Old 06-11-2003, 05:25 PM   #1
kaos200
Member#: 2692
Default Fuel Vapor can (under rear of car)
Whats the main function of it? how it work, hows it plumbed etc?
kaos200 is offline   Reply With Quote
Old 06-11-2003, 06:47 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Peaty posted this once...
It filters the gas fumes that will end up in the atmosphere or vented back that get vented from your gas tank. I think it's the Carbon filter cannister. There is a check valve in the filler neck so you don't get gas down in it but if you force it it can happen. This is why they say don't add anymore gas after the pump stops pumping. I usually do anyway but not a lot more, just to round off the price.
kastle is offline   Reply With Quote
Old 06-11-2003, 08:49 PM   #3
kaos200
Member#: 2692
right but what if you wanted to bypass it to remove the canistor etc.
there are two primary lines feeding the whole system, and the system has two solenoids of some sort.
What I DO know, is if you plug both those main lines, the tank gets pressurized and you cant fill up because the pump thinks the tank is full. I just need to test and see which.
If you leave both lines open, you leak vapor and your mileage goes down the $hitter it seams.
Old 06-11-2003, 08:55 PM   #4
Avenger
Member#: 1234
The solenoids are controlled by the ecm to let the fume go into the engine at certain time. If you disconnect the hose you might get an EVAP code with your check engine light lit.
Avenger is offline   Reply With Quote
Old 06-11-2003, 09:11 PM   #5
kaos200
Member#: 2692
lol, not too worried about the cel.
Basically, how should I route those two lines to just bypass the can? Which of the two solenoids can I put between the lines to do what I need at the right time?
Old 06-11-2003, 11:12 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Heh, I have no idea on the answer, but I'm going to get a close look at that bastard tomaro... I have to run fuel lines across the top of the tank to the new secondary system because there are too many snags when you try to run it with a hanger or something (doh!). Good luck!
Old 06-11-2003, 11:17 PM   #7
kaos200
Member#: 2692
hehe cool
I want to remove it because I hate adding weight to the car so when I added the fuel surge, I figured that could go
Old 06-12-2003, 05:50 AM   #8
kaos200
Member#: 2692
just finished discussing this with a friend on the boards (thanks dood!)
and Im going to try a check valve on the smaller line under the car, bleeding out, stopping anything getting in. It just sucks that Im losing fuel to the atmosphere
And once I have sunlight Im going to see exactly where the fatter line goes, possibly just to atmosphere.
I removed the fuel vapor purge into my intake manifold, being that Ive had an inconsistent idle at times, this may solve that problem (we'll see)
Damn, and I told myself Id never be a guinea pig again... LoL
Old 06-12-2003, 06:22 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Hell, if you're going that far, you might want to try a pressure-relief valve... something that opens after a certain pressure only.
Go to www.mcmaster.com and enter "pressure relief valve" in their search and check the page that comes up. Possibly the one at the bottom may work the best... it's the cheapest and can be set very low.
Old 06-12-2003, 03:27 PM   #10
kaos200
Member#: 2692
im going to do just that
to top it all off I just found a 3rd small hose, comes off the fuel tank filler (leads to gas cap), Im going to use the pressure release on this one and cap the other two, and just try different setups until I find what the car likes
Kian
Old 06-13-2003, 02:23 AM   #11
kaos200
Member#: 2692
change of plans, looks like the pressure release is going to go on the middle or largest of the 3 hoses, with a check valve on the third tiny one (air in, not out)
since the tank wont fill with those two plugged (I think its probably the middle one)
Question is, what should the valve be set at to release?
Old 06-13-2003, 07:46 PM   #12
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Atmospheric Pressure???
15psi?
Zee
Sunrise City Rider is offline   Reply With Quote
Old 06-13-2003, 08:09 PM   #13
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Hey Kian, excuse my ignorance, but what are you trying to accomplish with this project? I thought the vapor canister just collected the gasoline vapor and allows it to condense back into liquid which is then fed back into the fuel system. Is this not just an emmissions thing to prevent HCs from being released into the atmosphere?
I don't understand how you would gain performance by removing this device.
Please enlighten me.
Word.
-Milan
US2JDM is offline   Reply With Quote
Old 06-13-2003, 08:58 PM   #14
kaos200
Member#: 2692
the answer to your question is simple, what can you do to your car to make it faster without adding power?
Old 06-13-2003, 09:23 PM   #15
kaos200
Member#: 2692
thanks to a nice board member I have the diagrams of the entire system when driving and when fueling, if anyone can host it, let me know Ill email it
thanks Greg!
Old 06-13-2003, 09:27 PM   #16
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
Always drive downhill.
ShadowIMg is online now   Reply With Quote
Old 06-13-2003, 09:52 PM   #17
kaos200
Member#: 2692
Old 06-13-2003, 10:00 PM   #18
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Weight reduction...but how much does that little plastic can weigh? Is it really worth the trouble?
Old 06-13-2003, 10:09 PM   #19
kaos200
Member#: 2692
I dont claim to know the answers to such questions
"I just do it"
OK so back ontopic, who wants to host the pics ?
Old 06-14-2003, 01:44 AM   #20
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
"I just do it"
Indeed. Hopefully you can weigh it when you do get it out, so we'll all know.
E-mail kym, she'll host 'em.
Old 06-18-2003, 07:14 PM   #22
EJ22T
Member#: 26603
1994 EJ22T powered-
majic carpet, Boo yaaa...
Unpluging it will vent alot of the gas into the atmosphere. A problem for tree huggers, but the biggest problem for you and I, is that alot of the gas will evaporate away from the tank if you uplug that cannister and leave the lines open. So dont do it. You'll be wasting alot of gas, especially on hot days, and your wallet won't thank you for it.
Mark,
EJ22T is offline   Reply With Quote
Old 06-18-2003, 11:02 PM   #23
kaos200
Member#: 2692
Mark,
Thats why Im trying to figure this out...
So far, Ive plugged the large line, but NOT the little T fitting on the same line a few inches back.
Ive installed a check valve on the line from the filler pipe (air in, but not out)
and left the 3rd line open for now (will put the pressure relief in tomorrow to test it when I fill up)
Old 06-22-2003, 05:06 PM   #24
kaos200
Member#: 2692
Ok so that didnt work, kept stopping the pump
I placed the pressure release valve on the largest hose, plumbed the line from the fill neck into the T that goes INTO the largest hose, and let the middle line open, gonna see how this goes tomorrow
Ive never looked forward to filling up so much
CAN SOMEONE HOST THE PICS IVE SENT THEM!
PSS the plastic box and all the parts with it are NOT light..
about 8-10pounds
Old 06-22-2003, 05:15 PM   #25
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
PSS the plastic box and all the parts with it are NOT light, I can even feel a difference in handling because the weight from the back is gone!
Good information there... didn't expect that box to be too heavy. What do you think it weighed out at?
Fuel Vapor Technologies Car = 92 mpg and 0-60 in 5 seconds hampster Non-Subaru News & Rumors 11 07-19-2007 01:15 PM
k5t48376 fuel vapor solenoid White 2.5rs Private 'For Sale' Classifieds 5 02-06-2006 06:20 PM
The fuel vapor trap thingamajiggy kaisersouse General Community 7 08-10-2005 06:06 PM
Fuel vapor leak??? stevo2234 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-16-2004 04:45 PM
Fuel vapor cointrol and purge valve alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-19-2002 11:06 PM
