Old 06-17-2003, 04:41 PM   #1
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
Default L--->RS cluster?
ok so i have the complete RS interior swap , im wondering if i can just use my own L cluster or if i need to use a RS cluster ? whats the wiring like if i decide to go to an RS clusteR?
cindergarden is offline   Reply With Quote
Old 06-17-2003, 05:20 PM   #2
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
I'm not sure, but I replace my gauge cluster w/one that had a tach, took 10 minutes.
does your cluster go to 140mph or 120mph like the RS?
I'd keep the 140mph cluster, if you have it, gives you hope that you get there
Scoobyslack1 is offline   Reply With Quote
Old 06-17-2003, 06:25 PM   #3
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
was it just plug and play or do i need to rerun wiring
Old 06-18-2003, 09:30 AM   #4
Scoobyslack1
Member#: 2780
junk yards rule!
Lightbulb
mine was L to L model basically.....so just plug-n-play
I think the RS uses a electrical speedo, my car has a mechanical one as do most Ls
Old 06-18-2003, 10:07 AM   #5
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
anyone know how i would go about converting this ? i know i need both wiring diagrams but then what do i do with em
Old 06-18-2003, 06:09 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Eby put a WRX cluster into his MY94 L. It is not a direct swap both physically and electronically. You would need to convert your tranny to use an electronic speed sensor and then wire it up to the car. Then you next problem is that the dash changed after 1996 and I _think_ they have different gauge cluster dimensions. Eby had to use bondo to get his WRX cluster to fit properly. I can't recall anybody putting an RS cluster in and reporting their experiences.
-Jon
Old 06-21-2003, 01:37 PM   #7
avk
Member#: 17252
'06 WX8
59E
I believe the cable driven speedometer was replaced with electrical on 1997 models. Scoobyslack, can you tell what you did to disconnect the speedo? I had my cluster out to add an AT shift indicator from a '93. On the speedo cable before the end socket, there was a plastic cylinder with rubber boots at both ends. I thought maybe it was some kind of quick disconnect but couldn't make sense of it. So I had to pull on the socket. It was on tight and I had to be careful not to brake things, so it took a lot more than 10 minutes.
avk is offline   Reply With Quote
Old 06-22-2003, 02:32 PM   #8
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Electronic speedo first showed up in the 1998 models with the new interiors - the one with the extra storage compartment on the dash that you can mount a gauge pack.
wac is offline   Reply With Quote
Old 06-22-2003, 10:21 PM   #9
avk
Member#: 17252
'06 WX8
59E
I test drove a '97 L wagon with an LCD odometer and assumed the speedo was electronic. If it was, maybe it depended on the transmission type. That one was automatic.
Old 06-23-2003, 02:08 AM   #10
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
mine now is a 94 5spd L cluster hte new one would be a 2001 5spd RS cluster
Old 06-23-2003, 11:12 AM   #11
RSimport
Member#: 24718
05 impreza RS
white
I have a 96 without a tach would this still have a plug for my tach or do I need to install a wire harness and everything to put one in?
RSimport is offline   Reply With Quote
Old 06-23-2003, 12:02 PM   #12
AKGC8
Member#: 1305
2000 Impreza
Yea I did the WRX gauges into my L allong with my WRX drivetrain conversion. So I've got the WRX electronic speedo.
What I'm not sure about, but have a feeling may work is putting an RS electronic speed sensor in place of the mechanical transmitter used on the L's. Then just sending wires to both the new RS cluster and the L's ECU(the ECU gets a tach signal from the cluster in the L).
The wiring was a piece of cake on my WRX cluster, so the RS shouldn't be any worse. You do have to rewire everything, but basically all the wires are there that you need(besides that speed sensor) so it's just a matter of matching them up.
AKGC8 is offline   Reply With Quote
Update a 2002 WRX Gauge Cluster with 2004 Cluster DamonL Electrical & Lighting 8 03-26-2010 05:04 PM
EJ20G swap-->RS Sean2.5Black Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-01-2008 01:18 AM
JDM GC8 STi cluster -> USDM car, need a harness or pinouts on the cluster no-coast-punk Subaru Conversions 11 07-29-2004 02:34 PM
WRX cluster in RS cluster?? 03imprezaRS Subaru Conversions 1 05-05-2004 07:30 PM
L-->RS Front bumper question soccerguy888 Interior & Exterior Modification 2 09-29-2003 01:59 AM
