Old 06-12-2003, 02:52 PM   #1
SWAT
Member#: 12493
2000 Impreza STi V6
Default How can you guys deal with emission tests if you have a RS-T?
the question is as the topic.
SWAT
SWAT is offline   Reply With Quote
Old 06-12-2003, 03:09 PM   #2
Darshu
Member#: 1676
98RS w/ EJ207
2010 Mazdaspeed3
In california? Got me dude. I just give generously to local law enforcement!
Darshu is offline   Reply With Quote
Old 06-12-2003, 03:16 PM   #3
SWAT
Member#: 12493
2000 Impreza STi V6
paying off someone might be the only way
SWAT
Old 06-12-2003, 03:17 PM   #4
8Complex
Member#: 922
04 FXT
Red
IIRC, people that are really concerned in Cali just do WRX swaps and keep the stock WRX ECU. Newer stock = better in the emissions' tester minds.
Around here? We get emissions 4 years after the car is bought new, and every 2 thereafter. Mine is coming up to 4 years next March and more then likely, it will be returned to stock or sold by then.
Old 06-12-2003, 03:18 PM   #5
SWAT
Member#: 12493
2000 Impreza STi V6
5 years or 4 years?
Old 06-12-2003, 03:23 PM   #6
dyswtric27
Member#: 404
2000 Audi S4
endless.night
Here in MD they only do an OBD II check on newer cars. No exhaust test or anything, they do check to see that you have a cat however. I could never get my stock ECM to not throw codes so i kept failing. I just had to spend $450 on emissions related parts and you get a waiver. I bought some new RC 550 injectors and that qualified me.
Jason
dyswtric27 is offline   Reply With Quote
Old 06-12-2003, 04:12 PM   #7
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
FYI, Puckaveli is working something for the Ohio folks... thing is the GC/GM RS was such a low production car it qualifies for state collectors car tags... emissions free . He is waiting on formal info from SOA but the car fits the criteria in the ODOT rules. Something for you all to look into.
Old 06-12-2003, 04:29 PM   #8
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
live in Canada
HOK is offline   Reply With Quote
Old 06-12-2003, 04:31 PM   #9
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Originally posted by HOK
live in Canada
NevAR :P
Old 06-12-2003, 05:08 PM   #10
Hondaslayer
Brain Stew
Member#: 4562
1998 Forester,lifted
1975 VW Westfalia tin top
Move to Michigan!!!!!!!
Old 06-12-2003, 05:52 PM   #11
Avenger
Member#: 1234
live in Canada
I'm in Vancouver, Canada and we get tested.
Avenger is offline   Reply With Quote
Old 06-12-2003, 06:00 PM   #12
Shinji N
Member#: 3987
1999 Miata
Maybe he's saying the techs aren't too bright?
Shinji N is offline   Reply With Quote
Old 06-12-2003, 06:05 PM   #13
Charge
Member#: 3313
Well, I just E-checked my car(some Ohio counties have to do that). Granted, I'm basically stock, but my results barely registered for them. There was no visual inspection, and from watching them inspect other cars(with obviously aftermarket exhausts) I'd guess they are only concerned with ostentatious tips and really loud vehicles.
I'd guess a properly tuned RS-T would pass in Ohio, for E-Check. If you could set up a stock looking exhaust(with something appearing to be a cat, in case they look) just for testing purposes, you'd probably be OK. My test consisted of about 40 seconds of testing at about 3500-4000rpm. That's it. Nothing else.
Although, a waiver would be nice...provided my registration costs didn't go through the roof for this.
Neil
Charge is offline   Reply With Quote
Old 06-13-2003, 02:10 AM   #14
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
We have the OBDII test in Illinois.
Your car MUST have a working OBDII in order to pass.
Your car MUST have all OBDII test completed.
Your car MUST pass all OBDII tests.
This will be checked by a OBDII scanner.
If the OBDII shows non-emissions realated warnings, then you may try to pass the sniffer test.
I'm going to be trying to pass the OBDII test with the T still attached to the RS-T.
