Old 06-16-2003, 01:10 PM   #1
superg
Member#: 3385
Default Close ratio STi type RA gear set and 4.44
A quick review of the close ratio RA STi gear set and 4.44 conversion. Rallispec sourced the gear set and did the 4.44 conversion through a core exchange of my r160. Bret Carter at Flatirons did a magnificent job with the install. Observations after some fun in the canyons west of Boulder:
- This is an outstanding improvement over the stock gearbox. The ratios put you smack in the middle of the torque hump on each shift. Instead of the descending rpm, descending push from each gear, now each the engine is in the same rev range and the acceleration is much stronger. It makes a remarkable difference on twisty mountain roads. You just never get caught in a hole" like you do with the wide ratios of the stock box.
The shift pattern is a bit closer than stock. It takes some practice and muscle memory to avoid over-reaching from 2nd to 5th instead of 3rd.
On the ride home on interstate, enjoyed the immediacy of 4th and 5th and didn't miss the stock 5th cruising/downhill gear at all. If your "special stages" involve lots of flat interstate, you might think it is too short.
BTW, installed an MRT downpipe/midpipe and hi flow cat at same time. Nice improvement, but overshadowed by the gearing improvement. STill, the exhaust really bellows in the canyons!
Superg
superg is offline   Reply With Quote
Old 06-16-2003, 01:41 PM   #2
GreenMarine
Member#: 36080
That's pretty cool..... Maybe you can help me answer my tranny questiuon that I have about the 5MT from 2003 and 2002....
GreenMarine is offline   Reply With Quote
Old 06-16-2003, 02:22 PM   #3
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Are you reusing the old synchro?
bemani is offline   Reply With Quote
Old 06-16-2003, 05:14 PM   #4
superg
Member#: 3385
Default Synchros
Synchros were replaced on warranty about a month ago due to 2nd-1st synchro gone (no longer able to downshift while moving, even with double-cluth, rev-match).
Superg
Old 06-18-2003, 01:12 AM   #5
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
So you're pratically using brand new synchros. Nice timing
How much did your mileage got worsen by?
I was thinking of doing just the 4.44 conversion so the ratio would be the same as JDM WRX, but that doesn't seem too cost effective since I'll have to pay someone to open up the tranny anyway, but replacing the gears would be around $2k more, which I don't want to spend the moeny for
Old 06-18-2003, 03:56 PM   #6
virpacalis
Member#: 19214
'07 STI
in the slow lane
superg: What rpm do you have at 80 mph in 5th?
virpacalis is offline   Reply With Quote
Old 06-19-2003, 01:49 AM   #7
mojo
Member#: 25391
2002 WRX Wagon
Hey Superg:
I've been considering the STI RA gears at 3.9 or 4.44 on a similarly modded WRX. Glad to finally see someone do it with a 4.44 and post results. I'd assume an 80 mph freeway cruise between 4000-4500 rpms? Sounds like some $$ saved by changing out the internals of your regular rear diff versus a new rear diff? How much did this project cost, realizing your cost might not be mine? What was the down-time? Any need to change transfer gears? PM me if you don't want to post specifics to the board--and if you might entertain another question or two. Thanks for any help.
John
mojo is offline   Reply With Quote
FS: 05 WRX Tranny w/ Ver6 STi RA Gear Set and ACPT Carbon Fiber Driveshaft luspeed SCIC Private Classifieds 14 05-14-2009 04:05 PM
STI type RA gear set. RacerX1 Transmission (AT/MT) & Driveline 1 05-03-2007 06:19 PM
STI Type RA Gear Set DoDO Brown Private 'Wanted' Classifieds 0 09-05-2005 11:39 PM
will sti type ra gear set fit in 2000 2.5rs billyr2.5 Transmission (AT/MT) & Driveline 2 04-02-2004 08:36 AM
where to buy type ra gear set BlackWagon Transmission (AT/MT) & Driveline 2 03-25-2003 11:48 AM
