Old 06-13-2003, 10:39 PM   #1
simpreza2
Member#: 20381
04 Forester X
93 240sx
Default AC question
Whats the 3rd pully on the blet that the ac is on? I misplaced my haynes book. Is it just keep the belt tight? or does it actually do something?
Thanks Jon
simpreza2 is offline   Reply With Quote
Old 06-14-2003, 02:56 PM   #2
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Default Re: AC question
Thanks Jon
Jon,
Not sure what pulley on the "blet" means. Can you clarify?
Br, Dale
Subietonic is offline   Reply With Quote
Old 06-14-2003, 04:17 PM   #3
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
"blet" is east coast speak for "belt" common mistake yeah thats just a tensioner. if your belts squeak tighten it.
biggreen96 is offline   Reply With Quote
Old 06-14-2003, 04:30 PM   #4
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
blet" is east coast speak for "belt" common mistake... lol
If your belt(s) is/are sqeaking, check them for cracks and tears in the material. Twist them gently sideways and look at the running surface of the belt and the edges. If you see cord coming loose, or if there's cracks up inside the running surface, replace them... it's just a blet (j/k) waiting to break. If the belt/belts all look good, then try using some belt dressing (avail at you local auto parts store) on them to quiet them down. I'd only adjust them a fraction tighter so you don't prematurely overstretch/wear them out.
OTOH - is the 3rd pulley squawking or grinding? If so, you'll want to replace that before it 1) seizes and burns up your belts or 2) wobbles so much that wears out your belts. Either way, that's a must fix soon.
Br, Dale
Old 06-14-2003, 06:05 PM   #5
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
3rd pulleys is usually for alternator.. the small one.. is the tention pulley.. there should be screw right next to it so you can adjust it..
NiTRoN is offline   Reply With Quote
Old 06-14-2003, 06:09 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Here's a pic
As mentioned, that little guy on the AC is just a tensioner.
Legacy777 is offline   Reply With Quote
Old 06-14-2003, 06:48 PM   #7
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Believe the alternator is just a bolt adjustment, while the AC has a pulley that rides on an adjuster track that uses a bolt to loosen/tighten the pulley against the belt and a lock/set bolt to hold that bolt in plate.
Br, Dale
edit: sorry didn't see the picture. It describes everything a ton better than I did.
question about my vents/air and AC question masterpickle Interior & Exterior Modification 3 06-21-2007 03:22 PM
AC question dangrass Service & Maintenance 27 07-21-2003 08:36 PM
AC question Giova New England Impreza Club Forum -- NESIC 0 07-01-2002 12:36 PM
AC Question? WhereRU Service & Maintenance 1 06-19-2002 10:19 PM
