Old 06-19-2003, 02:08 PM   #1
Track Assassin
Member#: 38193
Default what springs drop the most for 00 L?
my girlfriend is looking for some springs for her legacy L sedan, so far i found h&r, sti and eibach springs for her, anyother companies make spings for her? and which one drop the most?she dont really care about the performance, shes more to the show side.
Track Assassin is offline   Reply With Quote
Old 06-19-2003, 02:48 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
MN eh? why dont i find girlfriends around rochester with good taste in cars
anyways, if i remember correctly from doing my searches long ago, the H&R's dropped it the most, but i mean some sites would post a bigger drop than others on the same springs, but this was before any were even out for the 00+ models. i ended up going with some coilovers but if she doesnt want the performance, h&r is a good brand, and check out whiteline for another option, as i believe they have springs for the BE's(your gf's car)
anyone else have some input?
Ben
Old 06-19-2003, 03:49 PM   #3
finse46
Member#: 30756
2006 Legacy GT SpecB
Artic Silver
Well, I am not sure about the maximum drop. However, I placed STi springs on my '01 GT. The car is stoopid low now. Do a search for finse in the bling bling thread for some pictures.
Ryan
finse46 is offline   Reply With Quote
Old 06-19-2003, 03:54 PM   #4
Hiroki Tada
Member#: 8048
I've put whiteline springs on my 02 GT. Dropped it at least 2.25". The car is riding stupid low, but it looks very nice. Its got an even wheel gap all around each wheel. Looks very sharp. Very affordable too. About 420$-ish Cdn for the set of springs.
Hiroki Tada is offline   Reply With Quote
Old 06-19-2003, 06:17 PM   #5
Solomon
Member#: 36587
2000 Legacy GT (BE)
I am trying to find some struts for the car to go with anything other than whiteline...no luck. I can't find anything for H&R for MY00 BE, or struts.
I was thinking about going with some whitelines on my stock struts to help kill some of the roll, does anyone know if that would do it?
If not, there is NOTHING for 00+ but whiteline springs or coilovers. Then again coilovers are only like 1k more.
Solomon is offline   Reply With Quote
Old 06-19-2003, 07:04 PM   #6
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Cut ones.
US2JDM is offline   Reply With Quote
Old 06-19-2003, 07:31 PM   #7
Solomon
Member#: 36587
2000 Legacy GT (BE)
cut ones?
Old 06-19-2003, 10:00 PM   #8
Hiroki Tada
Member#: 8048
He meant by saying that you could always cut your stock springs. A typical ricer move only for show and will wreck any handling your leggy may have.
I have whitelines on stock struts and it killed the body roll. Mind you, theres still some, but now I can take highway onramps at pretty damned high speeds and not feel as if my car is going to flip. A definite improvement and it looks pretty damned sweet.
Im getting a rear adj. swaybar to finish off that roll and by then my car should rotate.
Old 06-19-2003, 10:08 PM   #9
tora
Member#: 5851
09 Forester XT
+ NA Miata
I had whitelines before. They lowered the car about 1.8" and about 2 after a couple months of settlement. They were pretty rough on the stock struts though.
I took them off and will be getting either H&Rs, Prodrives and KYB GR2's which will be out in July for our cars.
tora is offline   Reply With Quote
Old 06-19-2003, 11:39 PM   #10
Solomon
Member#: 36587
2000 Legacy GT (BE)
What H&R springs do I get for MY00 sedan?
Old 06-19-2003, 11:49 PM   #11
jkyes
Member#: 707
99 Legacy GT
Quick silver
Default duluth
if this is from Duluth MN, you are not going to want to lower it all the way down... you'll be dragging on the roads... though i live in the twin cities, i lived in duluth for 5 years and it has some of the worst roads around.
jkyes is offline   Reply With Quote
Old 06-20-2003, 02:13 AM   #12
TGycageL0002
Member#: 9116
2000 Legacy
Timberline Green Pearl
here is the formula that worked for me
whiteline spring for the BE
GAB strut tower bar
Whiteline Front sway
Whiteline rear sway
In total, I am in to suspension around 500 bucks..... great investment
H&R does NOT make springs that fit the sedans, sti requires new top mounts, WHITELINE FITS PERFECTLY!!!!!
