Old 06-18-2003, 12:20 PM   #1
mvstype
Member#: 4736
95 12 sec. Legacy
Same Color as a Booger
Default Starter Sensor on Clutch?
I went out to my car this morning and tried to start my car. Pushed down clutch and nothing, depressed then pushed down again then it started. I then went to get gas. I had to press the clutch many times before it would start.
Is there a sensor to change? Is it easy? Has anyone had this problem?
MV
mvstype is offline   Reply With Quote
Old 06-18-2003, 01:12 PM   #2
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
The clutch safety switch should be on the clutch pedal assembly if it's like other cars. Drop the lower dash panel and poke around under there, maybe it's just loose?
Word.
-Milan
US2JDM is offline   Reply With Quote
Old 06-18-2003, 03:09 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Or sticky, try to lubricate it.
Old 06-18-2003, 03:57 PM   #4
mvstype
Member#: 4736
95 12 sec. Legacy
The switch is tight & moves well. I have to really stomp on it to get it to work.
MV
Old 06-19-2003, 12:36 PM   #5
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
If you aren't worried about starting your car into a wall, you could just bypass that switch.
I can't recall if it's an open circuit or closed circuit safety, but either way, you could simply clip the wires (or crimp them together).
Not too elegant, but it'll solve your problem short term. And if you do your cuts / crimps cleanly, it shouldn't be too hard to reinstall a new switch later on.
One caveat before you do this- I think the sensor that disables the cruise control when you clutch in is a seperate unit entirely... but please verify that, and make sure you're hacking the right one.
-Brian
KD7000 is offline   Reply With Quote
Old 06-19-2003, 01:11 PM   #6
mvstype
Member#: 4736
95 12 sec. Legacy
I was thinking of doing that. If it got so I can't start the car.
The sensor for the starter is at the top of the peddle stroke & the sensor for the cruise is on the bottom. I don't get to use the cruis much in SoCal anyway.
I'm going to see if the local dealer has the part at lunch today.
MV
Old 06-19-2003, 07:42 PM   #7
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
Maybe I'm not understanding what you've said, but I think it's the opposite of that.
A light press on the clutch should disengage the cruise control, while putting the pedal to the floor should disable the starter lockout...
-Brian
Old 06-20-2003, 11:27 AM   #8
mvstype
Member#: 4736
95 12 sec. Legacy
I explain things terrible. The sencor that is bad it at the top of the pedal & the cruise sencor is on the bottom if you look under there.
MV
Old 06-20-2003, 12:31 PM   #9
Dealer Xing
Member#: 4673
As far as I know only USDM M/T cars have the dummy clutch switch, correct me if I am wrong.
Dealer Xing is offline   Reply With Quote
Old 06-20-2003, 03:01 PM   #10
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
Ummm, as far as I can tell, we're talking about USDM 5MT cars here.
Also, what do you mean by "dummy switch" ?? It's a real switch, not fake. If you're saying it's a switch for dummies, well, uh, no kidding. That's why I suggested earlier that he could just bypass it...
-Brian
Old 06-20-2003, 04:13 PM   #11
mvstype
Member#: 4736
95 12 sec. Legacy
I ordered the part. It is $32.
It is working fine now but I'm going to change it anyways. If it gets to the point that I can't start it before I get the part (Wed)I will just wire the two wires together.
It is not a dummy switch. It is pretty smart. It knows enough not to let me start the car.
Is there a car made with an auto with a clutch?
Thanks for the help everyone.
MV
Starter problem after clutch install naSTi wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-22-2009 10:22 AM
WTB: WRX Starter, 2.5rs clutch fork boot Switch07 Private 'Wanted' Classifieds 2 07-24-2008 10:44 AM
5mt starter & 6mt clutch akcel Drivetrain 0 06-19-2007 01:20 AM
TGV sensor the same as TPS sensor on 04 STi?? Clark Kent Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-20-2006 10:25 PM
Oil leak from starter - overfilled on oil change? codger Service & Maintenance 3 07-16-2003 08:33 PM
