Old 06-17-2003, 04:59 PM   #1
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Default compression test numbers
what kind of compression numbers should i be looking for
a compression test yielded
1 125
2 114
3 130
4 125
2 is lower than the rest but the big question is are ALL the cyls lower than they should be
Old 06-17-2003, 06:51 PM   #2
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
2002 Dragon slayer :)
Yep. You should NOT see anything less than 168psi or more than 178psi (+/- 2psi). Your engine is losing some compression. Did you beat on it when you bouht it? The rings don't usually sit good on the cylinder walls if you really beat on the car while it's still under 500 to 1000 miles.
~Anthony.
WRX 555 STi is offline   Reply With Quote
Old 06-17-2003, 06:53 PM   #3
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
Oh, i didn't see you have an EJ20 (?). In that case, i don't really know those numbers. I thought this was an RS-T only forum...hmmmm...
~Anthony.
Old 06-17-2003, 11:59 PM   #4
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
Hey Anthony! Not all RS-T's have those numbers for compression, at least for the 8.5 to 1 ratio guys. I am curious why this guys #2 numbers are so much lower than the rest. It may be a washed set of rings. I would expect a CEL light if that was the case. Running too rich would cause this to happen.
hayscoob is offline   Reply With Quote
Old 06-18-2003, 01:29 AM   #5
Mancini
Member#: 20726
For what it's worth I was seeing 198-200psi across the board in my 98. I've always thought as long as they're somewhat equal or within 10% or so of each other its not too bad.
I know even with dsm's it's ok if they're in the 120's and they're 7.8:1 on the 6 bolt engines.
As for the rings, I think running them hard at first will seal them better initially but will ruin the longevity of the engine..so you will see a decrease in compression if that it is the case.
edit: if you're not seeing that great of compression crank up the boost...more blow by = more opportunity for boost..j/k
Mancini is offline   Reply With Quote
Old 06-18-2003, 01:31 AM   #6
supermarkus
Member#: 6971
2008 WRX STi
SSM
Here's what I managed to find from the 02 WRX manual
DOHC Engine Page ME-22
Standard:
138-166 psi
Limit:
121 psi
Difference between cyls:
7 psi
Hmmm, kinda borderline. How was it running? Sorry if I didn't catch the background story.
supermarkus is offline   Reply With Quote
Old 06-18-2003, 01:48 AM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Testing the motor cold can result in a good amount lower numbers, BTW. Keep that in mind as you're looking at compression numbers from manuals versus your results... the books all test them hot.
Old 06-18-2003, 09:45 AM   #8
Puckaveli
Member#: 1518
00 2.5RS
Here's what the JDM manual says:
Standard - 142-171psi
Limit - 121psi
Difference between cylinders - 28psi
It is better to test a warm engine.
Puckaveli is offline   Reply With Quote
Old 06-18-2003, 10:53 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes it was cold .. and it was on the ej20G .. which i *think* is 8 to 1 like the ej205 ... but there has been suggestion that it is 8.5 or 8.8 to 1 in whcih case it is hosed ...
the proublem is that i have about --><-- skill tuning the tec 2 .. if i stay out of boost i am fine quite peppey actually..once i hit ~110 kpa it falls on its face oh yeah and the turbo seals are bad so it smokes
Old 06-18-2003, 11:48 AM   #10
Puckaveli
Member#: 1518
00 2.5RS
The manuals I have are for the EJ20G too.
Sounds like it needs some work.
Old 06-20-2003, 02:00 PM   #11
Z1 Performance
Member#: 9327
Well, try this...put a bit of ATF in it and crank again..if it goes up dramatically, the rings are worn, if not, its in the head.
Those numbers are borderline being acceptable, as its around a 10% difference across the cylinders
Adam
Z1 Performance is offline   Reply With Quote
Old 06-20-2003, 03:16 PM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
could i have screwed up somthing with the timing belt?
Old 07-01-2003, 09:32 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
so i heated the engine up today (coolant to 88C)
and re did the compression test
got 130 psi +- 1psi in all cylinders
Old 07-02-2003, 02:31 PM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
That's a good sign. Now you just need to check turbo bushings and main bearings
-Jon
Compression test number tell me what you think ScoobyJD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 01-06-2010 10:11 PM
Thoughts on my compression test numbers... phong Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-07-2007 11:22 AM
Odd compression test and leakdown test numbers SloRice Built Motor Discussion 10 11-13-2006 10:07 AM
what are normal numbers for a compression test? ted dibiase Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-12-2006 11:37 AM
Compression test results numbers Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-12-2001 01:08 AM
