Old 06-19-2003, 01:22 PM   #1
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
98 Unicorn EVO Killer
Default Turbo Question
Hey guys, im not sure if im even in the correct forum for this. but here it goes. Anyway heres my question a budy of mine owns a 2000 Legacy Limited with the 2.5l motor as all of you knew im sure. But he found himself a 1991 Legacy Turbo 2.2 and he was told that he could convert his car into a turbo using the stock compents off the 2.2 Turbo, but he could only run it at about 4psi, the only thing that he said he might have to change was a sensor.. didnt say which one though.. but mentioned that he would need it from a WRX ? i think this seems fishy to me. and if its possible can i do it to MY99 RS cuz if so im doin some junkyard searchin.. thanks guys.. peace
PumpsGOTAWD is offline   Reply With Quote
Old 06-19-2003, 01:33 PM   #2
OKRS25
Member#: 36533
2005 STi
Your in the right place, search around in this topic and you will find almost every answer to any question you could have...
OKRS25 is offline   Reply With Quote
Old 06-19-2003, 02:54 PM   #3
trilap5e
Member#: 19644
2005 WRX STi
I second the search - you'll find tons of info here!! Like OKRS25 said, it's all here...
trilap5e is offline   Reply With Quote
Old 06-21-2003, 01:45 AM   #4
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
cant someone just gimme an answer.. so i dont have to do all that work ..... haha .. thanks guys..
Old 06-21-2003, 02:47 PM   #5
Unsung Boxer
Member#: 37196
OK, here, i will help you a bit.
For aftermarket forced induction you will need the following:
1. Turbo, Up Piping, Down Piping, Intake Piping, Intercooler.
2. Fuel Managment. To correct the fuel maps of the NA ECU. Apexi SAFC's, Link ECU, Greddy ECU's.. these work well.
3. Missing Link (check valves that trick the Maf sensor).
4. Upgraded Fuel flow, Fuel Injectors, Fuel Pump, maybe FPR?
5. Up/Down pipe routing technique...
... here is the catch. You can use stock WRX up and down pipes if you replace ur crossmember w/ a WRX one (or what we call the Turbo Xmember). If you dont want to dig this deep, you get custom up/down pipes made. as seen here www.uniquemotorsports.com
at any rate, this is not an easy task. All of use tell you to use the search because your question is the basis for this ENTIRE forum.
-Jake
Unsung Boxer is offline   Reply With Quote
turbo, EWG and Turbo question silver_rocket Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-15-2007 06:47 PM
2 questions- 1) sti sb question 2) bigger turbo question legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-23-2005 05:43 PM
newbie with a question...2.5rs turbo question...which ones???? QCK HNDA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-03-2001 08:10 PM
Quick turbo question IMPBOY Bay Area Impreza Club Forum -- BAIC 3 06-02-2001 10:55 AM
Turbo Question for all you turbo people out there Jimmy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-14-2001 01:30 AM
