Old 06-16-2003, 05:53 PM   #1
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
Default Perin underdrive pulley
Was wondering if anyone knew how to get a Perin underdrive pulley off. What's the trick or is it just brute force?
ac_gohan is offline   Reply With Quote
Old 06-17-2003, 10:40 PM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Put a breaker bar on the socket wrench, place the socket on the crank bolt, and set it so that the end of the bar is against the ground on the battery side of the motor, unplug the wires to the coil pack, and crank the motor 1 revolution with the starter, having a friend hold the breaker bar in place.
Make sure your friend wont sue you in case he get's hurt.
Or, Have your friend wedge a screw driver into the flywheel teeth through the access port at the top of the bell housing so the motor wont turn, and you crank the breaker bar with your own strength.
ImprezaRS dot com is offline   Reply With Quote
Old 12-11-2005, 11:20 PM   #3
Crazy D
Member#: 35927
02 wrx
.........or you could use a chain wrench...
Crazy D is offline   Reply With Quote
Old 12-12-2005, 05:14 AM   #4
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
when I did mine, I just let the car in gear, put a ratchet on in, and gave it a swift hit with a hammer. Off it came.
EcksJay is offline   Reply With Quote
Old 12-12-2005, 05:31 AM   #5
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
i left mine in 5th gear, and used a 2ft breaker bar. once the bolt is out, tap the pulley w/ a soft hammer. it should come off really easy.
jam69007 is offline   Reply With Quote
Old 12-12-2005, 05:43 AM   #6
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru Stars
In my experience fitting alloy-underdriven pullies, I ALWAYS used loctite or simillar. Using the screwdriver on the ring-gear/flywheel is good, just don't snap the end off your screwdriver like one of tech's did and not tell anyone...then when he started the Engine it put the broken piece of screwdriver through the diff housing from inside the bell housing!!!
Also, it's nice when the gearbox holds up to loosening the Crank pulley bolt, but when the 5th and Rev nut/Mainshaft nut lets go, (cos it was already loose-and making a slight noise in 5th on light throttle ), you will not enjoy this method. I think the safest way, (mechanically speaking), is to do the breaker bar on the ground thing. Having said that, I made my own 'strike-spanner', out of a 22mm socket with one 'flat' of the drive side cut out at 90 Deg. Then I welded a 10" 1/2" drive extension bar to it and put an EA82 Head stud in later when it started to bend!!! I am still using this tool to loosen crank bolts on ALL sorts of vehicles!!
Years later I was looking through the Stahwille ctalog and saw the 'Strike-Spanner' on sale....and that was when I named It!!!!!
Sixpack(admires tool and years of scarring.... )
sixpack subaru is offline   Reply With Quote
Old 12-12-2005, 05:43 AM   #7
sixpack subaru
Member#: 64974
Don't ask about re-fitting/torquing the bolt!!
Underdrive pulley vs Lightened pulley sc00ter Newbies & FAQs 21 05-20-2008 08:20 PM
Underdrive Pulleys/Lightweight Pulleys UGotBoost? Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-22-2003 10:32 AM
Underdrive pulleys AND lightened pulleys? jhayzhon Normally Aspirated Powertrain 1 10-10-2001 07:50 AM
('93-'01) Short throw shifter or Underdrive pulley? Opinions needed! Robmat Impreza Forum 11 05-21-2001 12:56 AM
Unorthodox Underdrive Pulley / Belt kits for SVX Boxer4Racing SVX Forum Archive 21 02-18-2001 06:36 PM
