06-14-2003, 03:43 PM | #1 |
Member#: 12625
SCIC
Vehicle:MY02 WRX Impreza Silver |
Dim light reversed in gauges
Ok so I put in my defi gauges finally and used the radio harness to tap into. it all works fine except if I brighten my dash lights the gauges dim.
Any idea on how to fix this? Also when I set the dimmer about half way so the dash lights are equal with the gauges the power seems to drop on the gauges because the vacuum drops a little on the boost gauge and the others have blinking red lights (Dont have them hooked up yet) and the lights blink slower.
06-14-2003, 04:10 PM | #2 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
Well - the subaru dimming circuit is a little odd - there is a fixed +12v, ground, and a variable 0 to -12V - sounds like you grabbed the latter two - the variable goes from 0 (full bright) to -12 (fully dimmed)
If you have a mechanical gauge, you should be able to grab the fixed +12 and the variable (use as a variable ground), and get the proper dimming action. most gauges expect a ground and a variable lead which goes from 0 to +12V |
06-14-2003, 06:33 PM | #3 |
Member#: 12625
SCIC
Hmm, the defi (Electrical) system uses both the fixed and variable 12v, there are hookups for both. (I do not know why)
And that is how I have it hooked up. But dim is still reversed. Thanks. |
06-15-2003, 01:09 AM | #4 |
Member#: 5887
BAIC
Vehicle:2002 GDAA (bugeye) 797 (blaze yellow) |
I don't have a defi electrical gauge, but from reading your post as well as some others, it seems that the gauge has three terminals. One for ground, one for fixed, and one for variable 12V. If this is the case, then there's not much you can do unless you convert the variable signal. As DrD suggested, the way the variable circuit in Subarus are wired are such that the ground is the floating terminal. Since the electronics require "true" ground, the lighting will not operate properly as you mentioned.
06-15-2003, 10:35 PM | #5 |
Member#: 25796
Vehicle:2012 Impreza |
06-17-2003, 09:13 PM | #6 | |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
Auto-dim mirror reverse override circuit | kenbadger | Electrical & Lighting | 1 | 07-24-2009 04:58 PM |
Reverse lights on in all gears... | Doomsayer | Electrical & Lighting | 7 | 02-17-2009 07:50 PM |
dimming lights | rexecutioner | Car Audio, Video & Security | 1 | 05-14-2002 09:44 PM |
dimming lights | rexecutioner | Car Audio, Video & Security | 1 | 05-14-2002 06:29 PM |
dimming lights | rexecutioner | Car Audio, Video & Security | 0 | 05-14-2002 02:24 PM |
