Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 08-10-2000, 09:56 PM   #1
arejay
Member#: 1916
Post Transmission Code Self Diagnosis
The "Power" light indicates transmission codes. The following self diagnosis will show any fault codes for the transmission.
To perform the self diag test for EXISTING problems
1) Warm up engine by driving at speeds greater than 12mph.
2) Stop vehicle and turn ignition switch OFF.
3) Turn ignition switch ON and make sure POWER indicator lamp comes on.
4) Turn ignition switch OFF.
5) Move selector lever to D and turn manual switch ON.
6) Turn ignition switch ON.
7) Move selector lever to "3" and turn manual switch OFF.
8) Move selector level to "2" and turn manual switch ON.
9) Move selector lever to "1" and turn manual switch OFF.
10) Partially depress accelerator pedal (to turn idle switch off).
11) Check code as displayed on POWER light. Blinking once every 1/4sec is normal.
To perform the self diag test for PREVIOUS problems
5) Move selector lever to "1" and turn manual switch ON.
7) Move selector lever to "2" and turn manual switch OFF.
8) Move selector lever to "3" and turn manual switch ON.
9) Move selector lever to "D" and turn manual switch OFF.
Trouble codes:
11 Duty solenoid A
12 Duty solenoid B
13 Shift solenoid 3
14 Shift solenoid 2
15 Shift solenoid 1
21 ATF temp sensor
22 Atmospheric sensor
23 Engine revolution signal
24 Duty solenoid C
25 Engine torque control signal
31 Throttle sensor
32 Vehicle speed sensor 1
33 Vehicle speed sensor 2
arejay is offline
HTML code is On
2008 HVAC A/C Self Diagnosis - Please try this if your A/C is working properly 04wgn Newbies & FAQs 8 08-15-2008 01:59 AM
Manual transmission codes andrewv Transmission (AT/MT) & Driveline 2 02-15-2008 11:33 PM
Help reading transmission codes serious Transmission (AT/MT) & Driveline 3 04-01-2003 03:18 PM
4EAT transmission code numbers srfurby Transmission (AT/MT) & Driveline 4 07-01-2002 04:46 PM
Brake System Self Diagnosis arejay SVX Forum Archive 4 02-17-2001 09:28 AM
