Old 06-16-2003, 09:42 AM   #1
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Default Ratio of a Legacy Turbo (TIN TY752VJ1AA) speedometer gear?
Hey there...
Anyone know the speedo gear ratio of the 1993 Legacy Turbo transmission (TIN TY752VJ1AA)? I'm looking to see if it's the same as the WRX, as my speedometer appears to be a little lazy by about 8% after my conversion to that tranny...
Cheers,
/Andrew
Kha0S is offline   Reply With Quote
Old 06-16-2003, 10:18 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Depending on where the speedo gear runs off of will probably affect things. I can look at the ratio when I get home, but more then likely they're going to be a little different.
Legacy777 is offline   Reply With Quote
Old 06-16-2003, 11:19 AM   #3
Kha0S
Member#: 8808
2011 WRX
DGM 5D
They're both tapped off the front diff, and both front diffs are 3.90... I haven't had a chance to confirm that my speedometer is reading low, but I suspect it...
I don't have the manufacturer shop manual for the Legacy Turbo, but I knew someone here would. Just let me know what the ratio is, and I'll move on from there.
Thanks!
/Andrew
Old 06-16-2003, 01:39 PM   #4
Legacy777
Member#: 4800
Thanks!
/Andrew
I sorta thought they were tapped into the front diffs......just wanted to check before I brought this issue up.
Actually the front diffs are different. The final drive ratio is the same, but the WRX has a 1.1:1 ratio in the front. Therefore the diff is going to be different. The turbo legacy did not have this "stepper" ratio.
I'll still let ya know what I find out when I get home.
Old 06-16-2003, 03:38 PM   #5
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Well, actually, the 1.1:1 ratio is the center transfer ratio in the WRX, and the rear diff is a 3.545 unit, while the front is still 3.9, which is the same as the Legacy Turbo unit.
Thanks for getting me the info whenever you get home... I'm so close to having this conversion at 100%... I just would like to have a slightly more accurate speedometer.
Thanks!
/Andrew
Old 06-16-2003, 04:30 PM   #6
Legacy777
Member#: 4800
Thanks!
/Andrew
edit: my bad....I got things mixed around. I took a look at some manuals.
Old 06-16-2003, 07:54 PM   #7
Legacy777
Member#: 4800
Book says
Speedometer gear tooth number (Drive/Driven) 29/9
Old 06-17-2003, 03:43 PM   #8
subarurabbit
Member#: 4083
2011 OB 3.6R
ding!
29:9 (didn't see the other post - did this from memory)
Roger
Thanks!
/Andrew
subarurabbit is offline   Reply With Quote
Gear Ratio of JDM 1992 Legacy turbo Tranny Cstmboxermotorsports Pre-2002 Factory Turbo Powertrain 12 03-26-2007 07:54 PM
Anyone know ratio of 5th gear in a Legacy SS? shemoves Legacy Forum 1 10-31-2006 07:17 PM
Pics of your Legacy turbo EJ22T Member's Car Gallery 6 11-24-2002 04:37 PM
Gear ratios and differential ratio for 95 legacy and 95 imprezza ciper Transmission (AT/MT) & Driveline 0 06-14-2002 07:58 PM
compression ratio on stock legacy turbo? wop Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-17-2001 09:27 PM
