Old 06-14-2003, 11:59 AM   #1
99WRXEJ20
Member#: 34545
1999 GC8
74f
Default 02 sensor question on swap
i put a 95 wrx motor in a 99 2.5rs and the front 02 sensor is gone. Anybody know if other 02sensors swap over?
thanks
99WRXEJ20 is offline   Reply With Quote
Old 06-15-2003, 10:55 PM   #2
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Are you using the 1995 WRX ECU?
If you are, you can probably use any old oxygen sensor. OBD1 Subaru ECUs aren't picky; you could even use a generic 1-wire sensor and just not wire in the heater or ground.
Does the 1995 ECU use the rear oxygen sensor signal? If not, you could swap your rear one up to the front.
If you're not using the correct ECU (i.e. you're using your RS's original ECU) you should probably use the correct sensor for a 1999 RS.
vrg3 is offline   Reply With Quote
Old 06-16-2003, 02:39 PM   #3
Puckaveli
Member#: 1518
00 2.5RS
I don't know what the specs are on the other O2's but the 95 WRX is as follows.
Heater circuit is 10 - 14 volts
Sensor output 0.1 - 1.0 volts
The plug has four wires and looking in the end it goes.
21
43
1 & 2 are the heater
4 is the O2 reading
3 is the ground.
Hope this helps.
Puckaveli is offline   Reply With Quote
Old 06-16-2003, 02:48 PM   #4
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Puckaveli - What is your source for that information? Is it for the front or rear sensor, or does it only list one sensor?
Old 06-16-2003, 03:08 PM   #5
Puckaveli
Member#: 1518
00 2.5RS
The diagnostics and wiring diagram sections of my JDM service manuals. The pre 96 WRX's only have one O2 sensor also. I have a 94 WRX motor and drivetrain in my garage too.
Old 06-16-2003, 03:11 PM   #6
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Cool.
So it seems the 1995 WRX oxygen sensor setup is the same as North American Legacy Turbos... One 4-wire sensor on the downpipe.
Old 06-16-2003, 03:50 PM   #7
Puckaveli
Member#: 1518
00 2.5RS
Yep the bung I believe is just after the turbo on the DP.
Old 06-18-2003, 01:45 PM   #8
99WRXEJ20
Member#: 34545
1999 GC8
74f
cool thanks for you help.
02 Sensor question.... YourMother'sLover Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-26-2005 04:44 PM
02 sensor question 02wrxdemon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-23-2004 03:21 PM
02 sensor question 1DOWNCLOWN Electrical & Lighting 2 02-25-2004 11:32 AM
exhaust cutout and 02 sensor questions Rickyh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-05-2003 09:00 AM
02 sensor question please help ac_gohan Normally Aspirated Powertrain 1 02-04-2001 08:59 PM