TGycageL0002 is offline   Reply With Quote
Old 06-20-2003, 02:18 AM   #13
Solomon
Member#: 36587
2000 Legacy GT (BE)
What is the "GAB strut tower bar"? Just a standard strut bar right?
Old 06-20-2003, 03:59 AM   #14
Hiroki Tada
Member#: 8048
I think so, but I've never heard of GAB before.
Why not go all out like I did and go STi? Pink looks great in the engine bay.
Old 06-20-2003, 11:52 AM   #15
tora
Member#: 5851
09 Forester XT
+ NA Miata
H&R should fit, but I'm guessing the rear spring rates would be different. (Unless sedans have different fitment than wagons??) Are you sure whitelines fit directly in? I had to install GC8 topmounts on the front to install whitelines on my car. Is our front spring diameter (coil diameter) different?
Old 06-20-2003, 12:29 PM   #16
Hiroki Tada
Member#: 8048
They fit on the stock perches and with the stock tophats. Front and rear.
No problems at all.
Old 06-20-2003, 03:02 PM   #17
Track Assassin
Member#: 38193
do tein make spings for her car? or just for the wagons?
Old 06-20-2003, 03:17 PM   #18
Solomon
Member#: 36587
2000 Legacy GT (BE)
Yes. They make the FLEX and the CS for the sedans. JoeT has the CS, and you can get the FLEX that works with the EDFC unit. I have had a few vendors tell me that you can, one has told me that you have to get some new top mounts. I have gotten quotes from $1398 complete to what http://godspeed.hack.net/tein.html has them marked.
I am leaning towards teh JIC. CUSCO are nice just alot of money.
Old 06-20-2003, 07:41 PM   #19
Solomon
Member#: 36587
2000 Legacy GT (BE)
Well I ordered the Prodrive springs and mounting stuff for my Legacy today.
I will have to wait until the GR2's come out later to swap out the struts. I have found that the serial numbers are out on GR2's for us BE/BH users, but nothing on when they ship.
Will let you guys know how it goes with the springs stock combo.
Old 06-21-2003, 04:09 AM   #20
chaneric911
Member#: 23905
2000 Legacy GT Wagon
Brillant RED
I have a set Used kg/mm for 00 legacy it is so low it drop 1.8 Front and 2.25 at rear.
If you are interest PM me.
chaneric911 is offline   Reply With Quote
Old 06-21-2003, 11:52 AM   #21
Track Assassin
Member#: 38193
so what springs bolt on perfectly, no custom work at all?
Old 06-21-2003, 12:01 PM   #22
tora
Member#: 5851
09 Forester XT
+ NA Miata
Eric, PM'd you.
Old 06-21-2003, 10:07 PM   #23
JLow03
Member#: 34959
2003 330i ZHP
1987 325is
So where do you guys buy Whiteline products, and who will be carrying the KYBSs when they do come out?
JLow03 is offline   Reply With Quote
Old 06-21-2003, 10:26 PM   #24
Hiroki Tada
Member#: 8048
Just go to Whiteline's site and look for a dealer near you. Thats how I scored my set of springs.
What springs lower the most? 35large Brakes, Steering & Suspension 15 07-08-2008 03:36 PM
what spring is the softest for 04 sti?? hoonsup2 Brakes, Steering & Suspension 5 04-07-2007 09:56 PM
What springs drop the least ? Jaredm82 Brakes, Steering & Suspension 8 07-07-2004 03:38 PM
what springs lower the most? Scoobs Brakes, Steering & Suspension 6 05-31-2002 03:05 PM
what springs drops the WRX 2.5 in front and 2 in back? Wrx0R Brakes, Steering & Suspension 9 01-27-2002 03:19 AM
