Old 06-18-2003, 06:04 PM   #1
BajaNut
Member#: 36905
2014 Outback SAP
leggtnut on lgt.com
Default Idle question on my MY90 legacy sedan L
Hello all,
In my MY90 Legacy Sedan L, I just had the Alternator replaced because it went out and now when I am Idleing, not all the time, the Idle drops down to about 500rpm's and sometimes it drops so low that it is stalling the car. Should I take the car back to the place that I had the alternator done, or could this be a compleatly different issue?
Thank you,
Ben
BajaNut is offline   Reply With Quote
Old 06-18-2003, 06:11 PM   #2
legacy2003
Member#: 38338
2003 Outback Sdn H6
might be the battery. my alternator went in my 95 and obviously the battery ended up dying. put a new alternator in and had sort of the same problem. replaced the battery and everything was golden. so check on that.
-mike
legacy2003 is offline   Reply With Quote
Old 06-18-2003, 06:17 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Ignoring the alternator replacement Id say without a doubt its a sticking Idle Air Controller.
Does the Idle bounce when its cold in the morning?
With the car off and the headlights on are they a reasonable brightness? Even with the alternator disconnected the car should be able to idle just fine if the battery is okay. The other way around too, if the battery is near dead the car should be able to run when the alternator is providing power (without the headlights, brakelights or rear defrost on).
Idle Question on 2000 OBS Richard1296 Normally Aspirated Powertrain 0 12-11-2006 07:42 PM
wrx springs/struts on installed on a 95 legacy sedan emyselfandi Brakes, Steering & Suspension 0 03-23-2005 09:25 PM
Uneven idle problem on my snowblower nitrohuffer Off-Topic 11 01-12-2005 03:15 PM
Just picked up my 2004 Legacy Sedan Diabolical1 CC Legacy Forum 3 07-25-2004 09:08 AM
Mirror tint -- here's a couple pics on my silver Legacy GT sedan... JSiwek Interior & Exterior Modification 6 02-25-2002 02:48 PM
