Old 06-13-2003, 12:06 PM   #1
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Question Sidefed Injector ?
Hey All,
I have a MY97 intake off a 2.5 Legacy for my hybrid project. A search did'nt help me on what size the injectors are. Does anyone know, and where's a good source for these as far as getting a matched set of bigger size.
Also are the 04 STi's sidefed? If they are maybe those will start selling for cheap like the WRX's. Course thats only if they fit.
Thanks, Tod
todnar is offline   Reply With Quote
Old 06-13-2003, 12:33 PM   #2
Mancini
Member#: 20726
Probably 270cc. Apparently 370cc injectors off a silvia will fit right in and only the plug end needs modified. I plan on going this route in the next month or so.
Mancini is offline   Reply With Quote
Old 06-13-2003, 01:37 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I recently went to the dealership on this and found that the STi injectors are about $100 each (I think at my pricing, around subaruparts.com pricing) so those should work for turbo applications pretty good. These are yellow tops.
I believe the Legacy turbo injectors are 370cc and blue or grey tops.
The RS injectors are red tops and I believe 280cc or so.
Old 06-13-2003, 02:26 PM   #4
Mancini
Member#: 20726
ah 280, thought it was around there...to many numbers to remember
Will the Legacy turbo injectors work with the Phase I fuel rail?
Old 06-13-2003, 03:53 PM   #5
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
The turbo legacy injectors are pink.
2.5GT is offline   Reply With Quote
Old 06-14-2003, 09:11 AM   #6
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Type Color Flow
EJ22 Grey 220 cc/min
EJ25 Red 280 cc/min
EJ22T Pink 360 cc/min
SR20DET Purple 370 cc/min
Thats the info I've had. Subaru injectors are High Impedance, the Nissan injectors are Low. You can use them, but you need to use a ballast resistor to get them to work. That is a bit of a band-aid fix, but some people have had plenty good luck with it, so its really up to you. The connectors are very close to identical.
I have Legacy turbo pink tops, and a set of 535cc Tomei side feed injectors for my 97 EJ22. Basicly any upgraded sidefeed injector for the old WRX or many of the Nissans will work, or can be made to work properly.
-Brad
http://www.subaruwagon.com
ChicksDigWagons is offline   Reply With Quote
Old 06-14-2003, 02:37 PM   #7
Mancini
Member#: 20726
I thought the sr20 injectors were high impedence, at least that was the impression I got from this thread here
http://forums.nasioc.com/forums/show...ghlight=silvia
Old 06-14-2003, 03:12 PM   #8
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
Actually the Silvia 370cc injectors are high impedence and direct drop-in for the Phase I fuel rail. I'm running them in my car right now. Nismo 555cc injectors or STi injectors will work great too.
Darshu is offline   Reply With Quote
Old 06-14-2003, 03:17 PM   #9
Mancini
Member#: 20726
and I just got my tax return today time for some new injectors
Old 06-15-2003, 02:33 PM   #10
ChicksDigWagons
Member#: 20508
1998 Red Wagon
Dizzam, looking further into it I see that I obviously had something confused. The SR20DET injectors are in fact high impedance. Not sure what led me to believe otherwise. I guess even geniuses can be proven wrong from time to time
-Brad
Old 06-16-2003, 02:38 PM   #11
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Smile
Thanks guys All that info will get me on the right track. Anyone wanna take a guess at what the STi's flow at.
Later ,Tod
Old 06-17-2003, 07:57 PM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hey 8 you have the part numebr for those
to add to the list
ej20G 425cc blue
there was a set of sti side feeds for sale in private for 280 shipped the other day
yes silvia are high impediance, as are you stockers 10-14ohms
low impediance 3-4 ohms
Old 06-21-2003, 10:16 PM   #13
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
I have a 1998 impreza and I have installed nissan sr20det injectors the purple ones. They drop right in all you need to do is go to a nissan or infinity dealer and get the plastic injector plug for that injector.
CUNNINGHAM is offline   Reply With Quote
Old 11-11-2003, 01:25 AM   #14
awd4ever
Member#: 31573
I found the
meaning of life!
this is amazing... after 400 searches i finally find a thread that gives me info i need.
now the question, does any one know if i could use Nissan MAF on my 1998 RS and NOT have it blow out ever 3 month?
awd4ever is offline   Reply With Quote
Old 11-11-2003, 02:17 AM   #15
Mancini
Member#: 20726
Are you having problems with your MAF? Cause mine has taken some serious abuse and is still working like a charm. Or are you thinking of the 99 MAF? 98's are hot wire and don't have the problems the 99's do.
Old 11-11-2003, 04:40 AM   #16
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yeah, the 98 MAF's were supposed to be solid. But no, I don't see a problem with using a Nissan MAF as long as the voltage output range is the same. Also, you may need to calibrate it to the size of the tubing it is in to properly output what the ECU expects at certain airflows.
1000cc sti sidefed injector spoolnSTi Private 'Wanted' Classifieds 4 05-29-2007 02:19 AM
PA: STI sidefed injectors and STi fuel pump killthelights145 Engine/Power/Exhaust 6 01-14-2007 12:15 PM
FS 440cc sidefed injectors from ej20g apoopoo999 Engine/Power/Exhaust 0 12-05-2006 12:54 AM
370cc sidefed injectors in a 98rs NeaD Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-24-2004 01:40 PM
Where to get Sidefed injectors nativo Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-14-2002 08:15 PM
