Old 06-17-2003, 03:39 AM   #1
scubaracer
Member#: 4909
1992 legacy 2.2Turbo
silver sports sedan
Default ej22t/ej25 hybrid!
first, i own a legacy turbo which has the ej22t closed deck motor.
Okay fellas, i know i can use the ej25 crank and rods to increase my displacement to 2.35l up from 2.2. i also know that if i use ej25 heads, the compression will drop to about 7.7:1. now, correct me if i am wrong, but my closed deck 2.2 can be overbored quite a bit. i.e. up to a 2.5l.
question........Can i use the 99.5mm 8.5:1 JE forged pistons?
this would be with a phase 1 crank and pauter rods and ej25 heads/cams. will it work? what will my compression ratio be?
i think it will be around 8.2:1. can someone help me calculate it?
thanks guys.
scubaracer is offline   Reply With Quote
Old 06-17-2003, 06:14 PM   #2
morpheous
Member#: 37122
94 legacy
According to the hanes manual you can only bore the t.Leg block .020 over. beyond that the cyl. walls will get to thin.
In order to get 2.5l from the t. leg block you would have to have it sleeved and bored for the 2.5 pistons.There is no way you would be able to bore the t.leg block 4mm. the cyl. walls would take a s**t.
What i am contemplating on dfoing to my t. leg block is to make almost a 2.4l which keeps the t.leg's original bore 97mm plus
PhI 2.5 crank and rods and custom pistons.
Doing some research i have come to the conclusion that even though the 2.5 PhI rods/t.leg rods have the same small end diameter you cant use the t.leg pistons. Why? yes they will fit on the 2,5 rod but the piston will pass the deck at TDC.
this is so because the 2.5 crank has a longer throw and the 2.5 rod is also longer than the t. leg rod.
-Jose
morpheous is offline   Reply With Quote
Old 06-17-2003, 06:44 PM   #3
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
97mm bore with 79mm stroke is 2.33l
morpheous is spot on with rod length and piston height.
EJ22 block will take a sleeve for a 99.5 or 100mm piston, but it's expense. Plenty of people I know are going the 2.33 route, it's a good compromise of capacity and cost.
You should be able to get pistons with a custom pin height in the 97mm size, that are suitable for a EJ25 crank and rods. I beleive Cobb can source the pistons you want in this respect, and can get them dished for whatever heads you choose.
I would fit uprated rods while you're at it though
Paul
Pavlo is offline   Reply With Quote
Old 06-18-2003, 02:25 AM   #4
scubaracer
Member#: 4909
silver sports sedan
okay, cool. that was the original route, so i will stick with that one. i will just get 2.5 crank and rods and have custom pistons 97mm. yeah, i never planned on using stock pistons.
the 2.5l was just an idea, but yeah, it would probably cost a whole lot more. 2.33l is good.
Old 06-18-2003, 07:05 PM   #5
Pavlo
Member#: 23015
95-> GC8
THe EJ25 block is good for about 450 crank hp in open deck form if you're interested.
But the EJ22 closed deck block can always be sleeved at a later date if/when you feel you can afford the work.
Paul
Old 06-18-2003, 08:15 PM   #6
morpheous
Member#: 37122
94 legacy
Pavlo,
Starting off with the same displacement,what do you think would be a more reliable engine, a sleeved 2.2 or a PHII 2.5? which one will withstand more power?
The obvious PHII pros are that the PHII has the better main center bearing, and the crank rod journals are larger.ON the cons side it is not closed deck which causes blown headgaskets.
How's your motor coming along? I saw the pics you posted a while back you had the deck welded and milled. Is this you?
-Jose
Old 06-20-2003, 11:34 AM   #7
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
the 2.2T will hold up much better under high boost then the 2.5 will. due to it being a semi closed deck, and the way it was cast.
