Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 06-15-2003, 08:18 PM   #1
redrexx
Member#: 36568
02 sedona WRX gone
04' Silver STi in affect
Default Any CELs yet with new exhaust?
The WRX is a CEL happy fool. I know the TurboXS guys are CEL free with their STi, and Dan at Godspeed has no CEL either. Any of you everday consumers experiencing CELs after changing most of or all of the turbo-back?
redrexx is offline
Old 06-16-2003, 12:49 AM   #2
STi-ll chillin'
Member#: 36124
2004 WRX STi
Silver/silver
noob here. What does 'CEL' mean?
STi-ll chillin' is offline
Old 06-16-2003, 12:52 AM   #3
Scuba Steve
Member#: 35543
04 GT35R STi+E85
[email protected] @5800ft elv.
Check Engine Light.
Scuba Steve is offline
Old 06-16-2003, 03:00 AM   #4
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Default Re: Any CELs yet with new exhaust?
Yes, I got a Cat inefficiency CEL when I mounted my ScoobySport Turbo Back.
I studied the ECU wiring differences between the WRX and STi and moved my ScoobySport CEL eliminator over. No more CELs.
Russ
rlavalle is offline
Old 06-17-2003, 12:08 AM   #5
hatchy
Member#: 36852
2004 STI
Default Re: Re: Any CELs yet with new exhaust?
Is there a wiring difference?
Originally posted by rlavalle
Yes, I got a Cat eniffeciency CEL when I mounted my ScoobySport Turbo Back.
Russ
hatchy is offline
Old 06-17-2003, 02:02 AM   #6
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Default Re: Re: Re: Any CELs yet with new exhaust?
Yes:
Instead of the Yellow/Blue wire on plug 137/Pin 3, it's on Plug B135/Pin 6. Often called Plug 'B' in the manual.
The White wire is not plug 135/Pin 17... it's Plug B137/Pin 25. This is often called Plug 'D' in the manual.
Hope this helps,
Russ
rlavalle is offline
Old 06-17-2003, 02:19 AM   #7
hatchy
Member#: 36852
2004 STI
Default Re: Re: Re: Re: Any CELs yet with new exhaust?
It does. Thanks Russ!
Yes:
Hope this helps,
Russ
hatchy is offline
Old 06-24-2003, 06:56 PM   #8
Redneck Ricer
Member#: 21458
2011 Jeep
Smurf Blue
Yes:
Hope this helps,
Russ
I am having huge problems with hooking up my little grey box the diagram they gave me looks nothing like it! I emailed you, please get back to me if you can help me hooking it up
thanks!
p-rex
Redneck Ricer is offline
Old 06-24-2003, 07:28 PM   #9
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Here are some hopefully clear instructions...
The wire colors are the same, they're just in different positions on different plugs. Below is a diagram of the plugs with the wire locations circled.
Just connect the wires as described in the ScoobySport CEL Fix instructions, but use the wires in the below locations.
So far, no more CELs after this fix.
Russ
rlavalle is offline
Old 07-30-2003, 12:12 AM   #10
drewzter
Member#: 39879
2008 Infiniti G37S
Graphite # 73 FS
Unhappy Is MIL eliminator needed with TXS HE cat
I'm confused. I put on a TXS exhaust from the turbo on back with a TXS cat pipe and muffler. This is on my STi. I had help from a WRX enthusiast. We used a MIL eliminator. I got CEL. Dealer charged me to tell me that it was an O2 code. I could live with it but from what I am reading I should not have to if I am willing to invest a little more time and money. But I'm confused as to whether or not we should have use the MIL eliminator at all. My friend said it was made for '03 WRX and the Sti is obviously reading the sensor differently. But I am not catless so why did we put one on at all. Is it needed for the high efficency cat. I am thinking of removing the MIL eliminator and resetting. Any thoughts from someone more familiar with this issue. Thanks.
drewzter is offline
Old 07-30-2003, 12:16 AM   #11
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
I have Turboxs exhaust on STI, NO Cels
Remove the mil eliminator
Wombat North is offline
Old 07-30-2003, 12:32 AM   #12
WorldOne
Member#: 22731
2002 WRB Do-Luck GDA
worldoneperformance.com
The resistor that WRX enthusiast have always used on the WRX to free themselves of the CEL will not work on 04 and up impreza models. This is because as you mentioned the 04 reads the sensor differently.
There is a fix in the works, companies like Perrin are hard at work on plug and play 02 sims that will make the lights go away. In the mean time your only real option is to do something custom like those who have posted previously in this thread.
BTW, I have a catless TXS and have been CEL free for more than a month. This just goes to show you that the CEL is finikey at best.
CHeers,
WorldOne is offline
Old 07-30-2003, 01:15 AM   #13
drewzter
Member#: 39879
2008 Infiniti G37S
Graphite # 73 FS
Post Remove MIL elim.
CHeers,
So do you also think removing the MIL elim. from my catted system might stop the CEL? If it is the wrong one could it not cause the CEL?
drewzter is offline
CEL codes with new TMIC???????? Needles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-28-2005 02:17 PM
AP still got CEL, and getting new exhaust? drrice Newbies & FAQs 11 09-29-2005 05:27 PM
CEL on with catless exhaust JoeGengsta Newbies & FAQs 9 07-08-2005 10:25 AM
CEL flashing with new turbo and injectors.... trbowrx Engine Management & Tuning 9 07-03-2005 04:14 PM
CEL and 4000 redline with new Exhaust gazoline Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-10-2001 09:43 PM
