Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 06-14-2003, 07:06 PM   #1
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Default Sti Track Day: The Good, the Bad and the Ugly
Well, I just completed the break-in and took the beastie onto the track for some truly aggressive driving. We went to Spokane Raceway Park, a nice road race course with a couple fast (147MPH/6th gear) straights and slow corners (2nd gear).
The Good:
Wonderful power & torque. The thing just claws out of corners. Great power for out accelerating Porsches & Beemers on the straights. The brakes are solid, with no big issues once race pads (Porterfield R4) and high temp fluid (Super Blue) are fitted.
The Bad:
It needs more camber adjustment! My alignment shop could only get -1 degree in the front and -1.5 in the back (with camber bolts installed). I'd like to get -2 and -1.5.
This isn't too bad, but the brake lines need to be upgraded to steel braided units. The pedal is too soft for easy heel-toe (or in my case, left/right foot pivot).
The Ugly:
I had the engine cut out on me a handful of times while at WOT in 5th gear at around 5k RPM, followed by a CEL. Pulling the code showed code 0244 "Turbocharger Wastegate Solenoid A Range/Performance". So I'm thinking the ECU thinks the boost is too high to control with the Boost Solenoid. Strange, since the only mods are silencer removed and Turbo-back exhaust. The boost gauge showed boost at about 16psi. EGTs at WOT, high RPM were 1560F or so.
No noticeable knock though.
All in all, a great time. But the CEL & engine cut are disturbing.
Russ
rlavalle is offline
Old 06-14-2003, 07:23 PM   #2
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
FWIW,
I had the same code (P0244) on my WRX WAY back when I had a BPM down pipe and the wastegate valve was contacting the divider plate on the DP not allowing the wastegate to open fully. Filed the divider plate down and never had the light again.
mr2guru is offline
Old 06-14-2003, 07:59 PM   #3
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Originally posted by mr2guru
FWIW,
Hmmm... Did you get a chance to check your Boost readings? Did they get too high?
My ScoobySport Downpipe has no divider, so I need to keep looking.
Thanks,
Russ
rlavalle is offline
Old 06-14-2003, 09:48 PM   #4
ToddStratton
Member#: 8351
2002 WRX Wagon
According to the service manual, if there are no other trouble codes then the wastegate control solenoid valve should be replaced. But you probably already knew that! Maybe you just have a faulty solenoid.
I just got through my break-in today as well and went on some of my favorite back roads. I felt the brake pedal was pretty good for heel/toe, much better than my WRX. I agree on the torque and power comments, it is really amazing. Even at high altitude. Oh yea, no pinging here either, even after over 45 minutes of pretty hard driving.
TRS
ToddStratton is offline
Old 06-14-2003, 09:52 PM   #5
hatchy
Member#: 36852
2004 STI
Default Re: Sti Track Day: The Good, the Bad and the Ugly
Russ,
Are you sure about the EGT? Unless our pistons are iron (which wouldn't work on a block with iron sleeves), I think they would start to melt around 1500F.
Originally posted by rlavalle
The boost gauge showed boost at about 16psi. EGTs at WOT, high RPM were 1740F.
Russ [/b]
hatchy is offline
Old 06-14-2003, 09:55 PM   #6
mlambert
Member#: 13831
Default Re: Re: Sti Track Day: The Good, the Bad and the Ugly
Originally posted by hatchy
Russ,
No way, even the crappy cast wrx pistons hang tough at 1600f
mlambert is offline
Old 06-14-2003, 10:09 PM   #7
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Wow! I don't know where I got that 1740F number... My GReddy EGT gauge showed 850C (1560F), so I must have converted wrong.
I've corrected the initial post.
Thanks,
Russ
rlavalle is offline
Old 06-14-2003, 10:37 PM   #8
hatchy
Member#: 36852
2004 STI
Default Re: Re: Re: Sti Track Day: The Good, the Bad and the Ugly
The melting point depends on what the piston is made of. Aluminum has a melting point of around 1500F (pure AL I think melts at 1200F). I think even forged pistons melt at 1700F?
hatchy is offline
Old 06-14-2003, 11:09 PM   #9
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
You can have combustion temps above the melting point of AL because the heat transfers trough the metal. NOx forms at temps above 2500deg F and it does not only happen cast-iron engines.
SubyTechMaster is offline
Old 06-15-2003, 01:56 AM   #10
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
I received some information from Clark Turner, a tuner in Arizona.
He says the CEL/fuel cut is caused by the ECU seeing 17.5psi for over 2 seconds.
I need to get a Manual Boost Controller to keep pressure in check. He also says that STi's don't have a problem with MBC's causing Part Throttle/Full Boost since the TPS crossover point is 20% TPS.
Russ
rlavalle is offline
Old 06-15-2003, 02:38 AM   #11
hatchy
Member#: 36852
2004 STI
Good to know, thanks.
hatchy is offline
Old 06-15-2003, 08:08 AM   #12
Jon [in CT]
Member#: 2992
02 WRX Sedan
Russ
I don't think Clark (AKA AZScooby) has access, yet, to the USDM STi's ECU programming logic. The CEL/fuel cut being caused by 17.5 PSI of boost for 2+ seconds is the logic programmed into USDM WRXes. And I seriously doubt the USDM STi's TPS crossover point for switching from closed-loop A/F control to open-loop is as low as a 20% opening angle, although this may be true of STi's sold in other markets.
