Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 11-29-2000, 10:54 AM   #1
CRZ_MSL
Member#: 1610
Question Intake Question
Has anyone taken a look at thier airflow sensor lateley? I have used a K&N panel filter for the past 130,000 miles. I keep it well oiled. The leading edges of my airflow sensor have a thin layer of dust/crud build up. Does anyone who has stuck with a paper filter have similar buildup?
In front of the airflow sensor is a wire mesh. This is probably there to protect the sensor from debris that get sucked into the intake, but if you are using a filter there is no way anything is going to get to the sensor. It's like installing a picket fence to stop anyone that gets past your razorwire electric fence. Removing this will improve airflow, but will the change in the flow characteristics affect the sensor readings adversely?
CRZ_MSL is offline
Old 11-29-2000, 02:00 PM   #2
glenstiles
Member#: 2827
2002 WRX wagon
Silver, baby, silver
Post
How do I get to the airflow sensor? Is this the one next to the airbox? I have a paper filter, but last time I checked didn't notice any buildup of grime or whatever.
Glen
glenstiles is offline
Old 11-29-2000, 02:52 PM   #3
CRZ_MSL
Member#: 1610
Post
If you look in the tubing after your filter box you will see a wire mesh. Hiding behind the mesh you will see the airflow sensor. Mine has a thin layer of dust on it. Tonight I am going to clean it off with cotton swabs and rubbing alcohol.
CRZ_MSL is offline
Old 11-29-2000, 04:35 PM   #4
immortal_suby
Member#: 1711
140 rogue points!
2013 GBS BRZ Limited 6MT
Post
I too am running a K&N for at least 22,000 miles. I also tore out the wire mesh screen about 10,000 miles ago. There is no buildup on my MAF yet. Be very careful when you clean it, that is an expensive piece of wire.
immortal_suby is offline
Old 11-29-2000, 04:59 PM   #5
CRZ_MSL
Member#: 1610
Post
Your K&N has been on for 22,000 miles? Get back to me in about 110,000 miles.
150K miles and counting. Provided no misfortune befalls my car, 250K should be easy.
CRZ_MSL is offline
HTML code is On
Yes an intake question...which "big" intakes fit w/TXS FMIC? Wrx_Fan_0717 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-30-2008 01:10 AM
cold air intake question Norris Normally Aspirated Powertrain 24 06-06-2001 11:08 AM
MY99 Intake question? BuRnToAsT420 Normally Aspirated Powertrain 11 06-04-2001 01:31 AM
Intake question ADIL Legacy Forum 18 04-28-2000 06:20 AM
Weapon R intake Question Install finnstr New England Impreza Club Forum -- NESIC 0 04-23-2000 11:03 AM
