Old 06-11-2003, 02:41 PM   #1
smp291
Member#: 9520
89 weak ass
commuter civic
Default Whats the best sound deadening Material
Im gonna be installing a sub or two and I would like to add the deadening stuff. Plus I want to put it in my doors. So whats the best stuff out there, are there any good websites?
smp291 is offline   Reply With Quote
Old 06-11-2003, 03:16 PM   #2
Daven
Member#: 14650
I know of 2 WRX's locally who have Raammatted.
Raamaudio.com Stuff is quite a bit cheaper than dynamat. Roughy 100ish a roll shipped. doign the outer skins, inner skin and door panel of each door and trunk takes about a roll and a 1/2. I've got my car done with it.
Daven is offline   Reply With Quote
Old 06-11-2003, 03:18 PM   #3
jobs
Member#: 18664
2010 Outback SWPearl
,99 Black Outback sport
jobs is offline   Reply With Quote
Old 06-11-2003, 04:26 PM   #4
elsanto
Member#: 34832
1989 M3
Ive used both cascade and Dynamat extreme.. the cascade was lousy compared to dynamat, bought a "trunk Kit" for my wagon and i got about 1/2 of the job done with the kit.. and crappy quality compared to dynamat. ive heard good stuff about brown bread , Raamat and bquiet also.
elsanto is offline   Reply With Quote
Old 06-11-2003, 05:08 PM   #5
smp291
Member#: 9520
89 weak ass
commuter civic
Cool I will check out all of those. I need it for my truck...
Old 06-11-2003, 07:12 PM   #6
well_armed
Member#: 15204
I disagree, the best stuff so far I have seen is the Cascade audio product. Their kits are not very good, meaning can cover a lot of square footage, but their product is far superior to dynamat. Here's my front drivers side door with full sound dampening done to it:
I used VB-2HD on the outer skin (what you see in the pic) and Vmax on the inner part of the outside sheet metal.
well_armed is offline   Reply With Quote
Old 06-11-2003, 07:15 PM   #7
defduane
Member#: 17718
2006 Forester XT
Dark Blue
Brown Bread is a very good sound deadening material. Similar or better than Dynamat Extreme, but much less expensive.
I think b-quiet.com sells it.
defduane is offline   Reply With Quote
Old 06-11-2003, 11:35 PM   #8
ruiner
Member#: 20784
2002 Impreza WRX
WR Blue
Cascade is great stuff but just as expensive if not more than Dynamat. Another high recommendation from me for Raammat.
Chad
ruiner is offline   Reply With Quote
Old 06-12-2003, 11:31 AM   #9
jerome02rs
Member#: 6347
2002 Impreza 2.5RS
Platinum Silver
If you check out all the audio/ install sites as well as reviews the overall consensus is that Brown Bread is the best there is.
jerome02rs is offline   Reply With Quote
Old 06-12-2003, 06:01 PM   #10
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
As we've just shown in the posts above, there is NO consensus! All the different materials have their own tradeoffs wrt price, thickness, smell, adhesive, etc. Price-conscious people will avoid Dynamat and Cascade for the cheaper products; smell-conscious people will avoid the asphalt-based stuff; thickness-conscious people will go for some of vinyl-based Cascade stuff; it all depends on what your personal tradeoffs are.
Old 06-16-2003, 09:58 AM   #11
smp291
Member#: 9520
89 weak ass
commuter civic
I sure dont want it to stink. Thinkness isnt a problem....I just dont want rattles
Old 06-16-2003, 10:33 AM   #12
jghall00
Member#: 35147
1994 Honda
Have you considered concrete?
jghall00 is offline   Reply With Quote
Old 06-16-2003, 10:42 AM   #13
sonicblue
Member#: 25227
2012 Escape
From b-quiet.com:
Brown Bread, >= $2.30 and about .4 lbs. per sq ft.
Dynamat, >=$5.40 and about .45 lbs. per sq ft.
From rammaudio.com:
Raammat60, =$1.60 and about .45 lbs. per sq ft.
