Old 06-15-2003, 10:47 PM   #1
legacy2003
Member#: 38338
2003 Outback Sdn H6
Default swap out auto for 5 spd manual in bd legacy?
anyone have any thoughts on this besides just selling my car for a standard? what do i need, how much does it cost, etc. anyone actually done it?
-mike
legacy2003 is offline   Reply With Quote
Old 06-15-2003, 11:20 PM   #2
Hiroki Tada
Member#: 8048
I think the general consensus around here is that it would be much more cost effective to just get another car. Im sure it'll save you the hassle of trying to find parts and then paying out hours in labour for a mechanic to do the swap.
Hell, you may find a car thats in better condition than yours for less than whay you maybe able to sell yours for.
Hiroki Tada is offline   Reply With Quote
Old 06-16-2003, 01:27 AM   #3
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
There's several posts in this forum and in the Suburu Conversion forum about just this subject. The three big component system pieces, excluding the transmission itself, are:
1) The pedal box and clutch master and slave cylinder to replace your existing brake-only box
2) The flywheel, clutch, pressure plate assembly and shift linkage (including the shifter surround for inside the cabin)
3) The ECU since the Auto ECU is set up to run the 4EAT TCU as well and this can cause you engine management problems if it can't "see" the TCU
The time to do it is not that exhorbitant. You could probably do it over a whole weekend if you were doing it yourself from after work on Friday until late Sunday night, providing you have the tools and every piece that you'll need for the conversion. You'd be be looking at probably 3-5 days of solid 8-hour a day shop time to have someone else do it unless they are intimately familiar with the conversion then they could probably do it in a lot less time.
Realistically, you're looking at $1-1.5K yourself and $2.5-3.0K to have someone else do it.
As was mentioned, it may be more cost effective to buy a car that's already set up the way you want it.
Good luck. Keep us posted.
Br, Dale
Subietonic is offline   Reply With Quote
Old 06-16-2003, 09:01 AM   #4
cardin555
Member#: 9972
2007 Jetta
grey
I know Cajual has been contemplating this also. He may have more info on this.
Cajual,.......where are you?
cardin555 is offline   Reply With Quote
WTB: 5 spd manual Trans for 98-01 RS 2.5 drewmob Private 'Wanted' Classifieds 10 06-28-2009 12:33 PM
oregon: 2005 Legacy gt Limited 5 spd manual pdx Nick 05 LGT Private Vehicle 'For Sale' Classifieds 10 06-19-2008 02:48 AM
needed in california 1994 subaru impreza 5 spd manual 2WD transmission DJNathan Drivetrain 1 08-21-2006 05:22 AM
5-spd manual vs 6-spd manual StuBeck Off-Topic 81 05-20-2005 12:12 AM
Tools needed for auto to 5 spd swap simpreza2 Transmission (AT/MT) & Driveline 3 04-16-2005 10:25 AM
