Old 06-16-2003, 09:46 PM   #1
tulit
Member#: 338
09 STi
Unhappy Leaking Oil Return
My stuff has been on my car for about 2 weeks now, all was fine.
Today I noticed the oil return tube, where its welded to the pan is leaking oil. This was a brand new pan from Ludespeed.
Any ideas on how I can fix this (hopefully without having to remove the whole pan again ) . Ive temporarly patched it with some RTV sealant (All I had) to see if it can stop the leak at all.
tulit is offline   Reply With Quote
Old 06-16-2003, 11:02 PM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Exclamation
How bout some JB Weld? Just make sure you clean the area real good before applying it.
Wedge is offline   Reply With Quote
Old 06-17-2003, 12:17 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I've used JB Weld for that before as well. I found out later that the rear freeze plugs on the pass side of the motor (behind the flywheel) was leaking instead. Drove me nuts for ages until I got that figured out and pulled the motor to fix it (and install my kit again).
Old 06-17-2003, 09:32 AM   #4
Avenger
Member#: 1234
I got RTV on mine for a year now and it works great.
Avenger is offline   Reply With Quote
Old 06-17-2003, 11:59 PM   #5
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default They all do that
The weld fails when you screw the fittings in to the tube, from flex.
The only way to (fix) it is to re-weld it and why your at it, add a brace from the tube to the pan. Better yet cut the tube down to a nub and weld that on and zip tie the oil line so it dosen't get damaged.
Or, you can RVT it like I did. (over a year)
milkman is offline   Reply With Quote
Old 06-18-2003, 01:17 AM   #6
Mancini
Member#: 20726
RTV will work if you don't mind it being ghetto. That stuff is amazing...it's like cement after it dries!
I actually used it instead of exhaust gaskets for my up and down pipe...
Which has since burned up and failed
The good news is it's barely noticable with my MASSIVE exhaust leak ala wastegate dump
Mancini is offline   Reply With Quote
Old 06-18-2003, 09:43 AM   #7
Avenger
Member#: 1234
You shouldn't use RTV on your exhaust, I will damage the O2 sensors. Happened to me except my RTV never burned up because it was a really high temperature one.
Old 06-18-2003, 12:24 PM   #8
Mancini
Member#: 20726
Interesting, didn't know that. Definately won't be doing that anymore.
Old 06-18-2003, 04:47 PM   #9
milkman
Member#: 8066
Y2K RSt
What the ----- who you calling ghetto? I think of it as resourceful.
I had my pan re-welded 2 times and JB weld on it. The RVT has held for over a year. You have to clean the pan and pipe really good with rubbing alcohol for it to seal.
Old 06-18-2003, 06:25 PM   #10
Mancini
Member#: 20726
No shame man, like I said RTV is some serious stuff. I used it on almost everything which has turned out to not be so smart...
But for all my intake stuff and my oil return line its just plain peachy. Actually, I used a bulkhead fitting instead of getting a weld fitting put on the pan...I just globbed some of that stuff on there and tightened her down realllll good. I did that back in Dec. and it hasn't leaked a drop!
oil return from turbo leaking..help! fliped wrx Subaru Conversions 1 07-02-2008 04:00 AM
oil return line leaking ALaDDiN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-27-2006 02:18 PM
Advice for leaking oil pan return tube (ludespeed pan) ilmaestro Normally Aspirated with bolt-on Forced Induction Powertrain 32 06-06-2004 06:45 PM
SS braided oil return line leaking? rhdude Normally Aspirated with bolt-on Forced Induction Powertrain 6 08-01-2003 04:57 PM
More WRX oil pan on a RS pics /w turbo oil return Revision Normally Aspirated with bolt-on Forced Induction Powertrain 0 09-08-2002 04:40 PM
