![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 38140
Anyone using 4-pot STI calipers? Only $600 includes the pad, sound like deal? also do I need the STI brake line to used with the caliper?
http://products.nasioc.com/viewProduct.cfm?ProductID=96 Just got my WRX, don't know much about it. Thanks in advance. Al |
#2 |
Member#: 5893
E. Canada
Vehicle:1997 Black GC4 1995 White BK6 |
$600 for the loaded 4-pots is about the going rate. You don't need STi lines, but I'd suggest you get good quality stainless lines. Goodridge ones are great for the price (the STi ones cost about 3-4 times as much).
Have fun! -Milan Edit: oh yeah, you're gunna have to run different wheels to fit those brakes (16X7 Subaru wheels from 98-01 the Impreza RS or 17s or larger) |
#3 |
Member#: 23974
Vehicle:2003 WRX Wagon Sonic Yellow |
Even with 17's you have to watch it for not all will clear then STI 4 pots. I found that out this weekend when I put mine on and put the Enkei RPM 2's back on. The wheel was hitting the caliper. So I had to go to a 3mm spacer to clear the caliper. While I did that I also put on StopTech brake lines on too.
#4 |
Member#: 5851
VIC
Vehicle:09 Forester XT + NA Miata |
I'm running 4-pots on my legacy and using Impreza 2.5RS (MY00) wheels. My Sti's were closer to $450USD new with pads. Where are you located? $600 does seem to be the going rate, but you can find better deals if you search.
I love these brakes, I'm sticking some porterfield R4S pads in soon and with the stainless lines and hopefully a MC brace it should be very nice. Good luck. |
#5 |
Member#: 38140
tora,
I am located in Van. too. Where did you get your set? As I said before, I am a newbie in Subaru world. I got the price from SubaruWRXparts.com. Thanks everyone for the reply. Al |
#6 |
Member#: 6513
#7 |
Member#: 4496
Vehicle:2009 Forester red |
i was lucky to get my brakes from tora's source (jerry/total). i ended up cheaping out and using the stock brake lines from my wrx and although they work i am still regretting i didn't buy the matching ss lines they had on offer after i had already installed them
![]() as for wheel clearance i have jdm 17"s so i was lucky there ![]() |
#8 | |
Member#: 25187
Vehicle:'03 WRX Sedan MBP '08 Forester Prem TGM |
#9 |
Member#: 5039
South East
Vehicle:1997 Legacy GT Wagon Navy Blue - sold:-( |
Tora, Ben and Jerry, I am a little confused. Are you guys saying that the 2 sites listed above sell Subaru STi 4pots for $450 new? All I could find on those sites were some excellent looking forged aluminum calipers. What gives???
ss |
#10 |
Member#: 5851
VIC
Yes, Total (if you contact them) has access to Sti 4-pots for 450-550 new depending on exchange rate....they are in Canada.
#11 |
Member#: 1594
I'd like to buy a set of the Subaru 4 piston calipers right now if I could get them for $450 new!
#12 |
Member#: 5851
VIC
What's the present exchange rate between Canadian and US dollars?
#13 |
Member#: 177
NWIC
Vehicle:The FHI addiction-> 93 WRX, 07 FXTS, 08 FXS |
1usd=1.34cad
#14 |
Member#: 5851
VIC
Then right now they would be closer to $550USD. When I bought they were $450USD.
#15 | |
Member#: 36135
Vehicle:2017 Yugo(prototype) Neon Green |
#16 |
Member#: 23974
48 should be the offset that is on the Enkei's that I have.
#17 |
Member#: 4496
i think the maximum width allowable with stock wheel studs is less than 5mm, which i read somewhere is not enough. sometimes fitting spacers can introduce a host of other problems, from insufficient thread depth in the lug nuts because the wheel studs are not long enough to compensate for the spacers, to hub centricity in which the wheel actually wobbles on the hub spacer.
#18 |
Member#: 5851
VIC
Very true. Even if you get longer studs you can dun into problems because they start taking a lot more of the stresses put out by the wheel instead of the hubs. A 5mm spacer on a 53ET wheel shouldn't pose any problems. You've still got enough thread depth for your NUTS. You've also still got a good portion of the hub left for the wheel to rest on. Hub-centric spacers are also a bonus if you can get them.
#19 | |
Member#: 5893
E. Canada
There are a few sets of 98-01 RS wheels for sale if you poke around on the board a bit. Or just upgrade to compatible 17s (it's one of the best handling mods out there and looks nicer!). |
#20 | |
Member#: 1594
Shipping probablly is a bit more than buying in the US though. |
#21 |
Member#: 9327
The easy solution (and nets you the same overall results) is a good set of Pads (Hawk HPS, Carbotech, etc.) and a good set of braided lines...and a heck of a lot cheaper than the Subaru 4 pots (which though its a 4 piston caliper, the pad itself is really not much larger than the stock pad, and that is largely what determines the overall performance, though the feel is a bit better with the 4 pistons)
Adam |
#22 |
Member#: 4496
i don't know what other people think about this but i chose not to go with an agressive pad because of how they eat rotors (which aren't cheap either... but then neither is buying new wheels) and some dust badly and corrode wheel finishes... or is it just me?
#23 | |
Member#: 5893
E. Canada
#24 |
Member#: 5851
VIC
Ben I'm running Porterfield R4S right now and having no problems. I think a lot of it has to do with driving style as well.
Z1, you can't tell me that a good set of pads and lines with a single piston caliper and 10.3 inch rotors will offer equal braking performance to Sti 4-pots with 11.3inch rotors as well as lines and good pads. That's the change I made and the difference is huge. We have guys that have gone from 2-pots and notice significant change. |
#25 | |
Member#: 18975
Vehicle:2005 WRX STi Platinum Silver |