The symptoms you describe are consistant with "boost creep" where the wastegate is unable to divert enough exhaust, even though it's commanded open, to prevent boost pressure from continuing to rise. In the past (on WRXes), I believe this has usually been cured by using a different aftermarket turbo-back exhaust system. BTW, which one are you using?
I have no idea why Clark thinks a manual boost controller would help and I, personally, would steer clear of it.
Jon [in CT] is offline
Old 06-15-2003, 10:15 AM   #13
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Well, an MBC would be a cheap test.
I also plan a quick test by routing pressure output from the turbo directly to the wastegate actuator to see if boost creeps up.
I have a ScoobySport exhaust.
Russ
rlavalle is offline
Old 06-15-2003, 04:54 PM   #14
Turbobug
Member#: 27412
1999 New Beetle
FOR SALE!!
Russ,
Where do you have the EGT gauge mounted? This will also make a difference on temp readings.
I know for the VW/Audi 1.8t, the stage III kits (around 300hp) out there produce around 1600deg temps in the manifold, and this isnt a problem. I would imagine that the STi should be able to take such temps as well, as Subaru has some good engineers
Turbobug is offline
Old 06-15-2003, 06:38 PM   #15
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
The Ugly:
Russ [/b]
At what RPM, gear and load were you seeing 16 psi - I'd be suprised if you were making 16 psi at redline?
Kevin
Red Rocket is offline
Old 06-15-2003, 10:36 PM   #16
Jon [in CT]
Member#: 2992
02 WRX Sedan
Kevin
As you can see from the extract you quoted:
I'm guessing that, under those conditions, he's not paying strict attention to his boost gauge. I think we're talking about at least 140 mph.
Old 06-16-2003, 01:18 AM   #17
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Uhh, you sure he understands how the drive by wire system works? This statement makes me think he's never even seen an STi, let alone read the service manual.
Were you cornering hard when the engine cut?
Glenn
ANZAC_1915 is offline
Old 06-16-2003, 02:00 AM   #18
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Glenn
FWIW
I fitted my STI with an EBC and tried to get part throttle high EGT's but can't. Boost set at 16psi but can only get 16psi in 5th and 6th above 5500rpm. I live at 3600ft BTW. Small turbo sucks.
EGT's go straight to 1550f in all gears but not 1 degree more. Good A/F sensor me thinks.
As far as the wheel alignment one should mention the caster on the STI is 4.5degs stock which is a full degree more than a WRX fitted with ALK. You can also flip the 2 bolt mount that joins the aluminum arm to the rear pivot to get even more, its offset if you look. I was also able to get 1.5 neg camber on the front stock.
Wombat North is offline
Old 06-16-2003, 02:50 AM   #19
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
I placed my sensor where the two passenger side exhaust ports meet. Probably about 5 or 6 inches from the exhaust valves.
Russ
Originally posted by Turbobug
Russ,
rlavalle is offline
Old 06-16-2003, 02:51 AM   #20
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Kevin
It was about 5000RPM, WOT in 5th gear.
Russ
rlavalle is offline
Old 06-16-2003, 02:53 AM   #21
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
No... 5th gear tops out at 120 to 125. 5k RPM is more like 100 or so.
Russ
Originally posted by Jon [in CT]
As you can see from the extract you quoted: I'm guessing that, under those conditions, he's not paying strict attention to his boost gauge. I think we're talking about at least 140 mph.
rlavalle is offline
Old 06-16-2003, 02:56 AM   #22
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
I think so. This guy is a well respected tuner, doing UTEC, and WRX ECU mapping. He is working on the STi now. He picked it up and immediately took it to his dyno.
I think he knows what he's talking about.
Oh, and no, I was blazing down the straight.
Russ
Glenn
rlavalle is offline
Old 06-16-2003, 11:54 AM   #23
Razlak
Member#: 7209
2005 WRX STi
World Rally Blue
Speaking of blazing down the straight(and corners too), here's a few shots I got of you Russ. Let me know if you want any of the full size originals.
Razlak is offline
Old 06-16-2003, 01:20 PM   #24
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Russ
fwiw, 9x% of WRX failures occur in #4 cylinder (driver's side), which tends to run the hotest. Most of us put the EGT on the 2-4 header merge. I'd rethink your location if I was you.
-C
TypeC is offline
Old 06-16-2003, 01:44 PM   #25
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
These are great shots! I'd love full res. versions!
My email only allows about 3MB worth of enclosures, but if you place them somewhare I can grab 'em from I'd be happy to.
Thanks,
Russ
rlavalle is offline
The Good The Bad and the Ugly is on incorporeal Off-Topic 12 08-14-2006 06:46 PM
Nitrous The good the bad and the ugly. SpeedR Water/Methanol Injection, Nitrous & Intercooler Cooling 10 04-10-2006 09:42 AM
SA Spottings: The Good, The Bad, and The Ugly DreddRS25 Texas Impreza Club Forum -- TXIC 13 11-01-2004 01:55 AM
The Good, the Bad and the Ugly Spheris Off-Topic 12 04-18-2004 12:13 AM
The Good, the Bad, and the Ugly.. xenonk Mid Atlantic Impreza Club -- MAIC 55 12-11-2003 06:14 PM
