used them in wood shop, back in the day. my cluster came with the 3 holes for the gauges. can i see a pic of yours? with my cd player inthe way there is not room down there for the gauges. i also wanted to be able to keep close watch on my boost gauge.
the hardest part is drilling a hole in the fire wall. i ran them through the rubber section that is just left of the brake pedal. i didnt like that so i got my metal drill bits and punches out and after like 2 horus and all the holes cut for my wires and tubes. one thing that helped me was running a very small and hard to bend wire down from the vents to the cd player i then tied the wire to that and pulled them up.
Old 06-16-2003, 12:42 AM   #14
PHATsuby
Member#: 13617
2001 Legacy GT back
yea having it low was a concern but i think it will be fine, i will post some pics once i get closer to finishing, hopefully tomorrow or tuesday i will post some up.
you think Home Depot would have a bit like that? guess i will have to make a few calls. thanks
Ben
Old 06-16-2003, 12:44 AM   #15
subiekid
Member#: 25516
i am hammering my head to remember what they are called. they are hallow in the center and have like teeth on them. ugg. i will find some on the net, give me 15 or 20.
this would do.
ITS SEARS
they are called "hole saws"
http://cgi.ebay.com/ws/eBayISAPI.dll...category=20797
just for a pic not the best place to guy them.
8 bucks at this place
http://www.toolmarts.com/milhole.html
Old 06-16-2003, 01:37 PM   #16
Speedwagon
Member#: 19681
Green
I don't know what's going on.. I've been trying to figure it out though.. always works for me.. only sometimes it works for others... some ppl say if you copy and paste the link it will work.
I think I'm just going to move my site elsewhere..
Old 06-16-2003, 01:51 PM   #17
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
The only way I could access the site was to cut back the URL to just "http://www.soundillusions.net/sites/speedwagon/" and paste that in so that could get to your site page. Otherwise, I just get the "don't have permission to access" page.
Once I was on your site, then I could click on the various parts, including the Defi gauges page. Again, some of the pics would load as thumbs and some wouldn't and then I'd get the square box "x" that shows where a pic should be. Even right-clicking and clicking the "show picture" doesn't load the pic either.
Br, Dale
Old 06-16-2003, 07:10 PM   #18
subiekid
Member#: 25516
i think it was speedwagon who sent this to me. looks bad ass.
are you in the magical land of jdm? if so, can i live with you?
Old 06-16-2003, 07:24 PM   #19
PHATsuby
Member#: 13617
2001 Legacy GT back
that does look cool
thanks, yea they are hole saws, i am frickin pissed though cause the one i bought was like warped or something so it made my holes too big and they werent even round, thats why it threw off my gauges so they arent perfect.
oh well, once it is painted it will look a ton better, but now all i have to do is patch up around the gauge edges and then primer and paint and it should look pretty sweet.
what do you guys think of my BMC designs gauge pod?
Ben
Old 06-16-2003, 08:00 PM   #20
subiekid
Member#: 25516
that is bad ass. how did you make that? did you just use glass resine? i am thinking i will do that, and just leave a single pod with my boost on top.
Old 06-16-2003, 08:08 PM   #21
Speedwagon
Member#: 19681
Green
Yea, that was me. And yes, I was in Japan at the time. I am no longer there.. but those items will be in my 98 Legacy soon enough.
I made that with black plexiglass.. sorry I don't have a daytime shot for ya. But, it was the black/smoked plexi that's opaque.. nice and shiny, and matched the gauges. Just cut 2 holes in it, and L brackets to mount it in above the stereo.
Old 06-16-2003, 09:36 PM   #22
subiekid
Member#: 25516
how is your swap coming along? have you started yet?
Old 06-16-2003, 10:13 PM   #23
Speedwagon
Member#: 19681
Green
No, not yet. I've been broke, and I needs parts first. BUT, I have money now, and I'm starting to collect the parts I need. I technically have everything, but I want new gaskets, water pump, oil pump and such. But I should have that stuff in the next couple of weeks, so probably start the swap early July.
Old 06-17-2003, 01:38 AM   #24
PHATsuby
Member#: 13617
2001 Legacy GT back
subie-yea i basically got the dimensions and thought of the shape i wanted, then made a mold out of cardboard(GHETTO), then i layed a layer of fibergalss cloth over the top, got pretty hard, then did a layer of mat on the backside, and its pretty solid, then did some bondo to get it smooth.
i hooked up the illumination, it looks awesome, the green is great, the needles could be a little more red but its awesome.
Ben
Old 06-17-2003, 01:50 AM   #25
subiekid
Member#: 25516
it looks bad a. i want to see it done by the end of the week
speedwagon: how are you going to get that into a 98? the old school leg had a 2.5 din. the bd has just a 2 din. are you gona get rid of the ash tray? i love your gauges. i just have crudy autometer, but oh well, i dont care too much about my apearance. my interior is beat to heck, if it was new i would care.
FS: Gauge Pod for 99-01 Impreza slamck Private 'For Sale' Classifieds 3 04-02-2004 02:24 PM
BPM GT-Greddy Lip-Replica foglight covers-Vent Gauge Pod WRXnFX Private 'For Sale' Classifieds 16 03-05-2004 02:42 PM
A-pillar gauge pod for 97s GT skydiver Interior & Exterior Modification 3 01-17-2002 05:20 PM
99-01 subaru gauge pods howie General Forum Archive 3 03-02-2001 11:46 AM
