Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 02-19-2001, 07:57 PM   #1
KEVINL
Member#: 3525
2004 Duramax W/500HP
And Want another STi
Post SVX BRAKES
I just bought two sets of VGX both front and rear brake pads for my SVX. My SVX is almost to the point of dangerously long stopping distances. Anyways I have these brakes on the front of my 1988 RX and they are awesome So I'm hoping this makes the SVX stop on a dime. I know Kastle can't stop his Turbo SVX so maybe these brakes are the answer to SVX braking issues. I will install them ASAP and keep everyone posted
KEVINL is offline
Old 02-19-2001, 08:06 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
I am planning on getting some carbon fiber pads and x-drilled rotors from Dale @ Motor Sports Warehouse down in Tuscon.
It's gonna cost me around $350 though for all the stuff.
kastle is offline
Old 02-19-2001, 09:45 PM   #3
blonde_man
Member#: 3283
Cool
Good luck. High-performance pads with cryogenically treated rotors are the way to go.
Drilled rotors are really just for looks, and can in fact make braking worse. When you drill holes, you are taking away mass that could otherwise have been available to absorb heat. This can make the rotors even more susceptible to warping. Also improper drilling can weaken the rotor making it even more prone to cracking. You're going to be replacing rotors more often if you use cross-drilled. If you have the money, and like the looks go for it. Just remember it's just looks, not performance. Even the new Porsche Turbo guys complain about their cracking drilled rotors. If Porsche can't get it right, then no one can! That's why they are now developing a new aircraft stopping strength, ceramic brake system.
A better alternative would be to get slotted rotors. Slotted are much stronger than drilled, and preserve more rotor mass. They are also good in wet situations, and still address outgassing like crossdrilled. They should have a long life, and if cryo treated, they will last even longer! Plus slotted rotors look cool too! They talk and walk!
For more information on cryo treated brake rotors for the SVX check out these sites:
http://appliedrotortechnology.com/default.htm
http://www.frozenrotors.com/
Enjoy!
Eric
blonde_man is offline
Old 02-19-2001, 10:03 PM   #4
AZ-GT
Member#: 192
2011 WRX
WR Blue
Post
So you are only upgrading the front brakes. Which makes sense but I'm just curious. I accidently used my dads screen name. I just saw the aluminum dash kit for the SVX. I think I will be getting that real soon
[This message has been edited by AZ-GT (edited February 19, 2001).]
AZ-GT is offline
Old 02-19-2001, 10:06 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
Just the fronts. Since that is where the vast majority of breaking goes on.
kastle is offline
Old 02-19-2001, 10:12 PM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
I knew I had some information from those sites:
From Frozenrotors.com
1992 Subaru SVX:
Front treated rotors $202.00 ea.
Gas slotting $45.00 ea.
From ART Rotors:
The front set of pads and rotors is $345.00. The rear set will cost $300.00.
I forget if the ART's were slotted or not, but I think they were. I sent them a email asking.
kastle is offline
Old 02-20-2001, 08:06 AM   #7
CRZ_MSL
Member#: 1610
Post
I had non-CD rotors on my car.
I cracked them.
Cracked rotors "sing" when you brake and they are cold.
Cracked rotors "chatter" when you brake and they are hot.
Very scary.
I put CD rotors on my car.
That was almost 60,000 miles ago.
I am a very happy camper.
No more warped rotors.
What blonde_man wrote is technically correct, but may not be the entire story.
Don't forget about decreased braking surface area, and increased heat radiating surface area.
My CD rotors have been good to me.
Your mileage may vary.
CRZ_MSL is offline
Old 02-21-2001, 08:00 PM   #8
svxboy
Member#: 3220
Post
Hey Kastle, The ART rotors are cross-slotted, and probably the best deal for the money. Greg
svxboy is offline
HTML code is On
Part number for SVX non-abs brake mast. cylinder? linsavy Brakes, Steering & Suspension 2 06-11-2007 03:41 PM
Wanted GC8 2.5 rs Brake system and SVX brake System stevos758 Private 'Wanted' Classifieds 1 07-26-2006 02:03 PM
svx brakes on GC impreza nomadtw Brakes, Steering & Suspension 4 05-21-2005 03:38 PM
STi brake conversion on my 1992 SVX svx92sti Brakes, Steering & Suspension 4 03-15-2005 05:10 PM
Brake band adjustment - Legacy and SVX models CRZ_MSL Normally Aspirated Powertrain 0 02-10-2001 12:24 AM
