Old 06-18-2003, 04:09 PM   #1
ndw1138
Member#: 32433
2005 STi V370
black
Default AC line and larger intercoolers - STi lines?
I assume the STi must have different AC lines (the metal hose that runs along the top of the intercooler) due to it's larger intercooler. Is there any reason that the STi metal hose can't be put on in place of the standard 02-03 WRX line? Any issues with replacing with the STi (STi being a RHD car the plumbing could be different up there?).
Reason being is every larger intercooler I have seen seems to either rub, or get too close to that line.. Rubbing is sooner or later going to cause a leak, I've put foam over the contact point but would rather just get the right line or simply bend it off the car.
Thanks for any input,
nathan
ndw1138 is offline   Reply With Quote
Old 06-18-2003, 04:42 PM   #2
teiva-boy
Member#: 22825
You can bend your stock line quite safely while it's still on the car. You can also try to fidget with the bracket on the firewall that holds the lines in place.
teiva-boy is offline   Reply With Quote
Old 06-18-2003, 05:42 PM   #3
Johnny5
Member#: 27200
2005 Legacy GT Ltd
Atlantic Blue
Do you have any photos with your A/C line bent with a larger intercooler? I have a STI TMI and pushed the A/C line as far back against the firewall as possible, but there's still a contact point with the IC near the blue cap on the IC line. For now I wrapped it in friction tape and put a wire loom over it, but getting not to touch at all would be ideal.
Thanks,
John
Johnny5 is offline   Reply With Quote
Old 06-19-2003, 07:48 PM   #4
ndw1138
Member#: 32433
2005 STi V370
black
Thanks,
John
If you get a chance shoot me a email address (the one you sent wasnt working).
At any rate, I talked to someone yesterday who sugested not bending those pipes. They are thinner than they appear and the slightest crack that you can't even be seen will let AC vapor escape and then your out a couple hundred buxs to fill up your AC after 1-2 hours of use. Altering the brackets doesnt look like a bad idea but I think this will only yield so much. I already moved mine a bit before installing the intercooler and I'm still silly close.
So I'm left with two options
- Figure out what the STi uses and get that pipe
- Put rubber around the hose in those contact areas (which I have been doing - via a old coolant hose) and hope this prevents any rattles or rubbing of metal on metal.
nathan
AC compressor and lines, tensioner w/pulley, and AC belt shibby2821 Engine/Power/Exhaust 24 08-01-2010 05:15 PM
FS(MN) Stock fuel lines and rails 05 Sti stihellride2005 Engine/Power/Exhaust 73 04-16-2010 07:41 AM
A/C line rubbing on larger intercooler 2mprzya Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 03-21-2008 08:52 AM
AVO600 and Larger Fuel Pump/Lines.. sponaugle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 49 02-19-2005 10:37 AM
