Old 06-12-2003, 10:12 AM   #1
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Default WRX starter motor work on JDM EJ20?
Anyone know? I'm assuming it will, but I'm not sure.
The starter is dying on my STi Ver. 3 (MY97), and I'm hoping to replace it with a USDM WRX part.
Anyone?
- Trent
peepshow is offline   Reply With Quote
Old 06-12-2003, 11:53 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
what tranny do you have
AFAIK there is only 2 starters
1 auto tranny
2 maunal tranny
i am using my 1.8 starter
Old 06-12-2003, 12:05 PM   #3
peepshow
Member#: 1777
2005 LGT
#92 FZippy
STi Ver. 3 manual. Cool, so a starter for any manual tranny Subaru should work?
Where is the starter located? I'm at work, car is stranded in a parking lot, too dark to poke around looking for it last night.
- Trent
Old 06-12-2003, 12:20 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
well on a version 3..
under the intercooler
drivers side top of tranny
1 bolt
1 stud/nut
gonna need
17mm or 14 to remove starter (can't remember need more coffee)
12mm or 10 to remove nut on the power pole
big honking screw driver/prybar to get intercooler on and off
screw driver to get hose clamps off
pliers for hose clamps on BOV line
Old 06-12-2003, 12:58 PM   #5
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Awww, crap! I gotta take the IC off? What a pain. Ah, well. Thanks for all the help, Jaxx.
- Trent
Old 06-12-2003, 12:59 PM   #6
Puckaveli
Member#: 1518
00 2.5RS
My version 2 starter looks a different than my 2000 RS starter the bolt holes are the same. Plus a flywheel for a 2000 RS will not fit in my Ver2 EJ20, it's too big. The trans cases are the same size so I would imagine the point where the starter mates up to the flywheel will be different.
Puckaveli is offline   Reply With Quote
Old 06-12-2003, 01:42 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um .. the fly wheels should the same diamater ??????
confused???
side note: hood puck, hood!
Old 06-12-2003, 03:42 PM   #8
Puckaveli
Member#: 1518
00 2.5RS
I had a Exedy flywheel that was going in wistful's 2000 RS and we put it up against my EJ20G and it would hit the engine case where it mates the tranny case. and it fit fine into the RS.
I went to do the measurments Tuesday and my friend borrowed my rachet set and left it in his car. He is stopping over tonight and dropping it off and I'm taking the scoop off and taking measurements for ya.
Old 06-12-2003, 04:35 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm very odd
i wonder if the 8 7/8 clutch configuration is differnt than the 8 1/2
our block should be identical just differnt head/turbos/internals
i am useing an 8 1/2 jun flywheel at the moment
note: the above numbers are the diamater of the friction disk. the pressure plate bolt spacing IS differnt between the two (not interchangable).. that said some flywheels (fidenza) have bolt holes for both my JUN does not
Old 06-12-2003, 06:00 PM   #10
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Alright, well, I'm gonna try going with a starter for the EJ20 (USDM) and see what happens. Thanks, everyone.
- Trent
Old 06-12-2003, 11:46 PM   #11
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
FWIW, I'm using a flywheel made for an RS with my 1995 WRX motor. It fits just fine. I did need to take off that sheild thing that's on the bottom of the motor though (that covers the seam between the engine and tranny I think)
Impreza Rider is offline   Reply With Quote
Old 06-13-2003, 07:38 AM   #12
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Yeah, Mark from Lachute Subaru said that they are all the same from 1996 on. However, I'm not sure if he was talking about EJ20s only.
- Trent
Old 06-16-2003, 09:10 AM   #13
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Well, after talking with Mark and Julien from Lachute, I bought a new starter for the original EJ22 that came in my car. Bolted right up, no problems. Mystery solved, it looks like any manual tranny starter will work, at least post 1996. Not sure about the earlier ones and a later version motor.
Thanks to all.
- Trent
Old 06-18-2003, 09:13 AM   #14
mykrrrr
Member#: 733
'13 Focus ST
Wink
Thanks to all.
- Trent
Good to see that my OBSTi will start like a charm huh Trent...
-mykr.
mykrrrr is offline   Reply With Quote
Bolt lengths for starter motor (MT, on EJ257) GTBGUY Service & Maintenance 2 05-25-2009 05:50 PM
Will USDM RS or WRX shift linkage work on JDM Ver. 4 STI 5 speed? legacy2003 Transmission (AT/MT) & Driveline 4 11-21-2008 12:36 AM
1995 subaru impreza WRX-RA GC8 COUPE sti JDM ej20 woohoo Private Vehicle 'For Sale' Classifieds 11 11-30-2007 05:03 PM
02 WRX Starter Motor Dead. Need some advice. TheChef Electrical & Lighting 10 10-29-2007 12:26 PM
wrx starter motor apart... Help trite Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-17-2005 04:22 PM
