Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 06-16-2003, 06:15 PM   #1
GameMastyr
Member#: 31788
2003 Impreza TS-T
Blue Ridge Pearl (dead)
Default Smoking turbo
Recently I purchased a used turbo kit and upon the first installation of the kit the car has been smoking. The shop that I have working on the car said it was because the turbo seals were leaking and they had a spare center housing for the turbo and they used that to rebuild the turbo with the new center housing. Well, I got a call from them today saying the turbo is still smoking and that I need to purchase a new turbo or have mine rebuilt. Of course they're more than happy to sell me a new turbo for $500.
Does anyone know what could cause this or if thats a common occurance? I checked the oil draining and it seems to be fine...
But someone said that since i don't have the tubes that were going to the old air air box rerouted into the new air intake I could be causing a positive pressure in the oil pan causing a back pressure that could be preventing the oil from draining into the pan. Do you think this could be the case? Or is it just more likely that the turbo is shot?
Please if you have ANY other ideas feel free to share. I've been without my car for way too long as it is.
Thanks.
GameMastyr is offline   Reply With Quote
Old 06-16-2003, 08:17 PM   #2
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
When i installed my turbo, it smoked from the turbo. But it was an oil leak from underneath the turbo from the oil return line and it was dripping onto the headers. You should go and smell the smoke and take a look at it yourself. The oil leak was hard to spot but that was the reason why it was smoking from there. It can also be an exhaust leak.
Derk1127 is offline   Reply With Quote
Old 06-16-2003, 08:21 PM   #3
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
What kind of turbo is it and which shop did you bring it to?
Turbotegra is offline   Reply With Quote
Old 06-17-2003, 02:52 AM   #4
GameMastyr
Member#: 31788
2003 Impreza TS-T
Default ...
The turbo is a Garret T3 and it's currently down at Rallitek. Rallitek is where the car is but most of the work is being done by a place called GPMoto. They're good people but still I don't want to get a new turbo and have the same thing happen.
Old 06-22-2003, 04:09 PM   #5
Giamilton
Member#: 8002
2013 WRX 5dr/Abarth
WR Blue/Nero
brrrrrrrt
Giamilton is offline   Reply With Quote
smoking turbo? infinitwrx Engine Management & Tuning 4 02-23-2004 01:48 AM
!Smoking Turbo! Please Help Me vsboxerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-17-2004 10:15 PM
White Smoke, turbo or engine failure? subywrxwrblu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-09-2003 06:35 PM
Losing/burning coolant occasional smoking turbo ctrexer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-25-2003 04:20 PM
smoking turbo dubluv17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-24-2002 04:05 PM
