Welcome to the North American Subaru Impreza Owners Club Saturday July 12, 2014
Old 06-11-2003, 03:21 PM   #1
DEE-REX
Member#: 37634
2003 WRX
Rally Blue
Question Rear door speaker upgrade (03 wrx sedan)
I put in infinity 4002i coax in the rear doors. I can hardly hear them, because my front infinity 605cs conmponents are way too powerful. The problem became even worse, when I upgraded my AMP. I upgraded from alpine mrpf-240 (40wx4) to mrvf-340 (55wx4). The rear speakers are rated only for 35w rms.
Any suggestions, on whats going to fit, and whats more powerful than 35w....something in the 50-60w range? Any special install instructions for these?
I really like good sound coming from the back...miss my eclipse gs-t...had great speakers in the back, and placed very optimally too!
DEE-REX is offline   Reply With Quote
Old 06-12-2003, 03:10 PM   #2
DEE-REX
Member#: 37634
2003 WRX
Rally Blue
Unhappy
looks like nobody knows....I did some research thro the forum, info is still not clear...but seems like kappa 42.5 have been successfully used in the rear doors...they are also 50w rms.....Somebody please help me out...are there any 5.25'' brands that might fit there?
Old 06-12-2003, 05:55 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Why bother with the rear speakers at all, unless you are planning on carrying important rear-seat passengers? If the fronts are good, and that's all you can hear, what's the problem?
Old 06-12-2003, 08:17 PM   #4
DEE-REX
Member#: 37634
2003 WRX
Rally Blue
I'd like to hear sound from the back. It just feels "full". Its tough to explain...check out a mitsu eclipse 2nd generation...you will know what I'm saying
Old 06-12-2003, 09:04 PM   #5
lgkahn
Member#: 9793
2002 2010 legacy gt
red
I don't understant having a speaker that handles more watts typically means it is less efficient and thus will not be as loud as the current speakers.
I have 6" polks in the front and 5 1/4" kenwood in the rear.
I had to cut the rear door panel to fit the coaxials in as there is no speaker to panel clearance.
I looked for speakers for both the front and rear that had the same relative efficiency ratings to avoid this problem
ie 92 db at 1 watt/1 meter..
that means supplying them with 1 watt of power and listening from 1 meter away they should put out 92 decibels of volume
search on crutchfield.com they have ratings for all their speakers.
hope this helps..
lgkahn is offline   Reply With Quote
Old 06-12-2003, 09:43 PM   #6
WORWRX
Member#: 36078
2003 WRX Sedan
Adjust the gain to the rear and front channels; if your amp allows you to do that; if not buy a crossover or an equalizer to give you more control.
WORWRX is offline   Reply With Quote
Old 06-13-2003, 05:14 PM   #7
DEE-REX
Member#: 37634
2003 WRX
Rally Blue
thanks guys....I see what you are saying, but if the speakers had the same efficiency, but if one had more wattage than the other...then assuming that you had an amp with enough power to drive them....wont it make the speaker sound louder.
If i increased the gains, I'm scared, I might blow up the speaker....
Old 06-13-2003, 05:35 PM   #8
WORWRX
Member#: 36078
2003 WRX Sedan
you won't blow the speakers if they can handle the wattage; but it sounds like you need a crossover...double check your install also and make sure the polarity on the speake wires are correct.
Old 06-13-2003, 07:34 PM   #9
DEE-REX
Member#: 37634
2003 WRX
Rally Blue
the speakers come with a built in cross over, my amp also has a cross over, and it is adjusted to pass everything over 80 HZ. The speakers are rated 35 watts, but the Amp is putting out 55 W!
Old 06-14-2003, 10:06 PM   #10
DEE-REX
Member#: 37634
2003 WRX
Rally Blue
Default what about subs?
gave up the idea of upgrading to a better 4'' rear speaker...I'll live with infinity 4002i for now, probably having a good sub can move the sound field a little to the rear.
So I was thinking of an Alpine 200w rms amp with a type-s or infinity reference 12'' or..
an infinity basslink. What are your thoughts?
I dont want distorted bass in the car so that the boom can be heard by my neighbour...but I want my car to sound like a "hip-hop club" inside with loud clear bass...
02-03 WRX rear door speaker stevepius Interior/Dressup/Audio & Security 1 01-20-2010 07:16 PM
02-03 WRX rear door speaker stevepius MWSOC Private Classifieds 0 01-20-2010 04:25 PM
Rear door speaker upgrade from Crutchfield..... dillsky Car Audio, Video & Security 3 09-10-2008 02:25 PM
FS: factory rear door speakers and mount from 03 wrx SOCIOPATH Interior/Dressup/Audio & Security 5 02-21-2007 01:16 AM
WTB: 20mm rear sway bar (02-03 wrx sedan) corbett TXIC Private Classifieds 0 04-29-2006 06:32 PM