By the end of the month dag nab it!
Revision is offline   Reply With Quote
Old 06-13-2003, 02:21 AM   #15
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
in Alberta we don't even need Cats... hehehe
Old 06-13-2003, 03:01 AM   #16
archbonr
Member#: 17666
08 Forester
Default Just move
Some counties in Ohio don't have to do E-check fortunately. Mine is registered in Champaign county and as of right now there is no requirement for it. I will deffinately keep an eye on that collector car thing though in case that ever changes.
Nik
archbonr is offline   Reply With Quote
Old 06-13-2003, 09:16 AM   #17
Puckaveli
Member#: 1518
00 2.5RS
The collectors plate would run around $80 a year.
If SOA comes through, which seems very likely, the will send me a letter stating my car is a limited production vehicle, but the letter will have to have my VIN, year, make , model, etc so if it works this will have to be done by the individual.
Puckaveli is offline   Reply With Quote
Old 06-13-2003, 09:24 AM   #18
OKRS25
Member#: 36533
2005 STi
Hey Boy you pass Texas emissions?
OKRS25 is offline   Reply With Quote
Old 06-13-2003, 11:24 AM   #19
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Wichita Co doesn't have emissions. $13 and a grease monkey checks your wipers, horn, lights, brakes :P
Old 06-13-2003, 11:49 AM   #20
archbonr
Member#: 17666
08 Forester
That works. Like I said I don't have to worry bout it for now, it's just nice to know the basics in case I ever have to do that sort of thing. Always good to know that there is a precedent just in case, ya know?
Nik
Old 06-13-2003, 12:30 PM   #21
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Is this collectors car thing limited to Ohio, or is this a nationwide thing? Heck, $80 a year is better than $35 for the inspection and $50 to pretend he didn't see what he thought he saw in the engine bay.
garface is offline   Reply With Quote
Old 06-13-2003, 12:53 PM   #22
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
I would also like to know if its just ohio and if you dont mind saying exactly how you are going about getting this done.
thanks
-Marc
boysetsfire is offline   Reply With Quote
Old 06-13-2003, 01:27 PM   #23
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default Oregon Emissions
In Oregon there are so called regions of testing. If you live iun the general portland metro area and other more heavily popultaed cities you are needed to take an emisisons test. in some other areas you are not. Best way I can think of and the way I did it was find a friend that lives in one of the areas that dont require testing and have your address changed for a little bit and say you live in that area. All you need to do is bring proof of insurance, license card and license plate number. $30.0 and you have yourself some new emissions tags good for 2 years I Think not to much work for tags eh? Or you can sell it to your freind for a week adn have him register it, as long as he lives in the certain areas then have him "sell it " back to you, I mean no money exchange just pass the title over and backl hehehe evil, I know, but it works and "no, I never said it was possible to do this because my car still needs tags..." tehe
John
Cusco is offline   Reply With Quote
Old 06-13-2003, 01:31 PM   #24
Shinji N
Member#: 3987
1999 Miata
Just curious about what your insurance has to say about owning a collectible car.
Old 06-13-2003, 02:04 PM   #25
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Don't tell em.
As for if the collector car thing is for Ohio only, best advice I have is to check your local DOT or DMV websites and review the code for special tags. Imagine if the cali folks could get out of CARB testing
How do/did you guys deal with relatives losing their minds with age? White 2.5rs Off-Topic 33 06-29-2009 08:47 PM
Would you guys make fun of me if you saw me driving a... waktasz Off-Topic 30 05-07-2009 08:23 PM
How do you guys deal with the heat? I'm from the midwest visiting Texas skribblez32 Texas Impreza Club Forum -- TXIC 43 04-10-2008 07:12 PM
So how do you guys deal with grief?? Miggidy Off-Topic 15 04-04-2005 11:38 AM
How do you guys deal with Sport TRAK? I am b Texas Impreza Club Forum -- TXIC 29 06-12-2002 09:48 AM
Message Board Statistics All times are GMT -4. The time now is 10:50 AM.
