Old 06-15-2003, 04:44 PM   #1
agent007kimball
Member#: 14215
Default Should I replace my broken tranny with another stocker or upgrade to Sti Gears?
Here is the situation...
I have a 2001 Forester which I turbochraged a bit over a year ago. I am making 232 pounds of torque at the wheels and I am amazed the stock tranny has lasted as long as it has, however a few weeks ago, second gear finally gave out on me.
So I am torn between 2 options. I either get another stock transmission for about $900 + installation or I get rallispec upgraded sti gears which will cost me about $2200 which includes installation.
Should I go for the stock forester tranny which is cheaper and I could probably get 2 for what the sti gears will cost, or should I shell out the extra money and get the sti gears?
Any thoughts? What do you think are the benefits in getting one or the other?
Thanks
agent007kimball is offline   Reply With Quote
ok... my D70 broke, should i just get D70s or upgrade to D90 maramaralula Off-Topic 14 02-02-2009 03:30 PM
Stick with stock TD04 or upgrade to VF39 myselfaffliction Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 07-30-2008 05:47 PM
Hyrda EMS, AEM EMS, or upgrade to sti ecu/wiring harness 03SuBbYWrX Other Engine Management 3 11-27-2007 04:47 PM
Most economical way of replacing a broken tranny bren wrx Transmission (AT/MT) & Driveline 8 09-13-2005 02:36 PM
Should I use my TXS unichip with no ABC or an MBC instead? How will boost behave? rex n effect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-25-2003 12:10 AM
