Old 06-19-2003, 06:37 PM   #1
sybir
Member#: 4615
05 STi, 97 Leg OB
Default yet another spring question.......
Okay, in the continuing quest for molesting an OB........
One of the local club guys said he'd give me WRX wagon springs (free)......
So I'm thinking; the weights for the GG's and the BG's are similar, they're both wagon setups, my OBshocks still seem to be good, and were stiffer than RS units......
Will WRX wagon springs fit on an OB (I know this is uncharted, but let's just say BG, then) struts and topmounts?
Looking at the spring diameter post, the seats on the Legacy struts/top mounts are 134mm, while WRX's are 130.....so I'm talking a 2mm offset on the spring perch....
How horrible an idea is this, given that I'm not trying to get the car on the ground, just get rid of a little bit of gap?
sybir is offline   Reply With Quote
Old 06-19-2003, 07:29 PM   #2
froggert
Member#: 768
OB, legacy, 911,
ram 1500, 1098s, m620
i think you'll need new upper spring perches and the rubber things in the front. i wasn't able to fit legacy springs on wrx wagon spring perches.
i've got a box of various suspension parts and may have a set or two of the impreza pieces. pm me if interested.
froggert is offline   Reply With Quote
Old 06-19-2003, 07:41 PM   #3
sybir
Member#: 4615
05 STi, 97 Leg OB
hmmmmm
in what way didn't the springs fit? (too big/too small?)
might be interested
Old 06-19-2003, 10:10 PM   #4
froggert
Member#: 768
OB, legacy, 911,
iirc, springs were bigger than the rubber rings and metal perches.
Old 06-19-2003, 10:36 PM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & 06 MCS
so in simple terms, the diamiter of the springs is what causes them to not be interchangable.
subiekid is offline   Reply With Quote
Old 06-20-2003, 01:23 AM   #6
sybir
Member#: 4615
05 STi, 97 Leg OB
right.
I realize they're different diameters. Not having messed with the suspension too much, I wasn't sure if it was a small enough difference that it would work.
Here's the other curiousity
I was able to build up a spring/strut combo that fit together fine (though I didn't end up using it) with RS struts, OB springs, and OB strut tops
and the RS bottoms are supposedly 141mm according to the Whiteline data
hmmmmmmmmmmmmm
Yet another spring question aren040 Newbies & FAQs 13 02-18-2005 07:21 PM
Yet another clutch question PhillyWReXx Warranty Issues & SOA Problems 6 07-28-2002 11:03 AM
Yet another morette question brunetmj Interior & Exterior Modification 2 08-19-2001 04:38 AM
Yet another ABS question... Penphoe Brakes, Steering & Suspension 4 12-15-2000 03:05 PM
Message Board Statistics All times are GMT -4. The time now is 02:11 PM.
