Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 02-19-2001, 07:48 PM   #1
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Talking SVX-T is back
Got the SVX-T back today. Still have a flat spot around 6000rpm's but the RRFPR will smooth that out.
The car is damn fast now. And because of that, I'm gonna need to get some new x-drilled rotors and carbon-fiber pads.
I'm hoping that Aaron and I can get the RRFPR installed Wednesday afternoon and get over to the track that night. If not, I'm going to try to go Saturday morning, if possible.
-kastle
kastle is offline
Old 02-19-2001, 08:51 PM   #2
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
From what I have seen from the SVX-T, I think it will be a close race with my RS-T. I think the 1st 1/8 will be all me and the 2nd 1/8 we be all Kastle.
Hopefully I can get a big enough lead on him to hold him off at the end and retain fastest Subaru in AZ title...
AaronB is offline
Old 02-20-2001, 09:37 AM   #3
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Post
Kastle,
How much boost are you running? What kind of 1/4 mile times are you expecting to run? Im excited!
Kevin Thomas is offline
Old 02-20-2001, 09:47 AM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
I'm running around 4psi normal now and hope that once I install the RRFPR, to move up to 5psi.
I'm hoping to crack into the 13's, but I won't know until later this week I guess. Maybe Wednesday night if I can install the RRFPR or Saturday morning if not.
kastle is offline
Old 02-21-2001, 01:41 PM   #5
Kevin Thomas
Member#: 110
1989 1989 XT6
Post
Do any of you guys have a video camera to record your 1/4 mile runs? No-one here is doing that and that would be awesome.
The next time I go to the track, Im hoping to record it so people can see what 13 second scoobies look like going down the track.
Old 02-21-2001, 01:45 PM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
AaronB and I are planning on taping his RS-T against the SVX-T once the SVX-T is running correctly. Maybe tonight, if not next week.
kastle is offline
Old 02-21-2001, 10:14 PM   #7
glenstiles
Member#: 2827
2002 WRX wagon
Silver, baby, silver
Post
Nice to hear that the SVX-T is back! Hope that the fueling issue is sorted out soon, don't want any blown pistons or such doing a quarter mile run. 13s, eh? Cool. How is the tranny holding up?
Glen
glenstiles is offline
Old 02-22-2001, 11:08 AM   #8
Kevin Thomas
Member#: 110
1989 1989 XT6
Post
How did the taping go last night *Jumping up and down*? When will you have it on the net so we can see it?
Old 02-23-2001, 12:00 AM   #9
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
Well, the car is still crapping out. It looks like we are going to try testing a different ECU in the car.
Maybe then I can run a 1/4 mile.....
kastle is offline
Old 02-23-2001, 11:39 PM   #10
blonde_man
Member#: 3283
Lightbulb
Just do what Shiv (Sport Compact Car magazine) did to the Project Impreza. He raised the fuel pressure, and then changed the fuel injector timing with an Apexi Fuel Controller I believe. With that setup and a turbo, he was able to get dyno verified 300hp from the STOCK 2.5RS engine with STOCK pistons (9.5or9.7to1 CR) and STOCK injectors. All he did to tune it was to install an Exhaust Gas Temperature gauge, and adjust the AFC to keep the EGT in safe range. With the two extra cylinders we should easily be able to get 300 hp, and maybe even get close to 400hp!!
So read up on the PROJECT IMPREZA (most of the info can probably be located here on the I-club), and get that SVX-T back on track! I believe Shiv also played with the timing, but that isn't necessary if you just want to get more fuel in to safely up the boost. Once you get things performing as much as possible like that, then you can squeeze even more power out of it by playing with the timing!
Good luck and have fun!
Eric
blonde_man is offline
Old 02-24-2001, 08:57 AM   #11
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
More likely than not, if the ECU doesn't work I'm pulling the plug on the project. I will use the vast amount of resources here and turbo my RS instead.
kastle is offline
HTML code is On
Guess who's back? Back again! C is back...tell a friend! -=C=- Off-Topic 29 06-01-2010 06:08 PM
The McRib is back! The McRib is back! athakur999 Off-Topic 65 01-26-2010 11:45 PM
girl on back of motorcycle is back - video! Shinkaze Off-Topic 31 03-01-2005 11:01 PM
The ghetto back... is back V6TurboTA New England Impreza Club Forum -- NESIC 59 07-21-2004 01:43 AM
SVX-T is now considered fast kastle SVX Forum Archive 5 02-08-2001 12:24 AM