I'm going to do my roof soon, so I'm interested in this. Just my half-cocked analysis, but based on these quick comparisons and given that all three have gotten some positive feedback here, I would take Brown Bread for only a little more than Raammat but less weight.
sonicblue is offline   Reply With Quote
Old 06-16-2003, 12:30 PM   #14
Jakezor
Member#: 9624
2002 ImprezaWRXsedan
Platinum Silver Metallic
Dynamat Extreme (if you can find a good deal on it)
or
Rammaat 60
Jakezor is offline   Reply With Quote
Old 06-18-2003, 07:52 PM   #15
Greg_R
Member#: 25704
2000 Impreza 2.5 RS
Red
I'm wrapping up an install on my '00 RS that uses Raamatt 60 as the dampener. Installation is very easy and a heat gun is not required (assuming the outside temp is warm). If it is cold (< 60 deg) a heat gun will be required. A roller (or something to press the material into shape) is an absolute must. The material does not smell at any time and is very sticky. Be sure to clean the metal surfaces prior to application.
Keep in mind that dampening materials will only stop the metal from vibrating. Exterior noise will still be transmitted. You will want some sound absorbtion material in addition to the dampener. Foam is a cheap absorber. A better solution is layer constrained foam (foam, a thin dense layer, foam, then another thin dense layer). BQuiet makes 2 good products... LComp and VComp.
In my car I used two rolls of LComp and 3 rolls of VComp (along with 2.5 rolls of Raamatt). This is for a full install (detailed below):
- Headliner: 2 layers Raamatt, 1 layer LComp in front and 1 layer of Vcomp in back
- A and B pillars: 2 layers of Raamatt, 1 layer of VComp
- Trunk: 2 layers of Raamatt (some areas 3 layers)
- Floor: 2 layers of Raamatt (some areas 3 layers). LComp on front floor, VComp on rear floor.
- Doors: 2 layers of Raamatt for the inside and outside portions of the door. 1 layer of Lcomp for the front doors, 1 layer of VComp for the rear doors.
Performance loss is similar to turning on the A/C. This install is easily the biggest PITA I've encountered w.r.t. working on cars. It took a friend and myself 18 straight hours to do the floor, headliner, rear deck, & part of the trunk. We thought it would be done quickly after gutting the car in 1 hour... boy were we wrong! Part of this time was spent running wire from the engine compartment to the trunk (I had already run the new ground and power wires). Signal wires were run along the roof and power wires were run along the floor. I also had to add a wood panel behind the rear seat (needed something to screw the amps into). FWIW, I would not recommend trying to reassemble your car at 3 a.m.! I've probably put another 8 hours into completing the trunk and doors...
After all of this pain, I can say that road noise is drastically reduced. The sunroof and windows no longer 'grind', they 'whir and click' into place. It seems I took this post somewhat off topic in my eagerness to vent about deadener application. Anyway, enjoy the project (if you dare!).
Greg_R is offline   Reply With Quote
Old 06-19-2003, 05:01 AM   #16
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Good job! You saved a ton of money over having an installer do it, and got to see the job done right!
Old 06-19-2003, 10:04 AM   #17
smp291
Member#: 9520
89 weak ass
commuter civic
Well at least the space in my Mazda Truck is a wee bit smaller than the WRX so Less materials will be needed! I just need to get some deadener...
Old 06-19-2003, 10:43 AM   #18
sil0nt
Member#: 30584
05 STi Black
07 S4 Avant Black
I'm about to pick up a roll of Raammat60. From what I've read, its the best for me. Its cheap, its not too heavy, its easy to apply, it doesn't smell bad, and it deadenes sound and dampens vibration really well.
sil0nt is offline   Reply With Quote
Old 06-19-2003, 12:54 PM   #19
il96
Gone... But not forgotten
Member#: 13082
How much material is needed to cover (one layer) the coupe doors, trunk and trunk lid ?
I did my floor yesterday, it was the worst job ever. tearing the whole car apart and then assembling it back is not fun especially when you deal with plastic fasteners. I used the sound deadening stuff from mcmaster.com, which I wouldn't recommend anybdy else. It is very hard to flex, it's probably not the lightest, and probably doesn't isolate as good. It was cheap though.
il96 is offline   Reply With Quote
Old 06-19-2003, 07:40 PM   #20
philw007
Member#: 34326
2004 WRX STI
Got an new sti. What would you recommend for some sound deadening...I want to kill some of the road noise. I am also planning on having a stereo installed. Was wondering what would be a cheap (without gutting whole car) way to get some decrease in road noise. Would adding dynamat to the doors help? How about to the trunk?
What won't cost too much for install?
