Old 06-16-2003, 05:01 PM   #1
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Question EJ22 turbo w/EJ20G heads?
ok, been reading alot of info on replacing the stock 2.2 turbo heads...unfortunately the info is reguarding 2.5L or 2.2L heads
has anyone used EJ20 heads (not from USDM motor) on their 2.2 turbo block?
which gasket to use?
compression ratio change?
thanks for any help
Alan
Scoobyslack1 is offline   Reply With Quote
Old 06-17-2003, 02:16 AM   #2
Unsung Boxer
Member#: 37196
I have always wondered if there is some hardcore proof of difference in flow through heads.
Subaru must have felt it sufficient to use Single port heads, and thus so do Chicksdigwagons and I. I personally feel that money is better spent elsewhere in your turbo project.
I am soon to turbo my EJ22 w/ SOHC Single Port heads... w/ EJ22t Block Internals, o-ringed. I will let you know what my results are. If it ends up being super low flowing, likely my major problem will be getting the turbo to spool. We'll see
Unsung Boxer is offline   Reply With Quote
Old 06-17-2003, 07:58 AM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Obviously Subaru did it to save money. I've been told by a very good tuner that even the dual port is a half-baked solution, when there is an immediate s-curve right off one of the cylinders before it even gets to the exhaust manifold (where the y-pipe is also another compromise).
And I completely agree that money is better spent elsewhere to get power.
Good luck with your project. I'm curious to know if your heads will mate up with the block as poorly as mine did at first.
wac is offline   Reply With Quote
Old 06-17-2003, 12:30 PM   #4
Scoobyslack1
Member#: 2780
junk yards rule!
ok........
this would also be going from SOHC to DOHC, I would be getting everything from the heads up, intake manifold, throttle body, fuel rails, STi injectors and cams/cam gears.
still has anyone done this?
I'm going to do this regaurdless of the single-dual port debate, I'm just looking for info.
again:
which gasket?
which timing belt?
I found a little more info, but mostly about USDM EJ20 heads on the EJ22 block.
Not sure if the volume of the heads is the same, JDM(old) vs. USDM(new).
If it is I will need a thinner gasket than the 2.2 uses stock.
Old 06-17-2003, 05:02 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
timing belt ...
dunno but i am using a 98 timing belt. sohc and dohc are the same for 98
Old 06-17-2003, 05:17 PM   #6
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
I'm going to do this regardless of the single-dual port debate, I'm just looking for info.
Check into your 2.0L turbo idle circuit, since that carries along with the intake manifold. It may be different from the 2.2L turbo idle circuit, depending on model year.
Old 06-17-2003, 05:38 PM   #7
Scoobyslack1
Member#: 2780
junk yards rule!
Default thanks for the warning...
well we got '96 1.8L wiring to work with '93 2.2L motor...we can make it work
Old 06-17-2003, 08:31 PM   #8
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
I believe you will have to use the new WRX Timing Belt...You have to think about Piston/Valve contact...Claying the Combustion Chambers may be neccessary....
Zee
Sunrise City Rider is offline   Reply With Quote
Old 06-17-2003, 08:45 PM   #9
Unsung Boxer
Member#: 37196
dont get me wrong, i support you on the swap, I just wouldnt do it myself because i dont have the excess time or money.
Im sure it will work fine assuming that you are using all the ej20 head parts... I think even the ej20 timing belt.
You might also run into injector problems.
Old 06-18-2003, 09:24 AM   #10
Scoobyslack1
Member#: 2780
junk yards rule!
Lightbulb
the injectors should be the least of my worries...since I will be getting the fuel rails w/it all
Old 06-18-2003, 11:21 AM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm i guess i ned to say this differntly
the timing belts are ALL the same..
Old 06-18-2003, 11:47 AM   #12
Scoobyslack1
Member#: 2780
junk yards rule!
Thumbs up
thanks....
Old 06-19-2003, 01:30 AM   #13
Unsung Boxer
Member#: 37196
I meant more along the lines of the ECU controlling the injectors. If you dont have the turbo, they will run way rich, w/ the turbo, you will have the wrong fuel map. Basically u need fuel managment.
In addition, u might want to look into this. I was told that the EJ22/25 IACV plug is different from that from the WRX, which would be on the WRX intake mani. If using the EJ25 ecu, this will likely be a problem. If you use the WRX ecu, u will have to rewire everything.
Old 06-19-2003, 10:06 AM   #14
Scoobyslack1
Member#: 2780
junk yards rule!
I already have a Link+ running my Legacy turbo motor
Team ARG!
Old 06-19-2003, 04:21 PM   #15
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
This is basically what I am doing but with the diffrent motor. Of course I am a moron and I doubt I could answer any of your questions. But... You know who could. So mabye he might have some good input for you.
Just wanted to give ya a heads up.
-Neal
DoctorNick is offline   Reply With Quote
EJ20G Power Stuff, Turbo, BPV, TMIC, Heads, etc. DSM_Outback 1993 - 2001 Impreza Specific Parts 39 05-26-2009 11:39 PM
EJ22e block + EJ20G heads....compression? Numbchux Built Motor Discussion 23 02-23-2009 01:27 PM
FS:(GA) EJ22 turbo heads, $150 OBO subyboy Engine/Power/Exhaust 1 09-07-2008 01:07 AM
What will be better for an n/a ej25/ej22 hybrid? ej22 or ej22t HLA heads? lotus2843 Subaru Conversions 4 08-09-2005 03:13 PM
Ej22 turbo Block With STi heads? TheWRXMan Subaru Conversions 5 06-05-2004 01:47 PM
