Old 06-15-2003, 01:52 PM   #1
SDEWYZ
Member#: 31352
98 RS
Black....for now
Question Coolant leak, 98 RS, water pump? seal?
So after a long trip to STPR the next day I noticed my coolant was kinda low, then I noticed small puddle under the car. Later after driving it I could see it dripping at quite a fast rate. I tried to tell where it was coming from. There is a lower coolant line that runs into the waterpump? Which has some sort of gasket im sure, is there anything else there? Where is the thermostat? I plan on replacing the waterpump, gaskets and timing belt and all that, but won't be able to have the $$$$ to do that for a few weeks. I can't tell where exactly it is leaking from, it just pools on a bolt head and drips from there. I tried using some gasket gunk which seemed to stop it for a day, but its back. The weird thing is sometimes it does not drip at all and other times it pisses it out. Can you replace the gasket as a temp fix? where else would it come from unless the waterpump actually cracked. Thanks guys
SDEWYZ is offline   Reply With Quote
Old 06-15-2003, 10:03 PM   #2
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
I have this same problem, did you get it sorted out yet?
biggreen96 is offline   Reply With Quote
Old 06-16-2003, 10:34 AM   #3
SDEWYZ
Member#: 31352
98 RS
Black....for now
no not yet.....waiting for some advice......
Old 06-16-2003, 10:48 AM   #4
biggreen96
Member#: 12535
vf39 06 5MT XT
Old 06-16-2003, 12:55 PM   #5
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default thermostat
That's where your thermostat goes.
vvk is offline   Reply With Quote
coolant leak after new water pump garinhash Service & Maintenance 3 12-03-2009 01:03 PM
coolant leak passanger side Water jacket crossover pipe not8player Built Motor Discussion 11 10-11-2009 09:44 PM
What is this part 21116AA010 Water Pump Sealing rick-l Service & Maintenance 3 08-21-2008 09:06 PM
Anyone had their water pump seal fail? Plays_With_toys Normally Aspirated Powertrain 8 02-13-2008 08:45 PM
Coolant leak: Thermostat or Water Pump WRX.357 Service & Maintenance 0 04-21-2007 10:30 AM