Thanks in advance for any recommendations on material and locations.
philw007 is offline   Reply With Quote
Old 06-19-2003, 11:06 PM   #21
G-force
Member#: 14104
UBER ILikeItLongAndH
ardDeepandSmoothEverSoCoo
and it doesnt stick for crap, even in 90+ degree weather, and that was after 3 hours in the sun as well...heavy, not very flexible, easy to tear, and did have a slight odor as well...yea, it's cheap, but not worth my 2 hours of time messing with it and still didnt do the job...in the end, i just rip the whole crap off..now i got 3 rolls of this crap.
guess you live and learn..gonna try that brown bread or raamat instead.
G-force is offline   Reply With Quote
Old 06-22-2003, 04:12 PM   #22
SubieStu
Member#: 4584
The McMaster-Carr materials I used on my OTS worked great.
It is heavy, I'll admit, but it adhered extremely well for me since I used a real heat gun and roller/spoon to apply it.
1) dampening: Polymeric mastic, part number 9709T19. Indistinguishable from the higher priced spread. Two or three layers everywhere. Self adhesive but need lots of heat to adhere really well. As mentioned earlier clean the surfaces well. Next time I mayl use the viscoelastic, part number 9709T26...more expensive, but lighter and has better DLF. McMaster also has a vibration damping compound part #9545T1 that looks like a good substitute for Cascade's V-Block for the outer door skins.
Work in the sun and a use heat gun. A roller and spoon also help. Gloves too. If it's bare metal cover it and cover it again. Maybe even again. Both sides. For the doors it's easy to pull the window regulator and glass to get inside. Don't cover the water drain holes inside the door cavity. I didn't take the carpet completely out under the dash...just worked under it...a pain. No asphalt smell past the first couple of weeks.
2) barrier: Vinyl sheeting loaded with lead-free barium metal powder, part # 54665T32. Use 1/8" neoprene sponge rubber to decouple the barrier from the body, part # 8647K71. Do the floor pan, parcel shelf and wall behind seats. I used a spray adhesive that I got at the upholstery shop to adhere the rubber to the vinyl barrier. The rubber backed vinyl sheet doesn't have to adhere to the body...use duct tape to keep it in place.
3) absorption: a) between the barrier and carpet, use the generic gray padding sold at upholstery shops. I used a reinforced type almost 1/2" thick. Hard to cut and made for pouffy carpets, use a thinner version b) fill all the voids in the tunnels between the trunk and pax compartment and in front of the gas tank...Flat Sound Absorbing Foam, part number 5692T49. 1" thick, adhesive back, skinned surface.
Total cost about $250 (doesn't include the trunk) but I have some left over. If you think that's expensive, price Dynamat or Cascade. I don't have all my receipts but I used about 4 or 5 sheets of the dampener, 6 or 7 linear feet of the barrier, 3 sheets of the neoprene and 1 or 2 linear feet of the acoustical foam.
Obviously you don't have to do all this, anything you do will help. I'm very happy with the result, but I don't know if I'd do it again. It's a royal pain and takes a long time not to mention the minor cuts and burns. It adds a lot of weight. The dampener isn't 100% reversible if put down right. Did I mention it's a royal pain to do?
Stu
SubieStu is offline   Reply With Quote
Old 06-23-2003, 11:12 AM   #23
aov
Member#: 7193
MY02 WRX
Hope this is not too off topic (maybe the thread starter would like to know too )
For someone who just wants to add a little bit of sound-proofing to reduce tire/road noise, what would you recommend? Would rammaat60 in the trunk floor, wheel wells, and maybe a little on the floor inside the cabin make any difference, or do you have to cover everything??
thanks,
-anders
aov is offline   Reply With Quote
Old 06-23-2003, 04:18 PM   #24
well_armed
Member#: 15204
These are vibration dampening materials...they will not decrease road noise but will only help with the noise associated with road vibration. (which is not a whole lot) It made a big diffy in my ride, but thats because I did a crap load of it...just a little here...and a little there...wont do you much good for all the labor and costs associated with it.
A tutorial on how to install sound deadening material in the front doors? Jesperss Car Audio, Video & Security 25 04-19-2013 08:24 PM
whats the best sounding exhaust ??? boostedsti06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 98 03-01-2007 12:29 AM
whats the best sounding exhaust for the sti in your opinion? stihopeful Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 103 04-14-2005 01:06 AM
sound deadening material under the hood MBPEJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-25-2003 04:22 PM
who has removed the sound deadening material from their car? DoinkMobb Normally Aspirated Powertrain 42 07-22-2002 04:31 PM
