Old 06-17-2003, 08:08 PM   #1
xtheviperx
Member#: 17580
2002 Impreza WRX
Platinum Silver Metallic
Default Just got the clutch replaced..
I just got my clutch replaced (THANKYOU quality Suabru in Wallingford, CT)
anyway...
It feels like it catches VERY low (low=pushed in) now...
is this normal or does it just feel different because its new..?
Thank you
--David
xtheviperx is offline   Reply With Quote
Old 06-17-2003, 11:47 PM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
The shop may have just adjusted the pedal travel to make sure it is fully engaged and doesn't slip when your foot is off the pedal.
You can adjust it out a little yourself, where the clutch lever leaves the passenger compartment near the gas pedal, to go into the firewall and engine bay. The rod that pushes on the hydrolics through the firewall is adjustable, you can loosen the nut and then screw the rod out.
ImprezaRS dot com is offline   Reply With Quote
Old 06-19-2003, 06:56 AM   #3
xtheviperx
Member#: 17580
2002 Impreza WRX
Thankyou
I will give that a shot... I will just lossen it a little bit
thanks again,
--David
Old 06-20-2003, 01:17 PM   #4
philip_g
Member#: 32906
which way would you adjust it? my clutch engages too far out for my liking, I have to have my foot off the ground and in a very bad position for fine control. I'd like it to grab further down, would I screw the rod out? or further in? I'm guessing in?
philip_g is offline   Reply With Quote
Old 06-24-2003, 12:02 AM   #5
ImprezaRS dot com
over boosted again
Member#: 1458
philip, yes, in to shorten the rod
Old 06-24-2003, 10:25 AM   #6
philip_g
Member#: 32906
thanks, done deal, MUCH better now.
From reading the directions I got the impression the adjustment was done in the engine bay, but it was actually by the gas pedal, no big deal.
Got my clutch replaced! HiVoltg12 Transmission (AT/MT) & Driveline 0 03-23-2006 05:47 PM
Just got sti clutch and flywheel any suggestions... hangten93 Transmission (AT/MT) & Driveline 4 08-04-2004 06:45 PM
just got new clutch from dealer..BUT.. skimmilk68 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-07-2004 04:37 PM
Just got my clutch replaced with an 03 WRX clutch, but I have questions S-WRX Transmission (AT/MT) & Driveline 10 03-25-2003 02:28 AM
Got my Clutch replaced at last! Wheels Warranty Issues & SOA Problems 1 04-21-2002 12:59 AM