Old 06-20-2003, 01:25 PM   #8
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Any issues using '98 DOHC 2.5l heads with the 2.2L block? This is a combo I am contemplating. OR possibly the DOHC heads on a 2.5L STI block, either would be pretty bad ass.
Sounds like compression ratio would be pretty low with a 2.2L block and 2.5L heads, I suppose a thinner HG could be used to raise the CR ratio, anything else besides new pistons?
Compressed is offline   Reply With Quote
Old 06-21-2003, 12:04 PM   #9
Pavlo
Member#: 23015
95-> GC8
Morpheos,
I wouldn't like to say which is more reliable. But given the choice of an open deck EJ25 and a closed deck EJ22, I would go with the 22 for a high boost motor.
If you can get an EJ25 crank, I think that's a pretty sweet setup, and one that a number of my friends are trying (motors to be running in the next few weeks).
Yes it is me with the welded and milled block. I had some setbacks with the heads, I have had 2 sets of EJ207 heads now, and finally have some that I either haven't ported and sold, or aren't cracked.
I have PAR billet rods, JE custom spec pistons (via Cobb), ACL tri-metal bearings, head studs, custom cams, ported heads, Garret turbo etc etc. I'm getting the valve seats cut now, then I have everything ready to assemble.
With my limited available time, I would like to have the engine in the car in 3 weeks, will be tight though.
Paul
Old 03-10-2007, 11:39 PM   #10
xxbrycityxx
Member#: 143060
So I was on 25rs club, and nobody knew anything about a ej22t with an ej25 head. Is it a good idea, or would I be better with a WRX engine?
xxbrycityxx is offline   Reply With Quote
Old 03-12-2007, 04:09 PM   #11
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Replied to your thread on RS25.
Wedge is offline   Reply With Quote
Old 03-13-2007, 08:34 AM   #12
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Just to let you know only the Phase I EJ25 cranks use the center main thrust. The Phase II blocks are rear main thrust.
Another big difference, that can be seen on Pauter's website: http://www.pauter.com/subaru.htm
is that the Phase I EJ25 rods have a larger big end bore then most all other subaru motors.
The DOHC heads should be great to use. My motor is almost done. The shortblock is assembled but my heads still need to be assembled/adjusted and mated to the SB.
My shortblock is a bore .020 EJ22turbo closed deck block with Wiseco (off the shelf) .020 over pistons, Pauter EJ25 Phase I Forged Rods, and Phase I EJ25 crank. Thats right Wiseco stocks pistons that are specifically designed for this hybrid setup. I hadn't looked at skirt length but I assume they are built to work with the increased rod length. As well the piston crowns are milled with valve reliefs in order to not interfere with the heads. Compression is 8.5:1 if used with stock T-Legacy heads. I believe it would be closer to 8:1 if used with EJ25 DOHC heads.
My heads are EJ25 DOHC with TWE Stage III cams and Shim Under Bucket Conversion w\ stiff springs and titanium retainers. I'm waiting for valve job and port and polish work because Ive heard low end response greatly diminishes when you open the heads up that much. I will probably do it when that becomes a restriction to my power goals.
MY99 2.5GT is offline   Reply With Quote
EJ20, EJ22T, Ej25 headers all the same? Mechkiller31st Built Motor Discussion 10 05-18-2010 01:20 PM
2000 EJ25 SOHC heads/EJ22T block hybrid - compatibility issues? Which parts to use? burtonsnowman Built Motor Discussion 21 02-12-2010 01:59 AM
VF22, FMIC, Utec, 3" Exhaust, Griffin Radiator, ej22t, ej25, and more eastcoastbumps Engine/Power/Exhaust 11 01-07-2007 01:32 PM
WTB: Water pump...EJ20, EJ22T, EJ25 STi Kawikid20o2 Private 'Wanted' Classifieds 4 12-14-2005 11:44 AM
WRX items for sale: Walbro, Rice, EJ22T, EJ25 n2xlr8n Private 'For Sale' Classifieds 9 12-19-2003 06:32 PM
